Interrupts on 18F4220
Results 1 to 3 of 3
    Jan 2007
    Unhappy Interrupts on 18F4220
    Thanks for any help on this--I am new to PICs but cut my teeth some on stamp things....
    I am having trouble getting a simple interrupt routine to run on an 18F4220. (I have some boards that we made earlier that I would like to reuse)
    I started by using a sippet of code from Chuck Hellebuyck (Nuts and Volts June 2006) and a PIC 16F877
    Circuit Stuff (on Protoboard)
    LED on Pin PORTB.1
    Switch on RB0
    ISP for programming
    My Version of his code
    LED1 Var PortB.1
    On Interrupt goto myint
    OPTION_REG = %00111111
    INTCON = %10010000
    loop:
    High LED1
    Pause 100
    Low LED1
    Pause 100
    Goto loop
    DISABLE
    myint:
    Low LED1
    Pause 500
    INTCON.1=0
    Resume
    Enable
    This runs fine on the 16F877 , When I swap in the 18F4220 and change the code to :
    LED1 Var PortB.1
    INTCON2 = %00111111 '<---------change here
    INTCON = %10010000
    loop:
    High LED1
    Pause 100
    Low LED1
    Pause 100
    Goto loop
    DISABLE
    myint:
    Low LED1
    Pause 500
    INTCON.1=0
    Resume
    Enable
    I never get the interrupt routine to run.
    Any Ideas?
    PORTB have some analog stuff multiplexed with..
    you need to add
    ADCON1=$0F
    at the top of your code to disable ADCs.
    BUT you could also edit the config fuses as well.
    Jan 2007
    Smile Interrupts on 18F4220
    Thanks!!!!
    I made the changes this morning and the 18F4220 is getting the interrupt.
    Thanks for the pointer. I am still learning about the config bits and often forget to look at them.
    I still have a little clock speed issue, but I think that is probably config bits also.....
    Thanks again.
  1. Continuous Interrupts when using DT_INTS and an INCLUDE file
    Last Post: - 15th January 2010, 22:42
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  3. Microcode studio - PIC16F877A Interrupts
    By mcbeasleyjr in forum mel PIC BASIC Pro
    Last Post: - 8th January 2009, 07:10
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 16:10
