16F88 internal clock configuration
Results 1 to 29 of 29
    Hehe... i guess i found the problem
    Here's all the configuration fuse available for you 16F88
    ;Configuration Byte 1 Options
    _CP_ALL                      EQU     H'1FFF'
    _CP_OFF	                     EQU     H'3FFF'
    _CCP1_RB0		    		 EQU     H'3FFF'
    _CCP1_RB3                    EQU     H'2FFF'
    _DEBUG_OFF                   EQU     H'3FFF'
    _DEBUG_ON                    EQU     H'37FF'
    _WRT_PROTECT_OFF             EQU     H'3FFF'	;No program memory write protection
    _WRT_PROTECT_256             EQU     H'3DFF'	;First 256 program memory protected
    _WRT_PROTECT_2048            EQU     H'3BFF'	;First 2048 program memory protected
    _WRT_PROTECT_ALL             EQU     H'39FF'	;All of program memory protected
    _CPD_ON                      EQU     H'3EFF'
    _CPD_OFF                     EQU     H'3FFF'
    _LVP_ON                      EQU     H'3FFF'
    _LVP_OFF                     EQU     H'3F7F'
    _BODEN_ON                    EQU     H'3FFF'
    _BODEN_OFF                   EQU     H'3FBF'
    _MCLR_ON		   		     EQU     H'3FFF'
    _MCLR_OFF                    EQU     H'3FDF'
    _PWRTE_OFF                   EQU     H'3FFF'
    _PWRTE_ON                    EQU     H'3FF7'
    _WDT_ON                      EQU     H'3FFF'
    _WDT_OFF                     EQU     H'3FFB'
    _EXTRC_CLKOUT		    	 EQU     H'3FFF'
    _EXTRC_IO		    		 EQU     H'3FFE'
    _INTRC_CLKOUT                EQU     H'3FFD'
    _INTRC_IO		    		 EQU     H'3FFC'
    _EXTCLK			    		 EQU     H'3FEF'
    _HS_OSC                      EQU     H'3FEE'
    _XT_OSC                      EQU     H'3FED'
    _LP_OSC                      EQU     H'3FEC'
    ;Configuration Byte 2 Options
    _IESO_ON                     EQU     H'3FFF'
    _IESO_OFF                    EQU     H'3FFD'
    _FCMEN_ON                    EQU     H'3FFF'
    _FCMEN_OFF                   EQU     H'3FFE'
    use _INTRC_IO instead... i'm sure that will work.
    Feb 2005
    Bellevue
    Default Thanks.. this is getting closer!
    I am using the _INTRC-IO, and also tweaked the serin2 stuff, so I have 'data' coming across all com lines now. Problem is that it is just 'off'..
    1. ) It is resetting. I have one routine at the front which only happens on power up. The data from this is showing up off and on.
    2.) the math is off. Where a value should sa 4.9volts it reads 3.3. Were a GPS lat should be 47.xxx, it reads 65,511, or some such. Same with all the other values, so I am sure the loops are off.
    I made a simpler program that just spewed data to the different com ports - out on RB2, RA0, RA1. This just said "text", #counter - and looped from 1-100.. that worked fine. When I put the full program in, it gives bad data.
    I think the original program for the 16F876/a was a 4Mhz program (??).. Does running this at 8 Mhz mess that up? Is there some setting that is needed? Does not seem like there should be....
    Thanks a bunch for your assistance - I've never 'ported' from one PIC to another. This program works great on the other one... but we need to be on the F88.. did not know it was going to be so hard.
    Tom
    o.k now it seems more a hardware problem than a software problem. be sure your supply line is neat an un-noisy. 10uF tantalum+0.1uF must be place close to your PIC... AS close as you can.
    AND be sure your MCLR pin is tie to VCC via resistor.
    Enable power-up timer can be great. Also as Melanie previously said it can be interesting to test the 'oscillator frequency is stable bit' before proceed to any of your initialisation process.
    look at the a/d register setting(ADCON and others)... i'm sure that they're different from the PIC you used before.
    Feb 2005
    Bellevue
    Default hardware profile..
    The hardware is pretty skimpy.. I have the F88 a 5.1v supply, and a resistor from MCLR to power. I have only power and ground supplied, and then serial lines out from the appropriate port pins. No caps no nothing.
    Whats odd is that with small program.. like only a portion of the one I am porting over, it works. It wakes up, it does its routine, then it starts doing a simple read from data input, put data into array, and read data from array out to the three serial outputs. This works fine.
    Whats odd is when I put my WHOLE program in place, it chokes.. It periodically shows the data, but when it does the math is always wrong, and it looks to be resetting as I see the initialize routine results now and then.
    I don't know about ADCON as I am only doing serial data in on Port B1, and serial data out on B2 and also A0,A1. I am setting the serial data out on A1 to 4800b by using SERIN2, and the rest is 9600b. - But again, this seems to work fine with a smaller program...
    Must be some timing setting beyond what I've had to set before.
    TG
    so there's no analog to digital conversion on a.0 and a.1 ???
    you must disable those analog pins to make them digital.. at least
    ANSEL=3 'set a.0 and a.1 as digital input
    and capacitor should be consider.
    Feb 2005
    Bellevue
    Set the .. ANSEL=3 'set a.0 and a.1 as digital input, thx. Probably a good idea, but did not have any impact.
    Oddly as I test, I find that my setting for OSCAL 8 mhz or OSCAL 4 Mhz does not have any impact on the system..
    I have tried:
    OSCCON=%01101000 ' 4 mhz
    and in another test...
    DEFINE OSC 8
    OSCCON=%01111000 '8 Mhz
    Something must not be getting written somewhere. I'd expect that these settings would have a big impact on overall system operation.
    Is there some prescaler setting that I am missing?
    tg
    prescaller have nothing to do with your code if you're not using TIMERs. Can you post your code here or it's a 'military secret'
  1. 16F88 bootlader with Internal OSC
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 2nd August 2009, 11:15
  2. external clock / internal clock
    By grounded in forum General
    Last Post: - 31st May 2008, 18:44
  3. Setting up internal clock correctly?
    By JohnM in forum mel PIC BASIC Pro
    Last Post: - 18th March 2008, 21:29
  4. 16F688 Internal clock and MCLR
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 18th August 2007, 19:38
  5. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
