Programming Multiple PICs Simultaneously
Results 1 to 14 of 14
    Yeah, expensive indeed. I know microchip do one as well, still expensive.
    Sure it's doable to create your own with your interface. You just need to launch your regular PIC programmer application few times and switch the programming pins from one socket to another, that way, each PIC will be verified before... slower but shouldn't be so hard to build.
    Food for thought!
    Another perfect place for your USB code...
    Build a circuit to switch Vpp and Vdd amongst multiple chips in the gang programmer, and hook up your USB cod/circuit to generate keystrokes to start the program/verify sequence again with whatever software you've got running...
    yeeeeshhh....another sleepless night...
    Yup, possibilities are endless here. If i was going to build one for myself, i would hack/log/sniff the programmer port first to see what the PC send to initialize the programmer (if there's any) and then create a program around that.
    Food for thought... once again!
    One more possibility for quantities ...
    Microchip can deliver chips already programmed ...
    Yes, I know ... it's not so fun !!!
    I find 30 pesos a day for somebody from Mexico (or read Romania if you're in Europe) along with your standard 1-gang programmer is a cheap solution. As a bonus you can get them to clean your car in the yard which is outside the scope even for the most expensive multi-gang programmer.
    Feb 2003
    Thats why Mistress Melanie is the boss
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Thumbs down Pass
    No thanks.
    I'll get the neighbor's kid to do it for me....right after he shovels the snow out of my driveway! After all, it's only about 350ft long! Then I'll give him a cup of hot chocolate and call it a done deal...
    Aug 2005
    Denver
    Yeah, and then you get the INS chasing them through your yard and putting huge footprints in your garden. Currently it's a $10,000 fine in the US for knowingly hiring an illegal alien. Factoring that into the financial equation, you'd have to be programming a whole lot of chips to make it a profitable venture.
  1. Simultaneous programming of multiple pics - is it possible?
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 18th April 2010, 04:56
  2. Multiple PICS from Same Crystal?
    By WOZZY-2010 in forum General
    Last Post: - 6th February 2010, 15:18
  3. Retrieving infos from multiple PICs on a bus/chain
    Last Post: - 15th October 2007, 04:42
  4. Programming Pins of PICs?
    Last Post: - 15th August 2007, 18:59
  5. Multiple PIC programming
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 7th May 2007, 23:47
