LOADER_USED question
Results 1 to 3 of 3
    pbppic16.lib doesn't exist
    There is no pbppic16.lib. For the 14-bit core the library is pbppic14.lib
    Scroll down below the utility macros and look in the "Startup Code" section.
    why then does it insert a "GOTO 0x04" at location 0x0000?
    Because it needs to vector the the INIT location to process startup code
    that didn't fit between 0x00h and 0x03h.
    Scroll way down to the bottom of your pbppic14.lib, and look in the INIT
    section.
    The PC boot-loader software normally just re-maps whatever user code it
    finds after its own jump vectors, so this normally isn't a problem.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2007
    Thanks for that info. I actually had discovered that pbppic14.lib was being used when looking at the resultant ASM, but your explanation clarifies why.
    So, now I guess I need to decide whether I want to GOTO my bootloader immediately after all the PBP init code or whether I want to modify the .lib file to remap as appropriate. I'm thinking the latter might make more sense as I develop other programs relying on my bootloader. Either way, I have enough info to really get this done now, I think.
  1. ADCIN question
    By Greg McFadden in forum General
    Last Post: - 16th September 2008, 03:53
  2. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  3. Remote PIC input question
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 1st September 2007, 16:44
  4. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
