Big characters on HD44780 4x20
Results 1 to 24 of 24
    Jan 2007
    Will people stopping using 16F84A one day? LOL!
    Anyways, do you mind if i try to do the code for the 16F877A right now as you'll end up using this one anyway?
    I'm only using it because it's the test pic! I've flashed it at least 500 times!
    This is a little bit smaller code:
    DEFINE OSC 12
    define LCD_LINES 4
    Clr     CON 1
    Comm    Con $FE
    LINE1   con 2
    LINE2   con $c0
    LINE3   con $94
    LINE4   con $d4
    Dx      con $14
    Begin:
            Pause 500
      LCDOUT  $FE,$40,$1F,$1F,$1F,$1F,$1F,$1F,$1F,$1F  ' Cust Char #0
      LCDOUT  $FE,$48,$1F,$1F,$1F,$1F,$00,$00,$00,$00  ' Cust Char #1
      LCDOUT  $FE,$50,$00,$00,$00,$00,$1F,$1F,$1F,$1F  ' Cust Char #2
      LCDOUT  $FE,$58,$00,$00,$00,$0E,$1F,$1F,$1F,$0E  ' Cust Char #3
      LCDOUT  $FE,$60,$00,$00,$00,$00,$00,$1F,$1F,$1F  ' Cust Char #4
      LCDOUT  $FE,$68,$1F,$1F,$1F,$00,$00,$00,$00,$00  ' Cust Char #5
      LCDOUT  $FE,$70,$00,$01,$03,$07,$0F,$1F,$1F,$1F  ' Cust Char #6
      LCDOUT  $FE,$78,$00,$00,$00,$00,$00,$00,$01,$03  ' Cust Char #7
            LCDOUT comm, clr
            lcdout comm, line1, "T", COMM, LINE2, "E", COMM, LINE3, "S", COMM, LINE4, "T"
            PAUSE 1000
            GOSUB NUMERO11
            PAUSE 1000
            GOSUB NUMERO22
            PAUSE 1000
            GOSUB NUMERO33
            gosub punto3
            gosub numero44
            PAUSE 3000
            GOTO MAIN
    Numero11:
            lcdout comm, $82, $07, $06, $00
            lcdout comm, $C4, $00
            lcdout comm, $98, $00
            lcdout comm, $D8, $00
    Numero22:
            LCDOUT comm, $86, $01, $01, $01, $00
            LCDOUT comm, $C6, $02, $02, $02, $00
            LCDOUT comm, $9A, $00, $01, $01, $01
            LCDOUT comm, $DA, $00, $02, $02, $02
    Numero33:
            LCDOUT comm, $8B, $01, $01, $01, $00
            LCDOUT comm, $CC, $04, $04, $00
            LCDOUT comm, $A0, $05, $05, $00
            LCDOUT comm, $DF, $02, $02, $02, $00
    Punto3:
            LCDOUT Comm, $E3, $03
    Numero44:
            lcdout comm, $90, $00
            lcdout COMM, $D0, $00, COMM, $D3, $00
            lcdout COmm, $A4, $01, $01, $01, $00
            lcdout comm, $E7, $00
    But of course it's not what I want!
    OK then i'll try with my favourite 16F84A
    OK everybody, the code shrinking competition start RIGHT NOW!
    Doh! i miss this line...
    So what do you want? smaller only ?
    Jan 2007
    Simply better! I'm working on it, in about 1 hour I will post the result!
    Maybe not FAR BETTER but interesting...
    Clr     CON 1
    Comm    Con $FE
    LINE1   con $80  ;2
    LINE2   con $c0
    LINE3   con $94
    LINE4   con $d4
    Dx      con $14
    offset  var byte
    Begin:
            Pause 500
            LCDOUT  $FE,$58,$00,$00,$00,$00,$00,$0E,$0E,$0E  ' Cust Char #3
            offset=0
            LCDOUT comm, clr
            lcdout comm, line1, "T", _
                   COMM, LINE2, "E", _
                   COMM, LINE3, "S", _
                   COMM, LINE4, "T"
            offset=2
            PAUSE 1000
            GOSUB NUMERO2
            PAUSE 1000
            GOSUB NUMERO1
            PAUSE 1000
            GOSUB NUMERO3
            PAUSE 2000
            GOTO MAIN
    Numero1:
            LCDOUT COMM,LINE1+offset,7,6,0,_
                   COMM,LINE2+offset+2,0,_
                   COMM,LINE3+offset+2,0,_
                   COMM,LINE4+offset+2,0
            offset=offset+4
    Numero2:
            LCDOUT COMM,(LINE1+offset),1,1,1,0,_
                   COMM,(LINE2+offset),2,2,2,0,_
                   COMM,(LINE3+offset),0,1,1,1,_
                   COMM,(LINE4+offset),0,2,2,2
            offset=offset+5
    Numero3:
            LCDOUT COMM,LINE1+offset,1,1,1,0,_
                   COMM,LINE2+offset+1, 4, 4, 0,_
                   COMM,LINE3+offset+1, 5, 5, 0,_
                   COMM,LINE4+offset,$02, $02, $02, $00
            offset=offset+5
    I'm still working on something...
    Jan 2007
    I think this is quite good:
    DEFINE OSC 12
    define LCD_LINES 4
    Clr     CON 1
    Comm    Con $FE
    LINE1   con 2
    LINE2   con $c0
    LINE3   con $94
    LINE4   con $d4
    Offset  VAR BYTE
    Begin:
            Pause 500
      LCDOUT  254,64,31,31,31,31,0,0,0,0       ' Cust Char #0
      LCDOUT  254,72,0,0,0,0,31,31,31,31       ' Cust Char #1
      LCDOUT  254,80,31,31,31,15,7,3,1,0       ' Cust Char #2
      LCDOUT  254,88,31,31,31,30,28,24,16,0    ' Cust Char #3
      LCDOUT  254,96,0,16,24,28,30,31,31,31    ' Cust Char #4
      LCDOUT  254,104,0,1,3,7,15,31,31,31      ' Cust Char #5
      LCDOUT  254,112,31,31,31,31,31,31,31,31  ' Cust Char #6
      LCDOUT  254,120,0,0,0,14,31,31,31,14     ' Cust Char #7
            LCDOUT comm, clr
            OFFSET=0
            gOSUB NUMERO0
            OFFSET=5
            GOSUB NUMERO1
            OFFSET=10
            GOSUB NUMERO2
            OFFSET=15
            GOSUB NUMERO3
            PAUSE 9000
            LCDOUT COMM, CLR
            OFFSET=0
            GOSUB NUMERO4
            OFFSET=5
            GOSUB NUMERO5
            OFFSET=10
            GOSUB NUMERO6
            OFFSET=15
            GOSUB NUMERO7
            PAUSE 9000
            LCDOUT COMM, CLR
            OFFSET=0
            GOSUB NUMERO8
            OFFSET=5
            GOSUB NUMERO9
            OFFSET=5
            GOSUB PUNTO
            OFFSET=10
            GOSUB NUMERO0
            PAUSE 9000
            GOTO MAIN
    Punto:
            LCDOUT Comm, ($D9 + OFFSET), $07
    Numero0:
            LCDOUT COMM, ($81 + OFFSET), $05, $FF, $FF, $04
            LCDOUT COMM, ($C1 + OFFSET), $FF, COMM, ($C4 + OFFSET), $FF
            LCDOUT COMM, ($95 + OFFSET), $FF, COMM, ($98 + OFFSET), $FF
            LCDOUT COMM, ($D5 + OFFSET), $02, $FF, $FF, $03
    Numero1:
            lcdout comm, ($82 + OFFSET), $05, $FF
            lcdout comm, ($C3 + OFFSET), $FF
            lcdout comm, ($97 + OFFSET), $FF
            lcdout comm, ($D7 + OFFSET), $FF
    Numero2:
            LCDOUT comm, ($81 + OFFSET), $00, $00, $00, $04
            LCDOUT comm, ($C4 + OFFSET), $FF
            LCDOUT comm, ($95 + OFFSET), $05, $00, $00, $00
            LCDOUT comm, ($D5 + OFFSET), $FF, $01, $01, $01
    Numero3:
            LCDOUT comm, ($C2 + OFFSET), $01, $01, $FF
            LCDOUT comm, ($96 + OFFSET), $00, $00, $FF
            LCDOUT comm, ($D5 + OFFSET), $01, $01, $01, $03
    Numero4:
            lcdout comm, ($81 + OFFSET), $FF
            lcdout COMM, ($C1 + OFFSET), $FF, COMM, ($C4 + OFFSET), $FF
            lcdout COmm, ($95 + OFFSET), $00, $00, $00, $FF
            lcdout comm, ($D8 + OFFSET), $FF
    Numero5:
            LCDOUT COMM, ($81 + OFFSET), $05, $00, $00, $00
            LCDOUT COMM, ($95 + OFFSET), $00, $00, $00, $04
            LCDOUT COMM, ($D5 + OFFSET), $01, $01, $01, $03
    Numero6:
            LCDOUT COMM, ($95 + OFFSET), $FF, $00, $00, $04
            LCDOUT COMM, ($D5 + OFFSET), $02, $01, $01, $03
    Numero7:
            LCDOUT COMM, ($81 + OFFSET), $00, $00, $00, $FF
            LCDOUT COMM, ($C3 + OFFSET), $01, $FF
            LCDOUT COMM, ($97 + OFFSET), $00, $FF
            LCDOUT COMM, ($D8 + OFFSET), $FF
    Numero8:
            LCDOUT COMM, ($81 + OFFSET), $05, $00, $00, $04
            LCDOUT COMM, ($C1 + OFFSET), $02, $01, $01, $03
            LCDOUT COMM, ($95 + OFFSET), $05, $00, $00, $04
    Numero9:
            LCDOUT COMM, ($C1 + OFFSET), $02, $01, $01, $FF
            LCDOUT COMM, ($98 + OFFSET), $FF
            LCDOUT COMM, ($D6 + OFFSET), $01, $01, $03
    It's "only" 1002 words and about 900 words w/o the little "show" in Main.
    Quote Originally Posted by erpalma View Post
    DEFINE OSC 12
    define LCD_LINES 4
    Clr     CON 1
    Comm    Con $FE
    LINE1   con 2
    LINE2   con $c0
    LINE3   con $94
    LINE4   con $d4
    Offset  VAR BYTE
    Begin:
            Pause 500
            LCDOUT comm, clr
            OFFSET=0 : gOSUB NUMERO0
            OFFSET=5 : GOSUB NUMERO1
            OFFSET=10 : GOSUB NUMERO2
            OFFSET=15 : GOSUB NUMERO3
            PAUSE 9000 : LCDOUT COMM, CLR
            OFFSET=0 : GOSUB NUMERO4
            OFFSET=5 : GOSUB NUMERO5
            OFFSET=10 : GOSUB NUMERO6
            OFFSET=15 : GOSUB NUMERO7
            OFFSET=0 : GOSUB NUMERO8
            OFFSET=5 : GOSUB NUMERO9
            OFFSET=5 : GOSUB PUNTO
            OFFSET=10 : GOSUB NUMERO0
            PAUSE 9000 : GOTO MAIN
    Punto:
            LCDOUT Comm, ($D9 + OFFSET), $07 : return
    Numero0:
            GOSUB COMBO1
    Numero1:
    Numero2:
            GOSUB COMBO2
    Numero3:
            GOSUB COMBO2
            GOSUB COMBO3
    Numero4:
            GOSUB COMBO1
            GOSUB COMBO4
            GOSUB COMBO5
    Numero5:
            GOSUB COMBO6
            GOSUB COMBO4
            GOSUB COMBO3
    Numero6:
            GOSUB COMBO6
            GOSUB COMBO7
    Numero7:
            GOSUB COMBO2
            GOSUB COMBO5
    Numero8:
            GOSUB COMBO8
            GOSUB COMBO7
    Numero9:
            GOSUB COMBO8
            GOSUB COMBO5
    COMBO1:
    COMBO2:
    COMBO3:
    COMBO4:
            LCDOUT comm, ($95 + OFFSET), $00, $00, $00, $FF
    COMBO5:
            LCDOUT comm, ($D8 + OFFSET), $FF
    COMBO6:
    COMBO7:
    COMBO8:
    I combined a few of your lcdout statement into gosub's. See how much (if any) code space that saves/uses.
  1. Only the first 8 characters.
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 22nd September 2009, 02:43
  2. Big big big memory or tiny SDs!
    By Ron Marcus in forum Off Topic
    Last Post: - 25th May 2007, 19:02
  3. Led scrolling display: How to mirror characters?
    By mahia2005 in forum mel PIC BASIC Pro
    Last Post: - 11th May 2007, 04:25
  4. LCD 16 characters inline: only first 8 work
    By Mugel in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 23:07
  5. LCD 4x20 HD44780
    By inteco in forum mel PIC BASIC
    Last Post: - 27th June 2006, 17:52
