JDM type programmer problem...
Results 1 to 15 of 15
    Quote Originally Posted by bearpawz View Post
    Ok, I think I found my problem so posting it here in case anyone else ever needs it...
    I guess there is an issue when you try to use this programmer after programming the config to use Internal Oscilater and no MCLR... (Both of which apply to me).
    From what I found on the internet the programmer its self applies constant power to pic, so once you flash it the first time with those settings, it will just run and wont will not program.
    So anyone know a down and dirty cheap way to "erase" the pic back to default?
    Im using 16F818 BTW
    PGM pin pulled down (or up?), don't remember which? Shouldn't matter using HV on MCLR, but you never know.
    Ok, well its very clear now that this JDM programmer just is not going to erase a chip with my configuration. For the record it has no power supply... just runs off the serial port and there is some issue with it running code before the programmer can get to it so...
    Instead of trying to build a whole new programmer... I would like to just sacrifice maybe one of my chips to build a down and dirty simple "bulk eraser". My thoughts are this:
    Use one pin for a push button to start the whole procedure...
    Once button is pushed it will activate a transistor to bring MCLR high and initiate programming mode all from the one PIC chip. So one transistor would be the only other component... the rest would just be using PIC to PIC pinout...
    So now my question is... does anyone know the exact specification for bulk erasing a pic?
    If you're thinking the JDM programmer is having issues with power, why not cut the trace to the power pins and add your own power?
    As far as making your own bulk eraser...each different family of PICs has it's own method of talking when doing programming/erasing. So unless you are only going to use one family of PICs...ever, I don't think it's worth the time.
    Why not go to Microchip's website and check out the PICKIT2? USB, upgradable, $35USD, and a good deal at that. Actually, Microchip is out of stock, but Digikey has a load of them at the same price. I've got it on good authority (thanks to mister_e) that these PICKIT2's are good programmers and I'm going to buy 2 of them very soon. My old Warp13a is over 8 years old...good programmer, but I want a new one.
    Mar 2006
    Hyderabad (India)
    Hi Bearpawz,
    if you are using a new PC with low voltage working, the VPP is an issue. as you are not using an external power supply, try to check out what are the measured values of Vcc and VPP by suitably inverting the concerned pins theo winpic800 program. if the pin4 doen't get 13V or little above programming doent take place. also the dellay could be set to 20 instead of 10 or 15. If the eBay has provided the schematic, try to to put it on the post and it will help us disgonose what is really happening-- in all probabilities, low voltages or noice on these voltages is the reason.
    eg., one maunufacturer has used MC34063A to derive Vpp from the Vcc obtined from the COM port. if you have only a charged cap as Vpp supply and the PC is of low votage(modern), then you may have to improvise it. afterall prchasing another will not assue trouble free-- we have to study and sort out the issue.
    Incidentally if the programmer that you got is of FENG3 ver5.2 rev8
    the designer clearly says not to connect the PC's ground to the programmer ground. please check that. if you want you can see the scmatic of FENG3 at http://hamradioindia.org/circuits/feng.php#mods
    please inform developments--
    Sarma
    Well, the reason Im not entertaining purchasing another programmer is because Ive got a non existant budget right now. not for at least a few weeks... just started a new job after several months of unemployment...
    Anyway, Here is the issue with the programmer:
    Its constantly applying the +5 and ground, so once I have code in there that uses the internal oscilator it begins to run the code BEFORE the high voltage reaches the MCLR pin to enter programming mode. Here is what I have found with my meter hooked up in place of a pic...
    When not trying to program:
    VDD (pin 14) = ±5V
    VSS (Pin 5) = 0V
    MCLR (pin 4) = ±0V
    Once I fire up programmer:
    VDD = ±5V
    VSS = ±0V
    MCLR = ±13V
    Default break the connection
    Mr. bearpawz,
    I do not know if you are looking for a long term solution, but why not sever the connection to the 5v terminal amd add a 5v regulator driven off the 13v line, would that work for you?
    Mar 2006
    Hyderabad (India)
    VDD (pin 14) = ±5V
    VSS (Pin 5) = 0V
    MCLR (pin 4) = ±0V
    VDD = ±5V
    VSS = ±0V
    MCLR = ±13V
    Oh!
    fine readings Bearpawz,
    i beleive a principle ,that one shold not purchase an nitem just cauz he /she has money-- we can use it for other purposes. likewise when we can use our knowledge and debug the faulty situation, why not -- every issue is an oppertunity from where we can gain experience. thus, you are right not to prchase-- even if you were in continuous emplyment. afterall there are thousands of users working on JDM versions.
    coming to the point, can you post the schematic of your prog if your user manual has it? otherwise a dirct photo of the equipmrnt in .jpg form. it will help us to sort out the issue
    Sarma
    malc-c's Avatar
    malc-c Guest
    This is a common problem with some verions of the JDM programmer. There is a fix that is shown below.
    Full details of this modification can be found at http://users.tpg.com.au/btkelly/jdm_b.htm
    Another version can be found at http://www.janson-soft.de/pic/pic.htm
    I use a commercial version of the JDM programmer from Olimex
    which is based on the following schematic
    Hope this helps
    here is a picture of the programmer.. At least I think.. not quite sure how to insert a picture into this here message board so its attached...
    It also seems that after playing around with the settings in IC-PROG I got it to work again. It seems like as long as I dont have to reboot Im ok. Just a couple of chips will not erase and they are probably blown or something.
    While this is true, my parallel port based EPIC compatible has only 4 wires of ICSP (Gnd, Vpp, clock and data). So, when you connect it to a pic on a breadboard, the pic is constantly getting +5 volts from the target supply and the programmer has no way of controlling it. And yet, even with the internal osc. and MCLR disabled, a 12F6XX has no problems getting programmed over and over again.
    I wonder how this can be explained?
    Anand
    Mar 2006
    Hyderabad (India)
    [QUOTE=ardhuru; While this is true, my parallel port based EPIC compatible has only 4 wires of ICSP (Gnd, Vpp, clock and data). So, when you connect it to a pic on a breadboard, the pic is constantly getting +5 volts from the target supply and the programmer has no way of controlling it. And yet, even with the internal osc. and MCLR disabled, a 12F6XX has no problems getting programmed over and over again.
    Anand[/QUOTE]
    Hi Anand, EPIC and parallel port type you said. any circuit diagram for further discussion . or site where i could read a schematic please?
    Sarma
  1. JDM type Programmer + WinPic800 (or whatever)
    By skimask in forum Schematics
    Last Post: - 10th December 2007, 12:12
  2. JDM programmer
    By phoenix_1 in forum Schematics
    Last Post: - 10th December 2007, 11:29
  3. USB programmer problem 18LF4620
    Last Post: - 8th November 2007, 02:03
  4. melabs usb programmer problem
    By bigbear in forum General
    Last Post: - 28th December 2006, 12:50
  5. EPIC PLUS programmer (problem)
    By pakbasic in forum General
    Last Post: - 17th May 2005, 19:28
