HPWM down
Results 1 to 6 of 6
Thread: HPWM down
    Sep 2006
    Default HPWM down
    I am attempting to control my motor using the HPWM. The code works, but the header has a problem .
    I used a header from a post I found here,it works, but I would liek to know what is wrong with mine
    This do not work:
    INCLUDE "modedefs.bas"
    DEFINE OSC 20 'use external 20mhz crystal
    PAUSE 300 ' start-up delay
    DEFINE CCP1_REG PORTB 'Hpwm 1 pin port, RIGHT
    DEFINE CCP1_BIT 3 'Hpwm 1 pin bit
    TRISA = %11111111 ' Set PORTA to all input
    TRISB = %00000000
    loop:
    HPWM 1,127,1000
    Goto loop 'Do it forever
    This code works:
    @ DEVICE MCLR_ON, INTRC_OSC, WDT_ON, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF, CCPMX_ON
    OSCCON=$60 ' use internal 4MHZ osc
    TRISB = %00000000
    loop:
    HPWM 1,127,1000
    As soon as i turn off the internal oscillation and put in a 20Mhz crystal, it does not work
    Hangover, Germany
    In your first program you forgot the "@ device"-statement. This statement is neccessary for every program! How should the PIC knows to initialize his oszillator ?
    And use the "DEFINE OSC"-statement !
    Yes and no, it goes much than this... using 20MHz, you can't produce a 1KHZ frequency. The lowest would be around 1.221 KHz...
    It's all explain in the PBP manual OR showned in my PicMultiCalc.
    <img SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1318&stc=1&d=116838497 7">
    Sep 2006
    like i said I tried that:
    Here is the code, it does not work, it always stays on high
    @ DEVICE PIC16F88, MCLR_ON, HS_OSC, WDT_ON, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF, CCPMX_ON
    PAUSE 100 ' start-up delay
    TRISB = %00000000
    loop:
    PORTB.4=1 'Enable B+ Both motors forward
    PORTB.5=0 'Enable B-
    PortB.6=1 'Enable A+
    PortB.7=0 'Enable A-
    HPWM 1,127,2000 'enable pin 13 Now for the speed of each motor
    pause 5500
    HPWM 1,210,2000
    pause 5500
    HPWM 1,127,1300 'enable pin 13 Now for the speed of each motor
    pause 5500
    HPWM 1,210,1300
    about now?
    EDIT: it's working here...
    Sep 2006
    I decided to put it at 5000
    HPWM 1,127,5000 'enable pin 13 Now for the speed of each motor
    pause 5500
    HPWM 1,210,5000
    pause 5500
    and it works
    thanks guys
  1. need help on hpwm
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 15:49
  2. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:05
  3. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 14:14
  4. HPWM and A to D interaction question 18F252
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 10th May 2006, 03:50
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
