If you plan to use WRITECODE you should be aware that some series require you to erase a block at the time and then write a block at the time. The size of these blocks can be found in the datasheet for the PIC. ERASECODE will erase the entire block that the address you have pointed to is inside.
I just saw you said you wrote 4 words and that is not a good way later....
/me
