my code, create by easyhid
i tryied cristal 20mhz or 8mhz and "device not recognised",Code:DEFINE OSC 48 DEFINE LOADER_USED 1 USBBufferSizeMax con 8 ' maximum buffer size USBBufferSizeTX con 8 ' input USBBufferSizeRX con 8 ' output ' the USB buffer... USBBuffer Var Byte[USBBufferSizeMax] USBBufferCount Var Byte ' ************************************************************ ' * main program loop - remember, you must keep the USB * ' * connection alive with a call to USBService every couple * ' * of milliseconds or so... * ' ************************************************************ usbinit ' initialise USB... ProgramStart: gosub DoUSBIn gosub DoUSBOut goto ProgramStart ' ************************************************************ ' * receive data from the USB bus * ' ************************************************************ DoUSBIn: USBBufferCount = USBBufferSizeRX ' RX buffer size USBService ' keep connection alive USBIn 1, USBBuffer, USBBufferCount, DoUSBIn ' read data, if available return ' ************************************************************ ' * wait for USB interface to attach * ' ************************************************************ DoUSBOut: USBBufferCount = USBBufferSizeTX ' TX buffer size USBService ' keep connection alive USBOut 1, USBBuffer, USBBufferCount, DoUSBOut ' if bus available, transmit data return
with 48 not detect
i tested demo program usbcdc and too "device not recognised".
					 usb - device not recognised
