Help finding Crosspoint Switch?
Results 1 to 14 of 14
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default Help finding Crosspoint Switch?
    Hi all.
    I am desperately searching for some 4 x 4 crosspoint switch chips. There are plenty of them around, but only in LARGE quantities. Does anyone know where I can get hold of 20 or so. Most popular seems to be 22100 by STMicrosystems or MC142100 by motorola.
    I just don't wanna have to use 4 x 4066 where one of these, or similar would be perfect.
    I am automating keypad presses.
    Peter Moritz,
    Up the bush, Halfway to the outback, South Australia.
    Default 22100
    Mouser has them .48 usd in single qty. See link below
    http://www.mouser.com/search/Refine....user_Wildcards
    Jun 2005
    Mouser don't stock them. Their MOQ is 1000, already tried to order from them but had to cancel when I heard the MOQ!
    Thanks anyway.
    Default wrhuahhh
    Quote Originally Posted by muddy0409 View Post
    Thanks anyway.
    Is the MOQ because you are in Australia, because the link I posted says they have them in single order quantities. Perhaps someone here could run interference for you.
    Talking 4x4 for bushmen ???
    Hi, muddy
    Did you had a look for the old 74C922 ??? some still available.
    RCA also had the CD 22100 ...
    Hi, muddy
    I got a few of those, a bit expensive compared to other chips. These days, I take an old 16F84, program it accordingly, and send out key presses as a serial code.
    Hi, Peter
    This last sentence rang the alert bell ...
    Could we know a bit more ???
    Jun 2005
    Sure.
    An associate of mine has asked about the possibility of adding RFID cards to the alarm systems he installs, as he has had some enquiries from customers.
    My plan is to have a PIC read an RFID card and have the PIC drive a crosspoint switch wired accross the alarm keypad to "simulate" keypresses.
    I have the reading and driving all worked out but now need a Xpoint switch so I can design a PCB (size constraints).
    As a "just in case" I am looking, this weekend, at using 4066 chips (3 of them) connected as Xpoint array 4 X 3.
    With the difficulty I am having finding some, that will probably be the solution.
    See?
    Simplicity itself huh?
    (Well it is after getting some help on some problems from people in this very good forum.)
    I've got the code basically sorted out (it works on my Development board, anyway) and am just waiting now to do a cuppla PCBs.
    And NO, I cannot get any information from the manufacturer regarding their LAN format for the keypad to panel comms.
    I have had it displaying on a terminal, but I cannot make any sense out of the data I see going back and forth.
    The keypad and panel are both built around PICs.
    Peter Moritz.
    Last edited by muddy0409; - 11th January 2007 at 17:46. Reason: Spelling and grammar fixes.
    Peter Moritz.
    New South Wales,
    Australia.
    Wink Benefits of communication
    Hi,Muddy
    Was a good idea to ask you for the context ...
    What about a CD 4052 "Dual 4 Channel Multiplexer" ??? One half for the rows and one half for the lines ...
    just need 5 lines ( 4 + enable both ...) from the driving PIC ...
    Feb 2003
    I would have suggested that but 4052 is intended for Stereo switching so both sides share a common address
    ( I am using the 4052 to give me 4 serial ports on a 18F452 )
    Forgot about "Enable" on my solution but as only 3 out of 4 combinations would be used on the "column" select then the 4th option would give an open circuit so all done with 4 lines
    Keith
    www.diyha.co.uk
    www.kat5.tv
    AAAAAAArggggghhh, damned !
    you're right Keith !!! that needs two CMOS packages ... at least one 4052 and one 4053 or a pair of 4052 ... but can deal with 2 arrays !!! or, of course 2 x 4051 !!!
    Feb 2003
    Hi Peter,
    Instead of 3 x 4066 have you thought of using TWO x 4051 "back to back" instead. 4051s are common enough and cheap enough to be around for a long time yet
    Provided the combined series resistance of two crosspoints is low enough to drive the keypad you can use that to address a keypad of upto 8 x 8.
    To drive the 4066's you will need quite a few I/O lines or some form of IO expander whereas with the 4051 method you only need 6 lines for a 64 key 8x8 matrix and in your case get away with only 4 IO lines.
    Mux "a" on the rows using a & b address lines with line c tied to 0v
    Mux "b" on the columns using a & b address lines with line c tied to 0v
    connect the "common" terminal of each mux together.
    4051 is also available as an SMDso you can fit a pair of them in the same space that a normal DIP would take if you need to.
    Keith
    www.diyha.co.uk
    www.kat5.tv
  1. How can I get a PIC to switch 2.5V DC to my Opamp pin?
    By HankMcSpank in forum Schematics
    Last Post: - 9th January 2010, 22:04
  2. Replies: 14
    Last Post: - 26th September 2007, 05:41
  3. a switch and 2LED
    By win_832001 in forum mel PIC BASIC
    Last Post: - 11th October 2006, 22:06
  4. Newbie - 16F628A and switch latching
    Last Post: - 19th May 2006, 02:35
  5. Switch Sequence
    Last Post: - 13th February 2005, 20:36
