Crystalfontz LCD
Results 1 to 10 of 10
    Jan 2007
    Default Crystalfontz LCD
    Hi
    Silly question
    Has anyone done an emulator in PBP for these http://www.crystalfontz.com/products/632/index.html serial displays.
    I am thinking of writing one but i dont want to revent the wheel.
    That way we can use our cheap LCD's with the magnitude of software
    allready out there for these displays.
    John
    Jan 2007
    Default Lcd
    Hi
    So nobody done this i got it mostly working
    Works with LCD Smartie and my router .
    At 9600 my router displays rubbish characters but at 9600 when
    connected to my pc it seems ok.
    ideas anybody
    is this good code / bad code
    '* Name : Crystal.pbp adapted from SERCLCD1b.BAS *
    '* Author : John Gerrard *
    '* Notice : Orginal Author Ranjit Diol *
    '* Date : 29/01/07 *
    '* Version : 1..00 *
    '* Compiler: PICBasicPro Ver 2.45 *
    '* Notes : Designed for HD44780 type character *
    '* MCU : PIC16F628 *
    DEFINE OSC 20 'Set the Xtal frequency
    include "Modedefs.bas" 'Include general definitions
    'ADCON1 = 7 'Make all pins digital
    cmcon = 7 ' Make port Digital
    ' ** Declare LCDOUT Defines **
    DEFINE LCD_LINES 2
    Define LCD_DREG PORTB
    Define LCD_DBIT 4
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 0
    Define LCD_EREG PORTB
    Define LCD_EBIT 3
    ' ** Define LCD Control Constants **
    CTL Con 254 ' Control Byte
    Clr Con 1 ' Clear the display
    HOME Con 2 'Beginning of the 1st line
    LINE1 Con 128 ' Point to beginning of line 1
    LINE2 Con 192 ' Point to beginning of line 2
    LINE3 Con 148 ' Point to beginning of line 3
    LINE4 Con 212 ' Point to beginning of line 4
    CGram Con 64 ' Point to Cgram within LCD
    DDram Con 128 ' Pont to DDRAM
    ShiftL Con 24 ' Shift display left
    ShiftR Con 28 ' Shift display right
    Blank Con 8 ' Blank display (don't clear memory)
    ULon Con 14 ' Underline ON
    BlinkCur Con 15 ' Blinking Cursor
    CurLeft Con 16 ' Move cursor left 1 position
    CurRight Con 20 ' Move cursor right 1 position
    BlockCur Con 13 ' Block cursor
    Space Con 32 'ASCII code for a space
    Null CON 0
    ' ** Declare Variables **
    SI Var PortB.1 ' Serial In Inverted
    VDD Var PortA.3 ' LCD VDD pin
    InByte1 Var byte ' The byte received
    InByte2 var byte ' Second byte recvd
    InBytes VAR BYTE[4] 'For multi commands
    baud var word 'Baud rate
    bd var word 'Displayed baud number
    BP0 var PortA.0 'A0,A1,A3 Pins used to determine
    BP1 var PortA.1 'baud rate and polarity
    BP2 var PortA.2
    ch1 var byte 'General variables
    ch2 var byte
    ch3 var byte
    bits var byte 'Used for baud calculations
    tmp var byte 'Temp var
    CGChar var byte[8] 'CGRam custom character
    CGAddr var byte 'CGRam address
    cnt var byte 'General use counter
    ' Init LCD
    HIGH VDD ' Switch On LCD VDD
    Lcdout $fe, 1 ' Init LCD
    pause 100 ' Wait for LCD to Initialize
    'Initialize variables
    bits = 0
    'Set to high
    high BP0
    high BP1
    high BP2
    low SI
    'Now make them input (they should read high)
    input BP0
    input BP1
    input BP2
    input SI
    'Check pins to determine baud rate and polarity
    'BITS var will end up having a value to
    'determine baud and polarity
    if BP0 = 0 then
    bits.0=0
    bits.0=1
    if BP1 = 0 then
    bits.1=0
    bits.1=1
    if BP2 = 0 then
    bits.2=0
    bits.2=1
    if bits > 3 then
    bits = bits - 4
    ch1 = "N" 'Inverted TTL RS232
    ch1 = "T" 'True RS232
    '19200 4800 2400 9600
    lookup2 bits,[32,188,396,84],baud
    lookup2 bits,[19200,4800,2400,9600],bd
    if ch1 = "N" then baud.14 = 1 'Invert it
    '==== MAIN SECTION =======
    gosub Init
    InByte1 = " "
    MainLoop:
    Serin2 SI,baud,[InByte1] ' Receive the serial byte
    if InByte1 <= 31 then goto LCDfonz
    if InByte1 >= 128 then goto Custom
    Lcdout InByte1 'Dispaly the Char
    Goto MainLoop
    LCDfonz:
    'if InByte1 = 0 then MainLoop
    select case InByte1
    case 0
    ' Null do nothing
    case 1
    lcdout CTL, Line1
    'LOW VDD 'lcdout ctl, 1
    'pause 30
    case 2
    Lcdout CTL, blank
    case 3
    Lcdout CTL, 12
    case 4
    Lcdout CTL, 12
    Case 5
    lcdout ctl, ulon
    case 6
    lcdout ctl, blockcur
    case 7
    Lcdout CTL, blockcur
    case 8
    Lcdout CTL, curleft
    case 9
    Serin2 SI,baud,[InBytes(0)] 'command Value
    case 10
    ' Null do nothing
    Case 11
    ' Null do nothing
    case 12
    lcdout CTL, $C0
    lcdout " "
    lcdout CTL, $80
    lcdout " "
    case 13
    ' Null do nothing
    case 14
    Serin2 SI,baud, [InBytes(0)] 'Brightness
    'LOW VDD 'high vdd
    case 15
    Serin2 SI,baud, [InBytes(0)] 'Contrast
    case 16
    ' Null do nothing
    Case 17
    Serin2 SI,baud, [InBytes(0), InBytes(1)]
    if InBytes(1) = 0 Then
    Lcdout CTL, ($80 + InBytes(0))
    lcdout CTL, ($C0 + Inbytes(0))
    case 18
    ' Null do nothing
    case 19
    ' Null do nothing
    Case 20
    ' Null do nothing
    case 21
    ' Null do nothing
    case 22
    ' Null do nothing
    Case 23
    ' Null do nothing
    case 24
    ' Null do nothing
    case 25
    Serin2 SI,baud, [CGAddr, CGChar(0), CGChar(1),_
    CGChar(2), CGChar(3), CGChar(4), CGChar(5),_
    CGChar(6), CGChar(7)]
    Select case CGAddr
    Case 0
    LCDOUT CTL,64,CGChar(0),CGChar(1),CGChar(2),CGChar(3),CGC har(4),CGChar(5),CGChar(6),CGChar(7) ' Write Custom Char
    Case 1
    LCDOUT CTL,72,CGChar(0),CGChar(1),CGChar(2),CGChar(3),CGC har(4),CGChar(5),CGChar(6),CGChar(7) ' Write Custom Char
    Case 2
    LCDOUT CTL,80,CGChar(0),CGChar(1),CGChar(2),CGChar(3),CGC har(4),CGChar(5),CGChar(6),CGChar(7) ' Write Custom Char
    Case 3
    LCDOUT CTL,88,CGChar(0),CGChar(1),CGChar(2),CGChar(3),CGC har(4),CGChar(5),CGChar(6),CGChar(7) ' Write Custom Char
    Case 4
    LCDOUT CTL,96,CGChar(0),CGChar(1),CGChar(2),CGChar(3),CGC har(4),CGChar(5),CGChar(6),CGChar(7) ' Write Custom Char
    Case 5
    LCDOUT CTL,104,CGChar(0),CGChar(1),CGChar(2),CGChar(3),CG Char(4),CGChar(5),CGChar(6),CGChar(7) ' Write Custom Char
    Case 6
    LCDOUT CTL,112,CGChar(0),CGChar(1),CGChar(2),CGChar(3),CG Char(4),CGChar(5),CGChar(6),CGChar(7) ' Write Custom Char
    Case 7
    LCDOUT CTL,120,CGChar(0),CGChar(1),CGChar(2),CGChar(3),CG Char(4),CGChar(5),CGChar(6),CGChar(7) ' Write Custom Char
    End select
    Case 26
    ' Null do nothing
    case 27
    ' Null do nothing
    case else
    'Lcdout CTL,InByte1
    end select
    goto Mainloop
    Custom:
    if InByte1 > 135 Then ' if not a custom Char then return
    Lcdout InByte1
    Goto Mainloop
    select case InByte1
    case 128
    lcdout 0 ' Dispaly Custom Char 0
    case 129
    lcdout 1 ' Dispaly Custom Char 1
    case 130
    lcdout 2 ' Dispaly Custom Char 2
    case 131
    lcdout 3 ' Dispaly Custom Char 3
    case 132
    lcdout 4 ' Dispaly Custom Char 4
    Case 133
    lcdout 5 ' Dispaly Custom Char 5
    case 134
    lcdout 6 ' Dispaly Custom Char 6
    case 135
    Lcdout 7 ' Dispaly Custom Char 7
    end Select
    goto MainLoop
    '******End of Main Program *********
    'Subroutines
    'ClrLCD:
    ' Lcdout CTL,Clr
    ' Pause 50 ' Clear the LCD
    'Return
    Init:
    'Load Custom CGRam characters
    LCDOut CTL,64,$00,$04,$02,$1F,$02,$04,$00,$00,CTL,128
    LCDOut CTL,72,$00,$04,$08,$1F,$08,$04,$00,$00,CTL,128
    LCDOut CTL,80,$00,$04,$0E,$15,$04,$04,$00,$00,CTL,128
    LCDOut CTL,88,$00,$00,$04,$04,$15,$0E,$04,$00,CTL,128
    LCDOut CTL,96,$1F,$11,$11,$11,$11,$11,$11,$1F,CTL,128
    LCDOut CTL,104,$04,$0E,$1F,$00,$00,$1F,$0E,$04,CTL,128
    LCDOut CTL,112,$02,$06,$0E,$1E,$0E,$06,$02,$00,CTL,128
    LCDOut CTL,120,$08,$0C,$0E,$0F,$0E,$0C,$08,$00,CTL,128
    logo:
    'Lcdout CTL,Clr:Pause 100 ' Clear the LCD
    Lcdout CTL,LINE1,"Crystal EMU .90"
    Lcdout CTL,LINE2,"Baud: ", ch1,dec bd
    Lcdout CTL,HOME
    Mentor, Ohio
    Smile
    Hi jman12,
    Yes you are re-inventing the wheel so to speak. There was a recent thread regarding serial interfaces for LCDs. I have purchased a number of 9600 and 2400 interfaces from www.wulfden.org. Very inexpensive. They come in kit form (I love building things!) and also have 1x14 and 2x7 pinouts and they handle up to 20x4 screens.
    HTH
    BobK
    Jan 2007
    Default Orginal Thought
    Yip i can buy one of those very nice looking units but still i want it to
    emulate a Crystalfonz unit.
    I like the idea of the 64 char buffer any idea's on how to do that
    Jman
    Jan 2007
    Default Better Now
    Hi
    The codes now looks like this
    i use hserin and now 9600 is perfect
    i also added contrast control (thanks to the forum serach for that).
    This code now works quite well LcdSmartie and my Miktotik routers.
    Regards Jman
    ' LCD should be connected as follows:
    ' LCD PIC
    ' DB4 PortA.0
    ' DB5 PortA.1
    ' DB6 PortA.2
    ' DB7 PortA.3
    ' RS PortB.7
    ' E PortB.6
    ' RW Ground
    ' Vdd 5 volts
    ' Vss Ground
    ' Vo PMW via20K potentiometer (or ground)
    ' DB0-3 No connect
    DEFINE LCD_LINES 2
    Define LCD_DREG PORTA
    Define LCD_DBIT 0
    Define LCD_RSBIT 7
    Define LCD_EBIT 6
    ' HSERIN defines
    DEFINE HSER_SPBRG 129 ' 9600 Baud @ 20MHz, 0.16%
    Null CON 0
    Restore CON 12
    contrast var byte 'General variables
    ch2 var byte
    ch3 var byte
    ' Init LCD
    'contrast set default
    'HPWM 1,20,1300
    gosub Init
    InByte1 = " "
    MainLoop:
    HSerin [InByte1] ' Receive the serial byte
    Goto MainLoop
    LCDfonz:
    select case InByte1
    case 1
    lcdout CTL, Line1
    'pause 30
    case 2
    Lcdout CTL, blank
    case 3
    Lcdout CTL, Restore
    case 4
    Lcdout CTL, 12
    Case 5
    lcdout ctl, ulon
    case 6
    case 7
    case 8
    Lcdout CTL, curleft
    case 9
    hSerin [InBytes(0)] 'command Value
    case 10
    ' Null do nothing
    Case 11
    ' Null do nothing
    case 12
    lcdout CTL, $80
    lcdout " "
    lcdout CTL, $C0
    lcdout " "
    case 13
    ' Null do nothing
    case 14
    hSerin [InBytes(0)] 'Brightness
    'LOW VDD 'high vdd
    case 15
    hSerin [InBytes(0)] 'Contrast
    contrast = inbytes(0) * 2
    HPWM 1,contrast,1300
    case 16
    ' Null do nothing
    Case 17
    HSerin [InBytes(0), InBytes(1)]
    case 18
    ' Null do nothing
    case 19
    ' Null do nothing
    Case 20
    ' Null do nothing
    case 21
    ' Null do nothing
    case 22
    ' Null do nothing
    Case 23
    ' Null do nothing
    case 24
    ' Null do nothing
    case 25
    hserin [CGAddr, CGChar(0), CGChar(1),_
    Select case CGAddr
    Case 0
    Case 1
    Case 2
    Case 3
    Case 4
    Case 5
    Case 6
    Case 7
    End select
    Case 26
    ' Null do nothing
    case 27
    ' Null do nothing
    case else
    'Lcdout CTL,InByte1
    end select
    goto Mainloop
    Custom:
    'Lcdout InByte1
    Goto Mainloop
    select case InByte1
    case 128
    case 129
    case 130
    case 131
    case 132
    Case 133
    case 134
    case 135
    end Select
    goto MainLoop
    Init:
    logo:
    Lcdout CTL,LINE1,"Crystal EMU Ver .99"
    Lcdout CTL,LINE2,"Jman says 9600 baud"
    Lcdout CTL,HOME
    Default nasty typo
    Hi jman,
    you got a typo that will cause a no compile
    it says CGC har instead if CGChar in 8 places.
    Jan 2007
    Default Typo
    HI
    It was during the copy paste from microcode mine has no compile errors
    and looks good in microcode
    Also the contrast is now connected to pmw pin with 2 resistors as per Mels diagram
    Thanks for looking
    Jman
    you could still shrink it a little bit
    LCDOUT LCDOUT CTL,64, STR CGChar\8 ' Write Custom Char
    Jan 2007
    Default shrink
    Thanks Mister E worked perfect.
    Any clue on how to add a buffer 64 chars would be nice
    John
            BufferChar VAR BYTE[64]
            HSERIN [STR BufferChar\64]
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. LCD will not start
