PC serial port funny
Results 1 to 14 of 14
    Lightbulb PC serial port funny
    Hi all,
    I guess this is a question more about the MSCOMM object within VB6 than PICs however, it may turn out the other way.
    I'm sending serial data to the PC and displaying the data in several text boxes. The connection between the PC and PICF628 begins when the VB6 form opens and the user initiates a request from the PIC. The PIC then sends 5 differnent variables plus a couple of characters at the front so that I could rip out the two command char which indicate which text box to display the data. I'm using the DEBUG @ 300 BPS for communication.
    The funny thing is that when any other data is sent after the initialization the PC comm port seems to have shifted (right) to places. I've attached both the PC code and a snippet from a large PIC file.
    I must mention that some of the VB code I obtained was off Rentron.com, I just added a few things.
    Oh, and one more thing, the days of frustration over the PICF88, was due to a decoupling cap, thanks for everyones advice especially Steve.
    Private Sub cmdinit_Click()
    Dim out As String
    out = "k"
    MSComm1.Output = out            'command to PIC to begin sending data.
    End Sub
    Private Sub Form_Load()
    Dim i As Integer
    Dim send_data As String
    Dim InStr As String
    MSComm1.CommPort = 2
    ' Fire Rx Event Every Two Bytes
    MSComm1.RThreshold = 6
    'If MSComm1.InBufferCount = 6 Then
        ' When Inputting Data, Input 6 Bytes at a time
        MSComm1.InputLen = 6
    'End If
    ' 300 Baud, No Parity, 8 Data Bits, 1 Stop Bit
    MSComm1.Settings = "300,N,8,1"
    ' Disable DTR
    MSComm1.DTREnable = False
    ' Open the port
    MSComm1.PortOpen = True
    End Sub
    Public Sub MSComm1_OnComm()
    Dim sData As String
    If MSComm1.CommEvent = comEvReceive Then
        sData = sData & MSComm1.Input
        sData = MSComm1.Input ' Get data (2 bytes)
    End If
    Call display(sData)
    End Sub
    Public Sub display(instring As String)
    Dim cmdword As String         'hold the command word
    Dim word As String        'holds the data
    Dim outstring As String
    If Len(instring >= Limit) Then
        outstring = instring
        instring = Right$(instring, Len(instring) - Limit)      'clears the buf
    Call handleinput(outstring)
    End If
    End Sub
    Sub handleinput(displaystr As String)
    Dim newstring As String
    cmdword = Left(displaystr, 2)     ' rip out the command
    word = Mid$(displaystr, 3, 4)      'rip out the data to be displayed
    Select Case cmdword
        Case "OK"
        Case "aa"       'lower bound
            lower.Text = word
        Case "bb"       'upper bound
            upper.Text = word
        Case "cn"       'step count
            stepcnt.Text = word
        Case "ab"
            focus1.Text = word
    End Select
    End Sub
    PIC code
    init:                           '
    sendlower:
    debug "aa", #lower
    PAUSE 100
    debug "bb", #upper
    PAUSE 100
    sendstepcnt:
    debug "cn", #stepcnt
    PAUSE 100
    sendf1:
    ADDR_L=1
    ADDR_H=2
    GOSUB readset
    DataA.byte0 = RDDATA_L
    DataA.byte1 = RDDATA_H
    debug "ab", #DataA
    I'm thinking that maybe I need to encapsulate the data in control characters then strip them out at the other end. But after looking at the output of the pic using (MCS Communicator) when the initialistion command is given, I can't see any errors. ?????
    I think yoyr problem is in your DEBUG statements in the PIC code. If you use the #modifier the PIC sends the the value of the variable as "text". So if the varaible lower is a word and set to 1234 the pic will send four bytes ie. "1","2","3","4" instead of the two bytes that the wordvariable consists of. That way the number of bytes the PIC sends depends on the actuall value of the variables so the OnComm() event will fire at different places in your "stream" since it's set to fire after every 6 bytes.
    I think that you need to do:
    sendlower:
    debug "aa", lower
    PAUSE 100
    And then on the VB-side you look for "aa" and then extract the high and low byte from the stream and put them together with Result = highbyte*256+lowbyte or something like that.
    Did it make any sence?
    /Henrik Olsson.
    Thanks Henrik,
    Yes I have tried what you've suggested, but only on the transmission of one variable containing 2 bytes. It worked fine. I will change the code and see if that does the trick. Ithink it might be a little tricky though.
    John.
    Smile
    Hi all,
    I've been able to get error free comms by sending the variables as high and low bytes (debug "aa", stepcnt.byte1, stepcnt.byte0). The same is not true when I send the variable as
    DEBUG "aa", stepcnt
    My steps taken to covert for display;
    cmdword = Left(displaystr, 2) ' rip out the command 'aa'
    newstring = asc(mid$, 3, 2)) ' put the rest of the word into var
    Lbyte = newstring AND &H255
    Hbyte = (newstring - Lbyte) / &H100
    word = (Hbyte * &H100) OR Lbyte
    Text.text=word
    This seems to work on paper. I've also swapped high and low around as I think the PIC sends the low order byte first?
    Even though I've got the project working well, could someone explain the correct way to strip data using VB.
    Most appreciated
    John
    Could you post your whole codes here (all VB(Vbp,form...) and PBP.Bas)? just pack both in a zip. Save me to re-invent the wheel and work exactly with what you have
    My single brain cell simply can't work with scratch and partial code snip... sorry i'm getting old
    Steve, I've attached the VB program and the PBP prog. Its pretty uglgy but for the best part it works. Its works well with the vb prog when variables are sent as byte1, byte2. Strange this occur when the variable is sent eg HSEROUT ["aa", stepcnt].
    I also changed to the USART as I found using the serial commands I could not catch external inputs.
    Thanks for your time Steve,
    John
  1. Send binary file to pic over pc serial port
    Last Post: - 3rd May 2011, 13:47
  2. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
  3. Microcontroller with 2 way paging application problem
  4. Replies: 2
    Last Post: - 28th April 2006, 12:10
  5. PC Serial Port Connections
    By BigH in forum Serial
    Last Post: - 20th January 2006, 08:24
