16F88 internal clock configuration
Results 1 to 29 of 29
    Feb 2005
    Bellevue
    Here it is..
    It won't do much unless you have this particular type of GPS that outputs the wierd data.. I captured some as a text file(which it is not).
    Attached is a zip file with
    1. shorter program files (Less the LST - it was too big)
    2. the 16F88 include file I use
    TG
    probably i'm getting older and need to sleep after only 22 hours awake but, i can't see why it's not working. I really suspect an hardware problem now. 0.1 uF ceramic Capacitor close to the PIC.
    i didn't get any compile error with the select case stuff.
    did you install the PBP patch for the F88???
    Here's the patch
    about the calculation what about if you skip the hexa to decimal and do like Bruce propose few post ago!!!
    Feb 2005
    Bellevue
    Thanks.. I'll try the patch and see what happens. Is the CAP from Gnd - + close to the V+ pin? I have nothing there.
    What post about skipping the Hex conv? I don't see that post in this thread.
    TG
    Feb 2005
    Bellevue
    Odd.. that patch does not work for me. It says the 16F88 file is an "unknown version"...
    hhhhhhhhhhaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa So you don't have the PBP 2.45!!!! probably the main cause of all your problem. OR if you have V2.45, remove it, reboot your system in 'safe mode', reinstall everything, and after that install the patch. everything should be done in a shell environement.
    start>> all programs>> accesories>> command prompt
    AND yes the capacitor must be place between 5 volt and ground as close as you can to the PIC.
    Quote Originally Posted by Tom Gonser
    TG
    i thought it was on this post... sorry
    there you go
    Feb 2005
    Bellevue
    Hmmm.. Reinstalling PBP is just copying files to a folder I thought. I think I need to do this, but am not sure exactly how to 'deinstall'. PBP does not show up in WinXP as a program that has a de-installer. I can move them out of a folder, restart, then put them back, but I don't see what that would do.
    Also, I think the 16F88.bas file is corrupt because the installer tries to update it, but says it fails because of an unknown version of that 16f88.bas.... This is probably the reason for the odd behaviour.
    I'll ping MELABS..
    Thanks for all your help!
    Tom
    Feb 2005
    Bellevue
    Red face Its Alive!
    Thanks folks!! The pesky (and cool) 16F88 gave up the ghost, and is computing math right!! I re-installed PBP, updated the 16F88.INC files, and reduced program space to 3000 from 4200. I DID have to struggle with the _CONFIG settings a bit, finally dupmping the .INC files in favor of putting it in the code after the @...
    [but] The ONLY thing that remains is an odd thing... My 'Onetime' routine does not appear to 'take'... I WANT it to go the the routine 'Onetime', and output data on the various serouts.. sort of a 'welcome' for 5 seconds.. What they DO is 'flash' super fast, and then disappear. Then the main program loop starts and things work fine..
    This is the LAST issue with this port! Is the fact I was running at 4mhz on the other unit an issue? I have the following OSC flags:
    DEFINE OSC 8
    OSCCON=%01111000 '8 Mhz
    CMCON = 7 'turn comparators off
    ANSEL = 0 'All digital
    A section of the program follows:
    Init:
    PORTA = %00000 'Initialize PortA to all zeros - all output
    TRISA = %00000 'All port A output
    PORTB = %00000010 'Initialize PortB
    TRISB = %00000010 'Port 2 input
    ' -----[ Main Code ]-------------------------------------------------------
    Gosub Onetime
    Menu:' ****** [Main Program Loop] ************************************************** ***************
    gosub counter ' main counter routine
    gosub getdata ' go get data
    gosub calcvalue ' calculate values
    gosub displayit ' display information
    if wp > 10 then
    gosub waypoint
    goto menu
    '************************* [First Screen] *****************
    Onetime:
    wp= 0
    serout2 Apinout, 16468, [I,CLR]
    serout2 Apinout, 16468, [I,L1_C1]
    serout2 Apinout, 16468, [" MicroTracker"]
    serout2 Apinout, 16468, [I,L2_C1]
    serout2 Apinout, 16468, ["(C)05 GPSFlight"]
    serout2 AGPSout, 16572,[27,91,50,74] ' clear screen vt-100
    serout2 AGPSout, 16572,[27,91,#10,59,#10,72] ' 10 th row, 10 column
    serout2 AGPSout, 16572,["GPSFlight MicroTracker"]
    serout2 AGPSout, 16572,[27,91,#12,59,#3,72] ' 5 th row, 3rd column
    serout2 AGPSout, 16572,["GPS Waypoint Port 4800-8-1-n"]
    serout2 AGPSout, 16572,[27,91,#13,59,#3,72] ' 5 th row, 3rd column
    serout2 AGPSout, 16572,["Connect GPS to this port to recieve waypoints"]
    serout2 cpinout, 84,[27,91,50,74] ' clear screen vt-100
    serout2 cpinout, 84,[27,91,53,59,51,72] ' 5 th row, 3rd column
    serout2 cpinout, 84,["GPSFlign MicroTracker (C) 2005 GPSFlight, Inc.",10, 13]
    Pause 5000
  1. 16F88 bootlader with Internal OSC
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2009, 11:15
  2. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 18:44
  3. Setting up internal clock correctly?
    By JohnM in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 21:29
  4. 16F688 Internal clock and MCLR
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 18th August 2007, 19:38
  5. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
