Just a thought, and I know it's not the best thought...
Since the hardware is giving you a bit of a problem, have you thought about using PBP's built-in Count and/or Pulsin commands? At 48mhz, you should have plenty of resolution to work with.
Also, you might want to put an LCD of some sort on your PIC, so you can read the values before they get send over the USB to the PC. You might be sending bad numbers in the first place.
For the problem-How about a variable that's declared as a byte variable that you might actually want as a word variable? (overflowing where you don't want it to, something like that)
