Timer and long (hours) sleep period - how to?
Results 1 to 15 of 15
    SWITZERLAND (french speaking)
    Default Going to try TMR1
    Thanks a lot Skimask for your support.
    I'm going to try with TMR1.
    A little more power is maybe worth the precision gain.
    Thank you.
    Roger
    Thank you.
    You could add in a RTC chip, and wake up just a bit more often and compare the RTC's time with what you expected and adjust your nap/sleep time to get you really close to 15 minutes, or even use the RTC's alarm function (usually tied to a pin) to wake up the PIC at intervals. RTC chips use hardly any power except when awake and I'd suspect that adding an RTC would use much less power than adding another oscillator to a PIC.
    Hi Flotul. I've used a code similar to this in the past and found it to be accurate within 2 minutes per hour using the internal oscillator set to 4 MHZ. Also, I operated it at 3V (using an LF series PIC), current consumption was only 1/2 mA and runs a long time on 2AA alkaline batteries.
    x var word
    let x = 0
    start:
    let x = x + 1
    if x >= 900 then (15 minutes passed, do your measurement)
    goto start
    Default Yes - possible alternatives
    Thank you for your suggestions.
    Two minutes may look acceptable in some cases but if you have to record datas over days and weeks, it's is no more accurate enough.
    I'll have to make some tries but, as said by skimask, an RTC is maybe the best choice after all.
    Thanks again.
    Roger
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  2. High Resolution Timer & Speed Calculator
    By WOZZY-2010 in forum Code Examples
    Last Post: - 7th February 2010, 17:45
  3. Replies: 5
    Last Post: - 24th February 2009, 19:55
  4. long countdown timer, how to save power?
    Last Post: - 15th November 2008, 06:15
  5. Long Timer
    Last Post: - 1st November 2005, 18:24
