Presetting Configuration Fuses (PIC Defines) into your Program
Results 1 to 40 of 83
Threaded View
  1. #11
    OK, i also have the same problem here.. hum hum when i add some code line as you did.
    SO it looks like PicBasic is not "New MPASM Compliant" for the config fuses. I'll contact Charles tomorrow.
    For now, what you can do is to place your config fuses in the 18F2550.INC in the PBP folder. BUT if you do different project and you need different config fuse setting, You can add a device to the MCS list and create a new .INC and .BAS file for it. OR do an include file to be loaded in the 18F2550.INC file.
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F2550, r = dec, w = -311, f = inhx32
            INCLUDE "P18F2550.INC"	; MPASM  Header
            INCLUDE "C:\PBPProg\ConfigFuse.cfg" ; Your Config Fuses
            NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	32
    Just drop your config lines in the ConfigFuse.cfg file and it's work... this time. DOH sorry.
  1. pic program crashing
    By comwarrior in forum General
    Last Post: - 8th July 2009, 16:33
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 14:46
  3. Making Program Code Space your playground...
  4. size of program vs mem on pic
    By PICMAN in forum General
    Last Post: - 1st March 2005, 17:23
  5. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 15:45
Members who have read this thread : 7
