JDM type Programmer + WinPic800 (or whatever)
Results 1 to 28 of 28
    Pickit is still growing with the age. It's working pretty good for me when i use it on the road. And it's a Microchip product... yeah the same doing the PIC... so they 'should' know how to program their PIC the right way now after some PICSTART disasters
    To push their product ALL microcontroller brand release cheap development kit now. Ti do one for 20$ with a little board in... I do remind one article in Electronic Design magazine talking about that.
    Pickit support few device for ICD... really a few... for now. but if you're like me and NEVER use any ICD... it's not a problem.
    35$ and it's USB.... how on earth you can build one yourself for this price if you include your time in?
    And guess what... they include the programmer schematic and the USB bootloader source code in the package... ok there's 2 bugs in the config fuses but.. easy to change even if you don't know C language.
    The only ICD I have is a basic serial LCD connected to a spare pin using DEBUG and 2 buttons on 2 other spare pins...that's 'In Circuit', and it is 'Debugging' !
    What's the deal on the config fuse bugs? Any links for the fix?
    euh... mmm i explain it bad... the config fuses setting are bad in the Pickit 2 bootloader firmware C code ONLY, the whole thing work really great.
    So why i know the config fuses are bad? LMAO! i allow everybody to laugh here....
    When i wanted to update the Pickit firmware, i choose a bad Hex code (probably a compiled program or else i don't want to remind) so i screw the Pickit 2. He was totally dead, no more USB connection etc etc etc.
    So i surfed the provided CD, and discovered they shipped the source code for it... but not the compiled .Hex file. So i just open the Bootloader project and recompile it with C18 to have the .Hex to be able to dump it in via the dedicated ICSP point on the Pickit pcb. Got compilation error... Discovered it was something around the BOV config fuses and another one wich i don't remind. I just corrected them using the newer syntax and VOILA! no more compilation error and be able to dump the .HEX in the Pickit with my favourite BK844a programmer. I think i kept the .Hex somewhere.
    Unless you do the same stupid thing as i did, you won't need it.
    That's what not enough sleeping do!
    Good moves
    I just checked Microchip's site and discovered that they are out of stock. Well, I want one now....so I'm ordering 2 of the PG164120 PICKIT2's from Digikey at the same price, along with a half a dozen '4550's (thanks mister_e) and some ADXL330's. Good fun...good times.
    If you say the PICKIT2 is good, then that's what I'll get and give to that friend of mine.
  1. JDM programmer
    By phoenix_1 in forum Schematics
    Last Post: - 10th December 2007, 12:29
  2. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 21:14
  3. JDM type programmer problem...
    By bearpawz in forum General
    Last Post: - 17th January 2007, 12:24
  4. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 16th August 2006, 00:47
  5. General Programmer Questions
    By mslaney in forum General
    Last Post: - 17th December 2004, 19:16
