Instant Interrupts and STRINGS-16.PBP in the same program
Results 1 to 11 of 11
    Dec 2003
    Storrs, Ct.
    Default Sorry, wrong version.
    Here's the right one.
    <code>
    DEFINE LOADER_USED 1 ' If using bootloader
    DEFINE OSC 20
    DEFINE HSER_RCSTA 90h 'setup receive register
    DEFINE HSER_TXSTA 20h 'setup transmit register
    DEFINE HSER_BAUD 38400 'setup baud rate
    'INCLUDE "DT_INTS-18.inc" ' Base Interrupt System
    'INCLUDE "ReEnterPBP-18.inc" ' Include if using PBP interrupts
    Addr var word
    Char var byte
    led1 var PORTC.0 'heartbeat LED
    Clear
    INT_Handler TMR1_INT, _ToggleLED1, PBP, yes
    T1CON = $31 ; Prescaler = 8, TMR1ON
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    goto StartLoop ' Required
    String1:
    @ da "This is a string",0
    AnotherString:
    @ da "Here is another string",0
    '------------GetAddress Macro - Location insensitive -------------------------
    GetAddress macro Label, Wout ; Returns the Address of a Label as a Word
    CHK?RP Wout
    movlw low Label
    movwf Wout
    movlw High Label
    movwf Wout + 1
    StartLoop ' This loop repeats continuously just as a test.
    @ GetAddress _String1, _Addr ' Get address of String
    gosub StringOut ' Send the String
    hserout [13,10] ' New Line
    @ GetAddress _AnotherString, _Addr ' Get address of String
    goto StartLoop ' Repeat
    StringOut: ' Send the string out via Hserout
    Readcode Addr, Char ' Get a character
    if Char = 0 then StringDone ' Look for Null char, Stop if found
    hserout [Char] ' Send char
    Addr = Addr + 1 ' Point to next character
    goto StringOut ' Continue with rest of the string
    StringDone:
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
    TOGGLE LED1
    @ INT_RETURN
    </code>
    "It will never happen here!" just happened here.
    My thoughts and prayers for Sandy Hook victims and families.
    Oh, that helps even more.
    There is a conflict between the two programs.
    DT_INTS also has a GetAddress macro.
    So you can just delete the GetAddress macro in the main program.
    Don't forget to un-comment the include files.
    Dec 2003
    Storrs, Ct.
    Default Success!
    As always Darryl, you are "THE MAN".
    Thanks alot...
    Dec 2003
    Storrs, Ct.
    Default Success!
    Thanks alot...
    Quote Originally Posted by ronjodu View Post
    See, now why can't "SHE" ever grasp that concept.
    But that's another story.
    Great! Hope the rest of the program works out too.
    L8R,
