Port Values
Results 1 to 5 of 5
Thread: Port Values
    Default Port Values
    I have a simple Question,but I can not find a Answer.
    I have a Pic 16F870 And I want to use My PortC as High/Low,I now how to do this but can I do this like here:
    Data @1,3,6,12,9
    For Counter = 1 to 4
    Read Counter,State
    PortC = State
    Gosub DelayCheck
    Next Counter
    3 is PortC = %00000011 and 6 is PortC = %00000110 and so on.
    Can I do this.
    Thanks.
    Sure you can do this, but don't forget to set the TRISC register at the top of your code to configure your i/o as output.
    TRISC=0 ' configure all PORTC I/Os to output
    PORTC=%00001010 ' Write to PORTC
    Thanks Mister,
    I can use decimal numbers like here PortC=3 and this don't disturbe my Hserin Communication on PortC.?!
    Thanks.
    Mmm, interesting point, i've never think about it.
    A simple experimentation here reveal that it doesn't cause ANY problem as long as you did a HSEROUT before writing to PORTC. Once you did it, those RX and TX I/Os are dedicated to HSERIN/HSEROUT only.
    i tried...
        '    Pic Configuration
        @ __CONFIG _XT_OSC & _WDT_ON & _PWRTE_ON & _BODEN_ON & _LVP_OFF
             ' XT (4Mhz) oscillator
             ' Enable watch dog timer
             ' Enable power up timer
             ' Enable brown out detect
             ' Disable low voltage programming
        '    Hardware configuration
        TRISC=%10000000 ' PORTC.7 as input => USART RX,
                        ' Others as output
        '    Serial Communication definition
        DEFINE HSER_SPBRG 25  ' 9600 Baud @4MHz, 0.16%
        '    Variables definition
        CounterA    var byte
        '    Main program
        HSEROUT [0]
    Start:
        PORTC=%11111111
        PAUSE 500
        PORTC=0
        PAUSE 500
        GOTO START
    If you use it, you'll discover that nothing happen to PORTC.6 and PORTC.7... well they stay at their usual levels... High.
    Now a slight better test...
    Start:
        HSEROUT ["Send me data...",13,10]
        hserin [DEC Countera]
        PORTC=countera
        GOTO START
    Use MicroCode Serial Communicator to do you Tests... it still work
    Yes its Working!
    I forgot this TRISC=0 :-)
    Thanks Mister
  1. Change On Interrupt, PIC16F884
    By elec_mech in forum mel PIC BASIC Pro
    Last Post: - 14th November 2008, 18:25
  2. port config.
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 25th July 2008, 13:25
  3. Microcontroller with 2 way paging application problem
    Last Post: - 20th April 2007, 18:27
  4. 8 port Signal Loss Detector, possible to use a pic?
    By jamie_s in forum mel PIC BASIC Pro
    Last Post: - 20th March 2006, 16:59
  5. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 16:21
