Adcin or Pot
Results 1 to 19 of 19
Thread: Adcin or Pot
    malc-c's Avatar
    malc-c Guest
    OK I've just had a further look at the manual, and there was no connection of the second leg to the +ve, however disconnecting the link between the +5v and the pot resulted in the value of D (in the above example) to 1 regardless of where the pot was set. Reconnecting the leg of the POT to +ve and the value changed back to 255 !
    Looking at the manual it states
    The resistance is measured by timing the discharge of a capacitor through the resistor (typically 5K to 50K). Scale is used to adjust for varying RC constants. For larger RC constants, Scale should be set low (a minimum value of one). For smaller RC constants, Scale should be set to its maximum value (255). If Scale is set correctly, Var should be zero near minimum resistance and 255 near maximum resistance.
    Unfortunately, Scale must be determined experimentally. To do so, set the device under measure to maximum resistance and read it with Scale set to 127. Adjust Scale until the Pot command returns 254. If 255, decrease the scale. If 253 or lower, increase the scale.
    Whats happening here is that your not measuring the voltage and then converting that analogue voltage into a digital value as per A to D convertion. The resistor charges the capacitor, which then discharges, which results in a negative going pulse on the pin. The frequency of this pulse determins the value of being stored in the variable (D in my example above). Here are some traces showing the pulse rate when D was 0, around 20 and at 255.
    Sep 2006
    I am not using A/D yu are right, but it still do not work , maybe i should use the A/D and change the reference voltage
    Ok i juste tried A/D works good
    Pot sucks..
    Je te l'avais dit
    I told you!
    Sep 2006
    oui je sais caline..
    Quote Originally Posted by lerameur View Post
    I didn't know the specie-that-grows-but-never-reproduces had haunted this forum ... LOL
    Being serious ... FORGET the "POT" Command ... and use RCTime instead !!!
    ADC not really compulsory for numerous applications.
    Alaain
  1. Using the Pot command.
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 17th August 2009, 21:23
  2. A/D, Pot, Input, A,B So lost now....
    By Helmutt in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 23:23
  3. Replies: 4
    Last Post: - 24th January 2007, 23:20
  4. Using ADCIN or POT/RCTIME?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 16th April 2006, 19:37
  5. pot controlled pwm -- help
    Last Post: - 29th January 2006, 13:29
