Sound high likely an ICSP problem. Which programmer & Software?
Did you tried on a Ziff socket? Are your sure your ICSP circuit is properly implemented?
I am using an epic plus programmer ver.4.22 and picbasicpro ver 2.50. I have a homemade programming adapter. I can read the blank chip "all 0fff" and the calibration register. I can load the hex file that I just read but can not load the hex files I create. I have no problem with other micros, however this is the only micro I just this program adapter with?
Thank you for your help!
I believe this is correct for the epic programmer?
What about the code you are trying to load?
@ DEVICE PIC10F202,INTRC_OSC
@ DEVICE PIC10F202,MCLR_OFF
@ DEVICE PIC10F202,PROTECT_OFF
@ DEVICE PIC10F202,WDT_OFF
BEGIN:
high GPIO.0
low GPIO.0
GoTo BEGIN
@ device pic10f202,mclre_off
Could be a missing "e" ???
_MCLRE_ON EQU H'0FFF'
_MCLRE_OFF EQU H'0FEF'
_CP_ON EQU H'0FF7'
_CP_OFF EQU H'0FFF'
_WDT_ON EQU H'0FFF'
_WDT_OFF EQU H'0FFB'
_IntRC_OSC EQU H'0FFF'
Are the config options when using MPASM. PM might be different...
