PC serial port funny
Results 1 to 14 of 14
    Steve, I've attached the VB program and the PBP prog. Its pretty uglgy but for the best part it works. Its works well with the vb prog when variables are sent as byte1, byte2. Strange this occur when the variable is sent eg HSEROUT ["aa", stepcnt].
    I also changed to the USART as I found using the serial commands I could not catch external inputs.
    Thanks for your time Steve,
    John
    O.K. i'll look at that. So you're using a 16F628 right? for serial comm, i would suggest you to use a crystal. To make sure to don't miss incoming stuff, i always suggest to use a USART interrupt.
    this
    ["aa", stepcnt]
    can't work because it will send a WORD ascii character... wich is impossible. So instead, you should work around and use
    ["aa", #stepcnt]
    but use VAL on the VB side.
    I'll do a little something here, totally different, so you could use some part of it in your actual code.
    Talking
    Thanks, I,m using a Xtal, found that out the hard way, could'nt work out why there were so many errors, after puting xtal in cct, errors disappeared. And yes, I'm using a 628.
    I kind of figured that "aa" stepcnt was a word representation of stepcnt and that on the other end it would need to be split in two to find the original values. I started off with #stepcnt but on the vb side after sending a whole bunch of words, errors started appearing. Never thought of the VAL function though. I just placed the value from the PIC straight into a txt box. Anyway, I hope my code is not to painfull.
    Thanks again
    John
    OK then, so i'll stop it here and skip the USART interrupt. In meantime, maybe you could use/read some part of what i've include.
    What i did is to use a fixed string format using DEC5 modifier on the PIC side
    hserout ["aa",DEC5 WordA]
    So it always send 7 bytes to the PC
    and on the PC side, i split the incoming string in 2 parts
            sWichOne = Mid(IncommingData, 1, 2)     ' get the header (two first character)
            wValue = Val(Right(IncommingData, 5))   ' get the value (5 last character)
    Where IncommingData = MSComm1.Input, sWichOne hold the "aa", "bb" or else 2 character header, wValue hold the decimal value after the header.
    no big deal.
    Bah, why not after all. This one use the USART interrupt. Thanks to Darrel instant interrupts... reduce indeed RTFM sessions to a minimum
    Smile
    Thanks Steve,
    I've just opened up the files the files you sent and begin to incorporate into my project. I'll let you know how I went, hopefully all good.
    Cheers
    John
    Thumbs up
    Thanks Steve. Eventually got back to my project. (To much time spent on this thing, so the missus says). Anyway, it works a treat. Iv'e added a couple more things to it as now the comms side of it works fine. I am considering using the picf88 for its ADC to measure battery voltgae.
    Thansk again Steve,
    John
  1. Send binary file to pic over pc serial port
    Last Post: - 3rd May 2011, 13:47
  2. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
  3. Microcontroller with 2 way paging application problem
  4. Replies: 2
    Last Post: - 28th April 2006, 12:10
  5. PC Serial Port Connections
    By BigH in forum Serial
    Last Post: - 20th January 2006, 08:24
