Ah, that helps.
You haven't defined the Interrupts yet.
There needs to be a section that looks something like this...That section should be at the top of the program (but after the INCLUDE files), and don't jump over it. It needs to actually execute.Code:ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler INT_INT, _ToggleLED1, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE INT_INT ; enable external (INT0) interrupts
Then there also needs to be a handler routine...HTH,Code:'---[INT - interrupt handler]--------------------------------------------------- ToggleLED1: TOGGLE LED1 @ INT_RETURN
