Instant Interrupts and STRINGS-16.PBP in the same program
Results 1 to 11 of 11
    Dec 2003
    Storrs, Ct.
    Default Instant Interrupts and STRINGS-16.PBP in the same program
    Hello all! Hope everyone had a good Holiday. My question is, can I use Instant Interrupts DT_INTS-18, ReEnterPBP-18 and STRINGS-16 in the same program. I've tried a few times and get several errors.
    symbol not previously defined.(INT_ENTRY_H)
    Found call to Macro in column 1.(GetAddress)
    Duplicate Macro name. (GetAddress)
    1003:symbol not previously defined.(Label)
    1004:symbol not previously defined.(Wout)
    1005:symbol not previously defined.(Label)
    1006:symbol not previously defined.(Wout)
    1007:unmatched ENDM
    Instant Interrupts works great on it's own (blinks an LED) and STRINGS works great on it's own (Hello World and It's Me!) on an LCD, however combined I can't get it to compile without errors.
    MCSP 2.3, PBP 2.45A, MPASM, and Microcode Loader with an 18F2525 @ 20 MHZ
    As always thanks for any help in my up-hill battle thru this learning curve.
    "It will never happen here!" just happened here.
    My thoughts and prayers for Sandy Hook victims and families.
    As far as I know, they should work together.
    Those don't look like MPASM error messages, are you sure you have MPASM selected as the assembler?
    Dec 2003
    Storrs, Ct.
    Default MPASM checked.
    Yes, under "VIEW", Compile and Program Options, Assembler, a check mark in the Use MPASM box. As I said Darryl they work great on their own just not together. Probably operator error somewhere, I'm just not sure where.
    Thanks for your help.
    Can you post the code?
    I'll take a look and see what's up.
    Dec 2003
    Storrs, Ct.
    Default code
    <code>
    DEFINE LOADER_USED 1 ' If using bootloader
    DEFINE OSC 20
    DEFINE HSER_RCSTA 90h 'setup receive register
    DEFINE HSER_TXSTA 20h 'setup transmit register
    DEFINE HSER_BAUD 38400 'setup baud rate
    INCLUDE "DT_INTS-18.inc" ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.inc" ' Include if using PBP interrupts
    Addr var word
    Char var byte
    Clear
    goto StartLoop ' Required
    String1:
    @ da "This is a string",0
    AnotherString:
    @ da "Here is another string",0
    '------------GetAddress Macro - Location insensitive -------------------------
    GetAddress macro Label, Wout ; Returns the Address of a Label as a Word
    CHK?RP Wout
    movlw low Label
    movwf Wout
    movlw High Label
    movwf Wout + 1
    StartLoop ' This loop repeats continuously just as a test.
    @ GetAddress _String1, _Addr ' Get address of String
    gosub StringOut ' Send the String
    hserout [13,10] ' New Line
    @ GetAddress _AnotherString, _Addr ' Get address of String
    goto StartLoop ' Repeat
    StringOut: ' Send the string out via Hserout
    Readcode Addr, Char ' Get a character
    if Char = 0 then StringDone ' Look for Null char, Stop if found
    hserout [Char] ' Send char
    Addr = Addr + 1 ' Point to next character
    goto StringOut ' Continue with rest of the string
    StringDone:
    </code>
    Here it is. Out for dinner for an hour or so. I'll check back later. Thanks again.
    Ah, that helps.
    You haven't defined the Interrupts yet.
    There needs to be a section that looks something like this...
            INT_Handler    INT_INT,  _ToggleLED1,   PBP,  yes
    @   INT_ENABLE   INT_INT     ; enable external (INT0) interrupts
    That section should be at the top of the program (but after the INCLUDE files), and don't jump over it. It needs to actually execute.
    Then there also needs to be a handler routine...
    '---[INT - interrupt handler]---------------------------------------------------
    ToggleLED1:
         TOGGLE LED1
    @ INT_RETURN
    HTH,
