Presetting Configuration Fuses (PIC Defines) into your Program
+ Reply to Thread
Results 1 to 40 of 83
    Sep 2005
    delhi
    Default Warning[230]c:\...\..:__CONFIG has been deprecated for PIC1
    Quote Originally Posted by Tissy
    Thanks for that. I thought i was going mad !! Theres nothing worse than people saying it should work when it doesn't. You have save my insanity.
    I think the .CFG approach is a good solution.
    Many thanks,
    hi,
    i also facing similar problem if i try to compile programe on 18f452 i get the similar message like:
    Warning[230]c:\develo~1\susdco~1\rfusb~1.asm 67:__CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
    i am using pbp2.44 with mpasm7.21.
    I tried to rectify the problems with the above directives but fail should i go for the other version of mplab
    pl. help
    thanks
    Feb 2005
    Essex, UK
    Havin gtaken the .CFG route, Steve does yours come up with these errors?
    Warning[205] c:\pbp\sdcconfigfuse.cfg 1 : Found directive in column 1. (CONFIG)
    Warning[205] c:\pbp\sdcconfigfuse.cfg 2 : Found directive in column 1. (CONFIG)
    Warning[205] c:\pbp\sdcconfigfuse.cfg 3 : Found directive in column 1. (CONFIG)
    Warning[205] c:\pbp\sdcconfigfuse.cfg 4 : Found directive in column 1. (CONFIG)
    Warning[205] c:\pbp\sdcconfigfuse.cfg 5 : Found directive in column 1. (CONFIG)
    Could you post your .CFG file?
    Cheers
    The CFG file is the one i post few post before. You just need to Indent your CONFIG lines as i did.
    Feb 2005
    Essex, UK
    Yup, got that now, thanks.
    One fuse that doesn't work is
    BOREN = SBORDIS
    But the fuse settings in the .INC are
    ; Brown-out Reset:
    ; BOREN = OFF Disabled
    ; BOREN = ON SBOREN Enabled
    ; BOREN = NOSLP Enabled except Sleep, SBOREN Disabled
    ; BOREN = SBORDIS Enabled, SBOREN Disabled
    So obvioulsy not all is compatible between, PBP and MPASM.
    Out of interest can you try this fuse on your configuration.
    Cheers.
    Well, I was finally forced to upgrade MPASM. And along with it came the dreaded __CONFIG has been deprecated warning. So I figured .. No problem, these guys have already figured it out.
    But after trying everything out, and having to modify include files in the include files each time I compile a program that needs a different config, espescially when my programs already have all the config statements in them, just wasn't working out very well. And the thought of having to modify every program I've ever written, to use the new Config syntax, was leaving a bad taste in my mouth.
    Fortunately, the old __CONFIG directives still work. The __CONFIG has been deprecated warning, is just that.   A warning.   And Warnings can be turned off.   So until Microchip decides to make it not work anymore, what I'm doing is to add this line to the .inc file for the chip it's being compiled for.
        errorlevel -230
    Then everything works just like it always has.
    Last edited by Darrel Taylor; - 8th April 2006 at 03:23. Reason: P.S. - My MPASM version is now 5.02
    Ah, I see what you mean!
    Define XTAL 48
    OSCTUNE.6 =1
       CONFIG OSC=HSPLL
    Jan 2011
    Skopje,Macedonia
    Default Re: Presetting Configuration Fuses (PIC Defines) into your Program
    I got this error: overwriting previous address contents (2007)
    I write this line @ __CONFIG _INTRC_OSC_NOCLKOUT to turn on the internal oscilator of the PIC16F628A,
    I fix any mistakes what I think I made them,but there are errors.I DEFINE OSC 4,it's not working.
    You need to comment the *.inc file for the chip in the PBP directory.
    http://www.picbasic.co.uk/forum/show...=6775#post6775
    Jan 2011
    Skopje,Macedonia
    I get: Unable to open INCLUDE file P16F628A.INC
    Quote Originally Posted by SKOLS1 View Post
    Be sure Microcode Studio knows where that file is located. Click view, Compile and Program Options ,click the assembler tab,check USE MPASM, and Click either find Manually or Find Automatically.
    Jan 2011
    Skopje,Macedonia
    Quote Originally Posted by Archangel View Post
    I try with P16F628.INF file and It isn't working with another Include file(16F628.inc).I find it automatically but still not working.I will try with my other computer.I am using MPLAB IDE v8.73,I have those problems with MPLAB IDE v.7.60.What do you think?
  1. pic program crashing
    By comwarrior in forum General
    Last Post: - 8th July 2009, 17:33
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  3. Making Program Code Space your playground...
  4. size of program vs mem on pic
    By PICMAN in forum General
    Last Post: - 1st March 2005, 18:23
  5. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 16:45
Members who have read this thread : 5
