Speed of USB EasyHID and Time problem
Results 1 to 11 of 11
    Quote Originally Posted by sjohansson View Post
    Good idea, I will try that.
    How can I do that? I thought that's what CCP1IF does. Just triggering if ccp pin rising or falling. Right?
    Also another question; Is it best to turn On and Off the timer for each cycle or should it be On all the time and just reset the timer registers?
    Just a thought, and I know it's not the best thought...
    Since the hardware is giving you a bit of a problem, have you thought about using PBP's built-in Count and/or Pulsin commands? At 48mhz, you should have plenty of resolution to work with.
    Also, you might want to put an LCD of some sort on your PIC, so you can read the values before they get send over the USB to the PC. You might be sending bad numbers in the first place.
    For the problem-How about a variable that's declared as a byte variable that you might actually want as a word variable? (overflowing where you don't want it to, something like that)
    Hi Stefan,
    I've been looking at your program, and frankly I've got more questions than answers. But, I have found a few interesting things.
    First off, I can verify that the program completely "Wigs Out" when the pulses are faster than 125pps. This also seems to be the Limit for the number of HID reports per second. I've been working on a couple other USB programs and have seen the same number.
    An easy way to verify what's happening is to modify the DoUSBout like this...
    ' * wait for USB interface to attach                         *
    DoUSBOut:
       USBBufferCount = USBBufferSizeTX              ' TX buffer size
       USBService                                    ' keep connection alive
       USBOut 1, USBBuffer, USBBufferCount, OutBusy  ' if bus available, transmit data
    OutBusy:
      toggle PORTB.0         ' toggle led to show when USB is busy
    GOTO DoUSBOut
    Change the PORTB.0 to an LED on your board.
    Then you'll see that the "BAD" numbers received by the VB program, happen at the same time the LED starts blinking, due to a busy USB condition. (anything above 125hz)
    At this point I still don't understand what's going wrong, but I have found a possible way around it. By changing the DoUSBOut to this...
    ' * don't wait for USB interface to attach, abort if busy    *
    DoUSBOut:
    OutBusy:
    This will discard the current reading if the USB is busy, and go back and measure another pulse, (rinse and repeat).
    I've run it up to 500hz and it never "messes up".
    Of course, this won't be able to report every pulse to the VB program, Hopefully you don't need them all.
    HTH,
    Mar 2006
    Gothenburgh, Sweden
    Hi Darrel.
    Thanks for verifying the problem. Now I know that it is not just my program messing with me..
    But it's still confusing because when I use my Basic Stamp to simulate a signal, it works fine with 7ms High and 0ms low pulse. (BS code #3 in my first post.) This means that USBOut has enough time to execute even if the low pulse is only a few us. Can it be the vb app that is the bottleneck here?
    Pic send it quick but next time it try to send the pc is still busy with the last one. What do you think about that?
    If the pic is the bottleneck then I wonder how it can catch the next pulse without any problem? In that case it should be stuck in the DoUSBOut routine.
    I will make a test to measure 16 pulses, save all values in buffer(0) to buffer(31) and then send all 32byte to the pc. Sending 32 bytes takes 22.4us according to my tests so that should be just fine from the pic point of view. It will be interesting to se how the pc handle it.
    Unfortunatley I need to measure all pulses. I use the values in the vb app to calculate acceleration, rpm and total revs.
    My next task is to simultaneously check the USBIn for new data.
    This without halting the program. I have made some test with the code example from bruce at post:
    http://www.picbasic.co.uk/forum/show...05&postcount=3
    This seems to work but I have not test it at higher speed yet.
    Do you have any other good solutions to do this? Maybe using USB interrupt USBIF or something else?
    I'll let you know about my further test.
    Thanks again.
    Stefan.
    I was using a Delphi App, also created by EasyHID, and saw the same thing. So I doubt it's anything to do on the PC side.
    As long as the frequency is less than 125hz, it never get's a BUSY response. But, once it goes above that, it does get "stuck in the DoUSBOut routine".
    This becomes evident if you try the first example in Post#8.
    I guess it depends on the highest frequency you'll need to measure, but you may not need to go that high. For say 10,000 RPM, you'll only need about 166 samples per second (Unless there are multiple pulses per rev). So if you capture 2 samples per report, you'll only need 83 reports per second, which should be well within the limits, and give a faster "Update Rate".
    Well, there's this ...
    Instant Interrupts - Revisited, post 148
    http://www.picbasic.co.uk/forum/show...0682#post30682
    Which works with this ...
    USBDemo, something to learn USB a little bit
    http://www.picbasic.co.uk/forum/showthread.php?t=5418
    Mar 2006
    Gothenburgh, Sweden
    Thanks Darrel.
    Fels like I'm on the right track again.
    I made some tests with USBIn today and it seems to work.
    I call DoUSBIn directly after the DoUSBOut so it has time enough to transmit before the next high pulse trig the ccp input.
    And if the drum is not rotating DoUSBIn is called by interval using Timer3.
    Stefan.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Replies: 14
    Last Post: - 31st March 2009, 13:04
  3. USB 18F4550 in High or full speed???
    By Jonathan Orrego in forum USB
    Last Post: - 16th July 2008, 17:13
  4. Need Help with USB using PIC18F2455
    By iugmoh in forum USB
    Last Post: - 15th April 2008, 18:07
  5. Time to transfer data in EasyHID
    By Demon in forum USB
    Last Post: - 22nd August 2006, 17:06
