Ping Darrel Taylor - Timer0 Instant Interrupt
Results 1 to 5 of 5
    Nov 2004
    Default Ping Darrel Taylor - Timer0 Instant Interrupt
    (Instant Interrupt Timer0 Question)
    Hi Darrel,
    I just downloaded a fresh copy of the DT_INTS-14 and ReEnterPBP files from your website and intalled them in a new directory, along with my program file.
    I have PBP 2.46 and the newest version of MPASM (5.03) running inside MicroCode Studio.
    My target processor is a 16F88 @ 20 MHz.
    I'm attempting to use a TMR0 interrupt.
    The relevant PBP code looks like this:
    INT_Handler TMR0_INT, _ClockCount, PBP, yes
    INT_ENABLE TMR0_INT
    When I compile, PBP tells me that T0IF can't be found and the program won't compile.
    So I opened up the MPASM's .inc file for the 16F88 and discovered that T0IF and T0IE aren't mentioned anywhere. Rather, it's TMR0IF and TMR0IE.
    So I made these two changes to the DT-INTS-14.bas file:
    ifdef T0IF ;----{ TMR0 Overflow Interrupt }-------------[INTCON, TMR0IF]---
    ;INT_Source INTCON, T0IF, INTCON, T0IE
    INT_Source INTCON, TMR0IF, INTCON, TMR0IE
    ;#define TMR0_INT INTCON,T0IF ;-- TMR0 Overflow Interrupt 16F
    #define TMR0_INT INTCON,TMR0IF ;-- TMR0 Overflow Interrupt 16F
    And now I get the error 'Interrupt source INTCON, TMR0IF not found.'
    I've checked to make sure that zeros are used instead of the letter 'O' everywhere.
    The errors are the same using a pervious version of MPASM - 3.90 I think.
    Any ideas?
    John
    See post #141 in this thread:
    http://www.picbasic.co.uk/forum/show...ant+interrupts
    /Henrik Olsson.
    Nov 2004
    Thanks - that fixed the problem and I'm able to compile.
    By the way, what's up with entering a CAPTCHA when searching the forum these days?
    Jul 2006
    Default desable the interrupt?
    Hello Darrel
    the line
    @ INT_ENABLE INT_INT ; enable external (INT) interrupts
    and how can i desable the interrupt?
    Pedro
    Darrel will most definetly correct me if I'm wrong but I think you do:
    @INT_DISABLE   INT_INT
    /Henrik Olsson.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. darrel taylor's instant interrupt compiler error
    By delta_boogie in forum mel PIC BASIC Pro
    Last Post: - 20th October 2009, 19:07
  3. DT Instant Interrupt counting
    By jderson in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 22:47
  4. Usart with Darrel Instant Interrupt
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 17th February 2008, 00:09
  5. Replies: 1
    Last Post: - 2nd November 2006, 23:24
