GP2 on a 10F202 as output
Results 1 to 15 of 15
    Mar 2008
    Cool 10f202
    I can not seem to program a 10f202 I always get "programming error at 0000" however if I read it I can write the info back to the chip?
    Quote Originally Posted by n0yox View Post
    Code?
    What are you reading from the chip ?
    Sound high likely an ICSP problem. Which programmer & Software?
    Did you tried on a Ziff socket? Are your sure your ICSP circuit is properly implemented?
    Mar 2008
    Cool 10f202
    I am using an epic plus programmer ver.4.22 and picbasicpro ver 2.50. I have a homemade programming adapter. I can read the blank chip "all 0fff" and the calibration register. I can load the hex file that I just read but can not load the hex files I create. I have no problem with other micros, however this is the only micro I just this program adapter with?
    Thank you for your help!
    Mar 2008
    Default program adapter
    I believe this is correct for the epic programmer?
    What about the code you are trying to load?
    Mar 2008
    Default blinky code
    @ DEVICE PIC10F202,INTRC_OSC
    @ DEVICE PIC10F202,MCLR_OFF
    @ DEVICE PIC10F202,PROTECT_OFF
    @ DEVICE PIC10F202,WDT_OFF
    BEGIN:
    high GPIO.0
    low GPIO.0
    GoTo BEGIN
  1. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 03:30
  2. Bit Banging input to output on PIC16F876A
    By Bronurstomp in forum mel PIC BASIC Pro
    Last Post: - 26th June 2008, 20:50
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 15:44
