Presetting Configuration Fuses (PIC Defines) into your Program
+ Reply to Thread
Results 1 to 40 of 83
    Default Warning[230] __CONFIG has been deprecated for PIC18 devices.
    If you are using any PIC18 serie, you will have this warning one day or another. Our friends from Microchip decide to change the way to define the config fuses when using the latest MPASM version 5.00.
    The solution is still located at the same place... at the end of the 18XXXX.INC file located in the MPASM folder.
    Quote Originally Posted by Snip of MPASM 18F452.INC
    ; IMPORTANT: For the PIC18 devices, the __CONFIG directive has been
    ; superseded by the CONFIG directive. The following settings
    ; are available for this device.
    ; Oscillator Selection:
    ; OSC = LP LP
    ; OSC = XT XT
    ; OSC = HS HS
    ; OSC = RC RC
    ; OSC = EC EC-OSC2 as Clock Out
    ; OSC = ECIO EC-OSC2 as RA6
    ; OSC = HSPLL HS-PLL Enabled
    ; OSC = RCIO RC-OSC2 as RA6
    SO now the new method to set the config fuse on the PIC18 serie is...
    @ CONFIG OSCS=OFF, OSC=HS
        ' Oscillator switch OFF
        ' Use HS oscillator (20MHZ here)
    @ CONFIG BOR=ON, PWRT=ON, BORV=45
        ' Brown out reset ON @ 4.5Volts
        ' Power-up timer ON
    @ CONFIG WDT=ON
        ' Watch dog timer ON
    @ CONFIG STVR=ON, LVP=OFF, DEBUG=OFF
        ' Stack over/underflow ON
        ' Low Voltage programming OFF
        ' Background debugger OFF
    Or if you prefer...
        CONFIG OSCS=OFF  ; Oscillator switch OFF
        CONFIG OSC=HS    ; Use HS oscillator (20MHZ here)
        CONFIG BOR=ON    ; Brown out reset ON
        CONFIG BORV=45   ; Brown out detect voltage=4.5 Volt
        CONFIG PWRT=ON   ; Power-up timer ON
        CONFIG WDT=ON    ; Watch dog timer ON
        CONFIG STVR=ON   ; Stack over/underflow ON
        CONFIG LVP=OFF   ; Low Voltage programming OFF
        CONFIG DEBUG=OFF ; Background debugger OFF
    Don't forget to comment the default PBP config fuses...
    Feb 2005
    Essex, UK
    Nope can't get it going !!
    I've used
    @ CONFIG FOSC = HS
    but it returns the error
    __CONFIG directives cannot be used with CONFIG directives
    I've even tried
    @ CONFIG _CONFIG1H, _FOSC_HS_1H
    which returns the same error as above and also,
    @ __CONFIG _CONFIG1H, _FOSC_HS_1H
    which returns two errors stating:
    Overwriting previous address contents (0000)
    Overwriting previous address contents (0001)
    Any ideas?
    eoasap's Avatar
    eoasap Guest
    tissy, i just got the same thing you did. That's too bad because Steve's code looks so neat and orderly i personally would rather not use all the underscores and such.
    Feb 2005
    Essex, UK
    Right, i think i've figured this out.
    You need to find the 18F2550.INC (or whatever device you are using) in the PicBasic Pro installation directory.
    When you open that file it should look something like this:
    ;*  18F2550.INC                                                 *
    ;*  By        : Leonard Zerman, Jeff Schmoyer                   *
    ;*  Notice    : Copyright (c) 2004 microEngineering Labs, Inc.  *
    ;*              All Rights Reserved                             *
    ;*  Date      : 12/31/04                                        *
    ;*  Version   : 2.46                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F2550, r = dec, w = -311, f = inhx32
            INCLUDE "P18F2550.INC"	; MPASM  Header
            __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
            NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	32
    This is effectivly where you modify the fuses. The fuse definitions are contained within the P18F2550.INC as contained within your MPASMWIN directory.
    *** Note: My advice would be to back any files up before any modifications ***
    Hope this clears things up, it worked for me in the end. Now all the fuses are set without the need for modification each time.
    Just to make things clear for everybody. My solution work!!! As i said in my previous post don't forget to comment the PBP default fuse wich are located in the PBP folder in the according .INC file as Tissy found. So after the modification, Tissy's .INC file will looks like
    ;*  18F2550.INC                                                 *
    ;*  Version   : 2.46                                            *
    ;*  Notes     :                                                 *
            NOLIST
        ifdef PM_USED
            LIST
            NOLIST
            LIST
            ;__CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
            ;__CONFIG    _CONFIG1H, _FOSC_HS_1H
            ;__CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
            ;__CONFIG    _CONFIG3H, _PBADEN_OFF_3H
            ;__CONFIG    _CONFIG4L, _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L
            NOLIST
            LIST
    BLOCK_SIZE	EQU	32
    If you don't comment the default fuses... you'll always have this Warning message + another like overwriting previous content..
    Also be sure you have the latest MPASM version. 5.00 as now.
    About now?
    Feb 2005
    Essex, UK
    Yup, that cleared it up, thank you.
    Also where can i download MPASM ver 5.00. I've looked at Microchips site but can't find the link. Do you have it by chance?
    Thanks again,
    Feb 2005
    Essex, UK
    I had it all going in version 4.01 of MPASM and then downloaded version 5.00....big mistake !!
    Now i am getting all sorts of errors. If i use no config fuses in the code and set them manually all compiles fine, but when i try and set the fuses, errors occur again.
    I have done what is suggested above and commented out the necessary lines in the 18F2550.INC file found in the PBP directory.
    Any suggestions?
    Default Newer 18F chips (18F26J50) without old style configs
    So I notice that some 18F chips have the old style configs like CONFIG1H, as well as the new style listed in their chipx.inc file. But other chips, like the 18F26J50 only have the new style, with no CONFIG1H style in the Microchip .inc file for that chip.
    I have read the configs have been depreciated posts, where Darrel says ignore the warnings, they are just that ... warnings. However, with newer chips like the PIC18F26J50, is there a way to get around the error:
    Error[176]c:\picbasic\26j50-~.asm 101 :CONFIG Directive Error: (setting "48" not found for the processor 18F26J50) ? It seems so close, to only be held up by defining the oscillator!
    I get the above error when I try to use :
    DEFINE OSC 48
       CONFIG OSC=HSPLL
       CONFIG CPUDIV=OSC1
       CONFIG PLLDIV=5
       CONFIG LPT1OSC=OFF
       CONFIG CP0=OFF
       CONFIG WDTEN=ON
       CONFIG XINST=OFF
       CONFIG IOL1WAY=OFF
       CONFIG STVREN=OFF
       CONFIG T1DIG=ON
       CONFIG FCMEN=OFF
       CONFIG WDTPS=512
       CONFIG RTCOSC=T1OSCREF
    If I comment out the DEFINE OSC 48, all appears good. If I try to define the OSC setting, I get the 176 error.
    ..there are no CONFIG1H's here...
    ;   Watchdog Timer:
    ;     WDTEN = OFF          Disabled - Controlled by SWDTEN bit
    ;     WDTEN = ON           Enabled
    ;   PLL Prescaler Selection bits:
    ;     PLLDIV = 12          Divide by 12 (48 MHz oscillator input)
    ;     PLLDIV = 10          Divide by 10 (40 MHz oscillator input)
    ;     PLLDIV = 6           Divide by 6 (24 MHz oscillator input)
    ;     PLLDIV = 5           Divide by 5 (20 MHz oscillator input)
    ;     PLLDIV = 4           Divide by 4 (16 MHz oscillator input)
    ;     PLLDIV = 3           Divide by 3 (12 MHz oscillator input)
    ;     PLLDIV = 2           Divide by 2 (8 MHz oscillator input)
    ;     PLLDIV = 1           No prescale (4 MHz oscillator input drives PLL directly)
    ;   Stack Overflow/Underflow Reset :
    ;     STVREN = OFF         Disabled
    ;     STVREN = ON          Enabled
    ;   Extended Instruction Set:
    ;     XINST = OFF          Disabled
    ;     XINST = ON           Enabled
    ;   CPU System Clock Postscaler:
    ;     CPUDIV = OSC4_PLL6   CPU system clock divide by 6
    ;     CPUDIV = OSC3_PLL3   CPU system clock divide by 3
    ;     CPUDIV = OSC2_PLL2   CPU system clock divide by 2
    ;     CPUDIV = OSC1        No CPU system clock divide
    ;   Code Protect:
    ;     CP0 = ON             Program memory is code-protected
    ;     CP0 = OFF            Program memory is not code-protected
    ;   Oscillator:
    ;     OSC = INTOSC         INTOSC
    ;     OSC = INTOSCO        INTOSCO (CLKO-RA6)
    ;     OSC = INTOSCPLL      INTOSCPLL
    ;     OSC = INTOSCPLLO     INTOSCPLLO (CLKO-RA6)
    ;     OSC = HS             HS, USB-HS
    ;     OSC = HSPLL          HS+PLL, USB-HS+PLL
    ;     OSC = EC             EC (CLKO-RA6), USB-EC
    ;     OSC = ECPLL          EC+PLL (CLKO-RA6), USB-EC+PLL
    ;   T1OSCEN Enforcement:
    ;     T1DIG = OFF          Secondary Oscillator clock source may not be selected
    ;     T1DIG = ON           Secondary Oscillator clock source may be selected
    ;   Low-Power Timer1 Oscillator:
    ;     LPT1OSC = ON         Low-power operation
    ;     LPT1OSC = OFF        High-power operation
    ;   Fail-Safe Clock Monitor:
    ;     FCMEN = OFF          Disabled
    ;     FCMEN = ON           Enabled
    ;   Internal External Oscillator Switch Over Mode:
    ;     IESO = OFF           Disabled
    ;     IESO = ON            Enabled
    ;   Watchdog Postscaler:
    ;     WDTPS = 1            1:1
    ;     WDTPS = 2            1:2
    ;     WDTPS = 4            1:4
    ;     WDTPS = 8            1:8
    ;     WDTPS = 16           1:16
    ;     WDTPS = 32           1:32
    ;     WDTPS = 64           1:64
    ;     WDTPS = 128          1:128
    ;     WDTPS = 256          1:256
    ;     WDTPS = 512          1:512
    ;     WDTPS = 1024         1:1024
    ;     WDTPS = 2048         1:2048
    ;     WDTPS = 4096         1:4096
    ;     WDTPS = 8192         1:8192
    ;     WDTPS = 16384        1:16384
    ;     WDTPS = 32768        1:32768
    ;   DSWDT Clock Select:
    ;     DSWDTOSC = T1OSCREF  DSWDT uses T1OSC/T1CKI
    ;     DSWDTOSC = INTOSCREF DSWDT uses INTRC
    ;   RTCC Clock Select:
    ;     RTCOSC = INTOSCREF   RTCC uses INTRC
    ;     RTCOSC = T1OSCREF    RTCC uses T1OSC/T1CKI
    ;   Deep Sleep BOR:
    ;     DSBOREN = OFF        Disabled
    ;     DSBOREN = ON         Enabled
    ;   Deep Sleep Watchdog Timer:
    ;     DSWDTEN = OFF        Disabled
    ;     DSWDTEN = ON         Enabled
    ;   Deep Sleep Watchdog Postscaler:
    ;     DSWDTPS = 2          1:2 (2.1 ms)
    ;     DSWDTPS = 8          1:8 (8.3 ms)
    ;     DSWDTPS = 32         1:32 (33 ms)
    ;     DSWDTPS = 128        1:128 (132 ms)
    ;     DSWDTPS = 512        1:512 (528 ms)
    ;     DSWDTPS = 2048       1:2,048 (2.1 seconds)
    ;     DSWDTPS = 8192       1:8,192 (8.5 seconds)
    ;     DSWDTPS = K32        1:32,768 (34 seconds)
    ;     DSWDTPS = K131       1:131,072 (135 seconds)
    ;     DSWDTPS = K524       1:524,288 (9 minutes)
    ;     DSWDTPS = M2         1:2,097,152 (36 minutes)
    ;     DSWDTPS = M8         1:8,388,608 (2.4 hours)
    ;     DSWDTPS = M33        1:33,554,432 (9.6 hours)
    ;     DSWDTPS = M134       1:134,217,728 (38.5 hours)
    ;     DSWDTPS = M536       1:536,870,912 (6.4 days)
    ;     DSWDTPS = G2         1:2,147,483,648 (25.7 days)
    ;   IOLOCK One-Way Set Enable bit:
    ;     IOL1WAY = OFF        The IOLOCK bit (PPSCON<0>) can be set and cleared as needed
    ;     IOL1WAY = ON         The IOLOCK bit (PPSCON<0>) can be set once
    ;   MSSP address masking:
    ;     MSSP7B_EN = MSK5     5 Bit address masking mode
    ;     MSSP7B_EN = MSK7     7 Bit address masking mode
    ;   Write/Erase Protect Page Start/End Location:
    ;     WPFP = PAGE_0        Write Protect Program Flash Page 0
    ;     WPFP = PAGE_1        Write Protect Program Flash Page 1
    ;     WPFP = PAGE_2        Write Protect Program Flash Page 2
    ;     WPFP = PAGE_3        Write Protect Program Flash Page 3
    ;     WPFP = PAGE_4        Write Protect Program Flash Page 4
    ;     WPFP = PAGE_5        Write Protect Program Flash Page 5
    ;     WPFP = PAGE_6        Write Protect Program Flash Page 6
    ;     WPFP = PAGE_7        Write Protect Program Flash Page 7
    ;     WPFP = PAGE_8        Write Protect Program Flash Page 8
    ;     WPFP = PAGE_9        Write Protect Program Flash Page 9
    ;     WPFP = PAGE_10       Write Protect Program Flash Page 10
    ;     WPFP = PAGE_11       Write Protect Program Flash Page 11
    ;     WPFP = PAGE_12       Write Protect Program Flash Page 12
    ;     WPFP = PAGE_13       Write Protect Program Flash Page 13
    ;     WPFP = PAGE_14       Write Protect Program Flash Page 14
    ;     WPFP = PAGE_15       Write Protect Program Flash Page 15
    ;     WPFP = PAGE_16       Write Protect Program Flash Page 16
    ;     WPFP = PAGE_17       Write Protect Program Flash Page 17
    ;     WPFP = PAGE_18       Write Protect Program Flash Page 18
    ;     WPFP = PAGE_19       Write Protect Program Flash Page 19
    ;     WPFP = PAGE_20       Write Protect Program Flash Page 20
    ;     WPFP = PAGE_21       Write Protect Program Flash Page 21
    ;     WPFP = PAGE_22       Write Protect Program Flash Page 22
    ;     WPFP = PAGE_23       Write Protect Program Flash Page 23
    ;     WPFP = PAGE_24       Write Protect Program Flash Page 24
    ;     WPFP = PAGE_25       Write Protect Program Flash Page 25
    ;     WPFP = PAGE_26       Write Protect Program Flash Page 26
    ;     WPFP = PAGE_27       Write Protect Program Flash Page 27
    ;     WPFP = PAGE_28       Write Protect Program Flash Page 28
    ;     WPFP = PAGE_29       Write Protect Program Flash Page 29
    ;     WPFP = PAGE_30       Write Protect Program Flash Page 30
    ;     WPFP = PAGE_31       Write Protect Program Flash Page 31
    ;     WPFP = PAGE_32       Write Protect Program Flash Page 32
    ;     WPFP = PAGE_33       Write Protect Program Flash Page 33
    ;     WPFP = PAGE_34       Write Protect Program Flash Page 34
    ;     WPFP = PAGE_35       Write Protect Program Flash Page 35
    ;     WPFP = PAGE_36       Write Protect Program Flash Page 36
    ;     WPFP = PAGE_37       Write Protect Program Flash Page 37
    ;     WPFP = PAGE_38       Write Protect Program Flash Page 38
    ;     WPFP = PAGE_39       Write Protect Program Flash Page 39
    ;     WPFP = PAGE_40       Write Protect Program Flash Page 40
    ;     WPFP = PAGE_41       Write Protect Program Flash Page 41
    ;     WPFP = PAGE_42       Write Protect Program Flash Page 42
    ;     WPFP = PAGE_43       Write Protect Program Flash Page 43
    ;     WPFP = PAGE_44       Write Protect Program Flash Page 44
    ;     WPFP = PAGE_45       Write Protect Program Flash Page 45
    ;     WPFP = PAGE_46       Write Protect Program Flash Page 46
    ;     WPFP = PAGE_47       Write Protect Program Flash Page 47
    ;     WPFP = PAGE_48       Write Protect Program Flash Page 48
    ;     WPFP = PAGE_49       Write Protect Program Flash Page 49
    ;     WPFP = PAGE_50       Write Protect Program Flash Page 50
    ;     WPFP = PAGE_51       Write Protect Program Flash Page 51
    ;     WPFP = PAGE_52       Write Protect Program Flash Page 52
    ;     WPFP = PAGE_53       Write Protect Program Flash Page 53
    ;     WPFP = PAGE_54       Write Protect Program Flash Page 54
    ;     WPFP = PAGE_55       Write Protect Program Flash Page 55
    ;     WPFP = PAGE_56       Write Protect Program Flash Page 56
    ;     WPFP = PAGE_57       Write Protect Program Flash Page 57
    ;     WPFP = PAGE_58       Write Protect Program Flash Page 58
    ;     WPFP = PAGE_59       Write Protect Program Flash Page 59
    ;     WPFP = PAGE_60       Write Protect Program Flash Page 60
    ;     WPFP = PAGE_61       Write Protect Program Flash Page 61
    ;     WPFP = PAGE_62       Write Protect Program Flash Page 62
    ;     WPFP = PAGE_63       Write Protect Program Flash Page 63
    ;   Write/Erase Protect Region Select bit (valid when WPDIS = 0):
    ;     WPEND = PAGE_0       Page 0 to WPFP<5:0> erase/write-protected
    ;     WPEND = PAGE_WPFP    Pages WPFP<5:0> to (Configuration Words page) write/erase protected
    ;   Write/Erase Protect Configuration Region :
    ;     WPCFG = ON           Configuration Words page erase/write-protected
    ;     WPCFG = OFF          Configuration Words page not erase/write-protected
    ;   Write Protect Disable bit:
    ;     WPDIS = ON           WPFP[5:0], WPEND, and WPCFG bits enabled
    ;     WPDIS = OFF          WPFP[5:0], WPEND, and WPCFG bits ignored
    _DEVID1          EQU  H'3FFFFE'
    _DEVID2          EQU  H'3FFFFF'
    Is the only solution is to edit all configs in the PBP include file, or am I missing something. If this has already been covered, let me have it....
    I notice that the 18F4550 has both styles in it's include file, like this:
    ;     CPUDIV = OSC1_PLL2   [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
    ;     CPUDIV = OSC2_PLL3   [OSC1/OSC2 Src: /2][96 MHz PLL Src: /3]
    ;     CPUDIV = OSC3_PLL4   [OSC1/OSC2 Src: /3][96 MHz PLL Src: /4]
    ;     CPUDIV = OSC4_PLL6   [OSC1/OSC2 Src: /4][96 MHz PLL Src: /6]
    ;   USB Clock Selection bit (used in Full Speed USB mode only; UCFG:FSEN = 1):
    ;     USBDIV = 1           USB clock source comes directly from the primary oscillator block with no postscale
    ;     USBDIV = 2           USB clock source comes from the 96 MHz PLL divided by 2
    ;   Oscillator Selection bits:
    ;     FOSC = XT_XT         XT oscillator, XT used by USB
    ;     FOSC = XTPLL_XT      XT oscillator, PLL enabled, XT used by USB
    ;     FOSC = ECIO_EC       External clock, port function on RA6, EC used by USB
    ;     FOSC = EC_EC         External clock, CLKOUT on RA6, EC used by USB
    ;     FOSC = ECPLLIO_EC    External clock, PLL enabled, port function on RA6, EC used by USB
    ;     FOSC = ECPLL_EC      External clock, PLL enabled, CLKOUT on RA6, EC used by USB
    ;     FOSC = INTOSCIO_EC   Internal oscillator, port function on RA6, EC used by USB
    ;     FOSC = INTOSC_EC     Internal oscillator, CLKOUT on RA6, EC used by USB
    ;     FOSC = INTOSC_XT     Internal oscillator, XT used by USB
    ;     FOSC = INTOSC_HS     Internal oscillator, HS used by USB
    ;     FOSC = HS            HS oscillator, HS used by USB
    ;     FOSC = HSPLL_HS      HS oscillator, PLL enabled, HS used by USB
    ;   Fail-Safe Clock Monitor Enable bit:
    ;     FCMEN = OFF          Fail-Safe Clock Monitor disabled
    ;     FCMEN = ON           Fail-Safe Clock Monitor enabled
    ;   Internal/External Oscillator Switchover bit:
    ;     IESO = OFF           Oscillator Switchover mode disabled
    ;     IESO = ON            Oscillator Switchover mode enabled
    ;   Power-up Timer Enable bit:
    ;     PWRT = ON            PWRT enabled
    ;     PWRT = OFF           PWRT disabled
    ;   Brown-out Reset Enable bits:
    ;     BOR = OFF            Brown-out Reset disabled in hardware and software
    ;     BOR = SOFT           Brown-out Reset enabled and controlled by software (SBOREN is enabled)
    ;     BOR = ON_ACTIVE      Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
    ;     BOR = ON             Brown-out Reset enabled in hardware only (SBOREN is disabled)
    ;   Brown-out Voltage bits:
    ;     BORV = 0             Maximum setting
    ;     BORV = 1
    ;     BORV = 2
    ;     BORV = 3             Minimum setting
    ;   USB Voltage Regulator Enable bit:
    ;     VREGEN = OFF         USB voltage regulator disabled
    ;     VREGEN = ON          USB voltage regulator enabled
    ;   Watchdog Timer Enable bit:
    ;     WDT = OFF            HW Disabled - SW Controlled
    ;     WDT = ON             HW Enabled - SW Disabled
    ;   Watchdog Timer Postscale Select bits:
    ;     WDTPS = 1            1:1
    ;     WDTPS = 2            1:2
    ;     WDTPS = 4            1:4
    ;     WDTPS = 8            1:8
    ;     WDTPS = 16           1:16
    ;     WDTPS = 32           1:32
    ;     WDTPS = 64           1:64
    ;     WDTPS = 128          1:128
    ;     WDTPS = 256          1:256
    ;     WDTPS = 512          1:512
    ;   MCLR Pin Enable bit:
    ;     MCLRE = OFF          RE3 input pin enabled; MCLR disabled
    ;     MCLRE = ON           MCLR pin enabled; RE3 input pin disabled
    ;   Low-Power Timer 1 Oscillator Enable bit:
    ;     LPT1OSC = OFF        Timer1 configured for higher power operation
    ;     LPT1OSC = ON         Timer1 configured for low-power operation
    ;   PORTB A/D Enable bit:
    ;     PBADEN = OFF         PORTB<4:0> pins are configured as digital I/O on Reset
    ;     PBADEN = ON          PORTB<4:0> pins are configured as analog input channels on Reset
    ;   CCP2 MUX bit:
    ;     CCP2MX = OFF         CCP2 input/output is multiplexed with RB3
    ;     CCP2MX = ON          CCP2 input/output is multiplexed with RC1
    ;   Stack Full/Underflow Reset Enable bit:
    ;     STVREN = OFF         Stack full/underflow will not cause Reset
    ;     STVREN = ON          Stack full/underflow will cause Reset
    ;   Single-Supply ICSP Enable bit:
    ;     LVP = OFF            Single-Supply ICSP disabled
    ;     LVP = ON             Single-Supply ICSP enabled
    ;   Dedicated In-Circuit Debug/Programming Port (ICPORT) Enable bit:
    ;     ICPRT = OFF          ICPORT disabled
    ;     ICPRT = ON           ICPORT enabled
    ;   Extended Instruction Set Enable bit:
    ;     XINST = OFF          Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    ;     XINST = ON           Instruction set extension and Indexed Addressing mode enabled
    ;   Background Debugger Enable bit:
    ;     DEBUG = ON           Background debugger enabled, RB6 and RB7 are dedicated to In-Circuit Debug
    ;     DEBUG = OFF          Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
    ;   Code Protection bit Block 0:
    ;     CP0 = ON             Block 0 (000800-001FFFh) code-protected
    ;     CP0 = OFF            Block 0 (000800-001FFFh) not code-protected
    ;   Code Protection bit Block 1:
    ;     CP1 = ON             Block 1 (002000-003FFFh) code-protected
    ;     CP1 = OFF            Block 1 (002000-003FFFh) not code-protected
    ;   Code Protection bit Block 2:
    ;     CP2 = ON             Block 2 (004000-005FFFh) code-protected
    ;     CP2 = OFF            Block 2 (004000-005FFFh) not code-protected
    ;   Code Protection bit Block 3:
    ;     CP3 = ON             Block 3 (006000-007FFFh) code-protected
    ;     CP3 = OFF            Block 3 (006000-007FFFh) not code-protected
    ;   Boot Block Code Protection bit:
    ;     CPB = ON             Boot block (000000-0007FFh) code-protected
    ;     CPB = OFF            Boot block (000000-0007FFh) not code-protected
    ;   Data EEPROM Code Protection bit:
    ;     CPD = ON             Data EEPROM code-protected
    ;     CPD = OFF            Data EEPROM not code-protected
    ;   Write Protection bit Block 0:
    ;     WRT0 = ON            Block 0 (000800-001FFFh) write-protected
    ;     WRT0 = OFF           Block 0 (000800-001FFFh) not write-protected
    ;   Write Protection bit Block 1:
    ;     WRT1 = ON            Block 1 (002000-003FFFh) write-protected
    ;     WRT1 = OFF           Block 1 (002000-003FFFh) not write-protected
    ;   Write Protection bit Block 2:
    ;     WRT2 = ON            Block 2 (004000-005FFFh) write-protected
    ;     WRT2 = OFF           Block 2 (004000-005FFFh) not write-protected
    ;   Write Protection bit Block 3:
    ;     WRT3 = ON            Block 3 (006000-007FFFh) write-protected
    ;     WRT3 = OFF           Block 3 (006000-007FFFh) not write-protected
    ;   Boot Block Write Protection bit:
    ;     WRTB = ON            Boot block (000000-0007FFh) write-protected
    ;     WRTB = OFF           Boot block (000000-0007FFh) not write-protected
    ;   Configuration Register Write Protection bit:
    ;     WRTC = ON            Configuration registers (300000-3000FFh) write-protected
    ;     WRTC = OFF           Configuration registers (300000-3000FFh) not write-protected
    ;   Data EEPROM Write Protection bit:
    ;     WRTD = ON            Data EEPROM write-protected
    ;     WRTD = OFF           Data EEPROM not write-protected
    ;   Table Read Protection bit Block 0:
    ;     EBTR0 = ON           Block 0 (000800-001FFFh) protected from table reads executed in other blocks
    ;     EBTR0 = OFF          Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
    ;   Table Read Protection bit Block 1:
    ;     EBTR1 = ON           Block 1 (002000-003FFFh) protected from table reads executed in other blocks
    ;     EBTR1 = OFF          Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
    ;   Table Read Protection bit Block 2:
    ;     EBTR2 = ON           Block 2 (004000-005FFFh) protected from table reads executed in other blocks
    ;     EBTR2 = OFF          Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
    ;   Table Read Protection bit Block 3:
    ;     EBTR3 = ON           Block 3 (006000-007FFFh) protected from table reads executed in other blocks
    ;     EBTR3 = OFF          Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
    ;   Boot Block Table Read Protection:
    ;     EBTRB = ON           Boot block (000000-0007FFh) protected from table reads executed in other blocks
    ;     EBTRB = OFF          Boot block (000000-0007FFh) not protected from table reads executed in other blocks
    ;       Configuration Bits
    ;   NAME            Address
    ;   CONFIG1L        300000h
    ;   CONFIG1H        300001h
    ;   CONFIG2L        300002h
    ;   CONFIG2H        300003h
    ;   CONFIG3H        300005h
    ;   CONFIG4L        300006h
    ;   CONFIG5L        300008h
    ;   CONFIG5H        300009h
    ;   CONFIG6L        30000Ah
    ;   CONFIG6H        30000Bh
    ;   CONFIG7L        30000Ch
    ;   CONFIG7H        30000Dh
    ; The following is an assignment of address values for all of the
    ; configuration registers for the purpose of table reads
    _CONFIG1L        EQU  H'300000'
    _CONFIG1H        EQU  H'300001'
    _CONFIG2L        EQU  H'300002'
    _CONFIG2H        EQU  H'300003'
    _CONFIG3H        EQU  H'300005'
    _CONFIG4L        EQU  H'300006'
    _CONFIG5L        EQU  H'300008'
    _CONFIG5H        EQU  H'300009'
    _CONFIG6L        EQU  H'30000A'
    _CONFIG6H        EQU  H'30000B'
    _CONFIG7L        EQU  H'30000C'
    _CONFIG7H        EQU  H'30000D'
    ;----- CONFIG1L Options --------------------------------------------------
    _PLLDIV_1_1L         EQU  H'F8'    ; No prescale (4 MHz oscillator input drives PLL directly)
    _PLLDIV_2_1L         EQU  H'F9'    ; Divide by 2 (8 MHz oscillator input)
    _PLLDIV_3_1L         EQU  H'FA'    ; Divide by 3 (12 MHz oscillator input)
    _PLLDIV_4_1L         EQU  H'FB'    ; Divide by 4 (16 MHz oscillator input)
    _PLLDIV_5_1L         EQU  H'FC'    ; Divide by 5 (20 MHz oscillator input)
    _PLLDIV_6_1L         EQU  H'FD'    ; Divide by 6 (24 MHz oscillator input)
    _PLLDIV_10_1L        EQU  H'FE'    ; Divide by 10 (40 MHz oscillator input)
    _PLLDIV_12_1L        EQU  H'FF'    ; Divide by 12 (48 MHz oscillator input)
    _CPUDIV_OSC1_PLL2_1L EQU  H'E7'    ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
    _CPUDIV_OSC2_PLL3_1L EQU  H'EF'    ; [OSC1/OSC2 Src: /2][96 MHz PLL Src: /3]
    _CPUDIV_OSC3_PLL4_1L EQU  H'F7'    ; [OSC1/OSC2 Src: /3][96 MHz PLL Src: /4]
    _CPUDIV_OSC4_PLL6_1L EQU  H'FF'    ; [OSC1/OSC2 Src: /4][96 MHz PLL Src: /6]
    _USBDIV_1_1L         EQU  H'DF'    ; USB clock source comes directly from the primary oscillator block with no postscale
    _USBDIV_2_1L         EQU  H'FF'    ; USB clock source comes from the 96 MHz PLL divided by 2
    ;----- CONFIG1H Options --------------------------------------------------
    _FOSC_XT_XT_1H       EQU  H'F0'    ; XT oscillator, XT used by USB
    _FOSC_XTPLL_XT_1H    EQU  H'F2'    ; XT oscillator, PLL enabled, XT used by USB
    _FOSC_ECIO_EC_1H     EQU  H'F4'    ; External clock, port function on RA6, EC used by USB
    _FOSC_EC_EC_1H       EQU  H'F5'    ; External clock, CLKOUT on RA6, EC used by USB
    _FOSC_ECPLLIO_EC_1H  EQU  H'F6'    ; External clock, PLL enabled, port function on RA6, EC used by USB
    _FOSC_ECPLL_EC_1H    EQU  H'F7'    ; External clock, PLL enabled, CLKOUT on RA6, EC used by USB
    _FOSC_INTOSCIO_EC_1H EQU  H'F8'    ; Internal oscillator, port function on RA6, EC used by USB
    _FOSC_INTOSC_EC_1H   EQU  H'F9'    ; Internal oscillator, CLKOUT on RA6, EC used by USB
    _FOSC_INTOSC_XT_1H   EQU  H'FA'    ; Internal oscillator, XT used by USB
    _FOSC_INTOSC_HS_1H   EQU  H'FB'    ; Internal oscillator, HS used by USB
    _FOSC_HS_1H          EQU  H'FC'    ; HS oscillator, HS used by USB
    _FOSC_HSPLL_HS_1H    EQU  H'FE'    ; HS oscillator, PLL enabled, HS used by USB
    _FCMEN_OFF_1H        EQU  H'BF'    ; Fail-Safe Clock Monitor disabled
    _FCMEN_ON_1H         EQU  H'FF'    ; Fail-Safe Clock Monitor enabled
    _IESO_OFF_1H         EQU  H'7F'    ; Oscillator Switchover mode disabled
    _IESO_ON_1H          EQU  H'FF'    ; Oscillator Switchover mode enabled
    ;----- CONFIG2L Options --------------------------------------------------
    _PWRT_ON_2L          EQU  H'FE'    ; PWRT enabled
    _PWRT_OFF_2L         EQU  H'FF'    ; PWRT disabled
    _BOR_OFF_2L          EQU  H'F9'    ; Brown-out Reset disabled in hardware and software
    _BOR_SOFT_2L         EQU  H'FB'    ; Brown-out Reset enabled and controlled by software (SBOREN is enabled)
    _BOR_ON_ACTIVE_2L    EQU  H'FD'    ; Brown-out Reset enabled in hardware only and disabled in Sleep mode (SBOREN is disabled)
    _BOR_ON_2L           EQU  H'FF'    ; Brown-out Reset enabled in hardware only (SBOREN is disabled)
    _BORV_0_2L           EQU  H'E7'    ; Maximum setting
    _BORV_1_2L           EQU  H'EF'    ;
    _BORV_2_2L           EQU  H'F7'    ;
    _BORV_3_2L           EQU  H'FF'    ; Minimum setting
    _VREGEN_OFF_2L       EQU  H'DF'    ; USB voltage regulator disabled
    _VREGEN_ON_2L        EQU  H'FF'    ; USB voltage regulator enabled
    ;----- CONFIG2H Options --------------------------------------------------
    _WDT_OFF_2H          EQU  H'FE'    ; HW Disabled - SW Controlled
    _WDT_ON_2H           EQU  H'FF'    ; HW Enabled - SW Disabled
    _WDTPS_1_2H          EQU  H'E1'    ; 1:1
    _WDTPS_2_2H          EQU  H'E3'    ; 1:2
    _WDTPS_4_2H          EQU  H'E5'    ; 1:4
    _WDTPS_8_2H          EQU  H'E7'    ; 1:8
    _WDTPS_16_2H         EQU  H'E9'    ; 1:16
    _WDTPS_32_2H         EQU  H'EB'    ; 1:32
    _WDTPS_64_2H         EQU  H'ED'    ; 1:64
    _WDTPS_128_2H        EQU  H'EF'    ; 1:128
    _WDTPS_256_2H        EQU  H'F1'    ; 1:256
    _WDTPS_512_2H        EQU  H'F3'    ; 1:512
    _WDTPS_1024_2H       EQU  H'F5'    ; 1:1024
    _WDTPS_2048_2H       EQU  H'F7'    ; 1:2048
    _WDTPS_4096_2H       EQU  H'F9'    ; 1:4096
    _WDTPS_8192_2H       EQU  H'FB'    ; 1:8192
    _WDTPS_16384_2H      EQU  H'FD'    ; 1:16384
    _WDTPS_32768_2H      EQU  H'FF'    ; 1:32768
    ;----- CONFIG3H Options --------------------------------------------------
    _MCLRE_OFF_3H        EQU  H'7F'    ; RE3 input pin enabled; MCLR disabled
    _MCLRE_ON_3H         EQU  H'FF'    ; MCLR pin enabled; RE3 input pin disabled
    _LPT1OSC_OFF_3H      EQU  H'FB'    ; Timer1 configured for higher power operation
    _LPT1OSC_ON_3H       EQU  H'FF'    ; Timer1 configured for low-power operation
    _PBADEN_OFF_3H       EQU  H'FD'    ; PORTB<4:0> pins are configured as digital I/O on Reset
    _PBADEN_ON_3H        EQU  H'FF'    ; PORTB<4:0> pins are configured as analog input channels on Reset
    _CCP2MX_OFF_3H       EQU  H'FE'    ; CCP2 input/output is multiplexed with RB3
    _CCP2MX_ON_3H        EQU  H'FF'    ; CCP2 input/output is multiplexed with RC1
    ;----- CONFIG4L Options --------------------------------------------------
    _STVREN_OFF_4L       EQU  H'FE'    ; Stack full/underflow will not cause Reset
    _STVREN_ON_4L        EQU  H'FF'    ; Stack full/underflow will cause Reset
    _LVP_OFF_4L          EQU  H'FB'    ; Single-Supply ICSP disabled
    _LVP_ON_4L           EQU  H'FF'    ; Single-Supply ICSP enabled
    _ICPRT_OFF_4L        EQU  H'DF'    ; ICPORT disabled
    _ICPRT_ON_4L         EQU  H'FF'    ; ICPORT enabled
    _XINST_OFF_4L        EQU  H'BF'    ; Instruction set extension and Indexed Addressing mode disabled (Legacy mode)
    _XINST_ON_4L         EQU  H'FF'    ; Instruction set extension and Indexed Addressing mode enabled
    _DEBUG_ON_4L         EQU  H'7F'    ; Background debugger enabled, RB6 and RB7 are dedicated to In-Circuit Debug
    _DEBUG_OFF_4L        EQU  H'FF'    ; Background debugger disabled, RB6 and RB7 configured as general purpose I/O pins
    ;----- CONFIG5L Options --------------------------------------------------
    _CP0_ON_5L           EQU  H'FE'    ; Block 0 (000800-001FFFh) code-protected
    _CP0_OFF_5L          EQU  H'FF'    ; Block 0 (000800-001FFFh) not code-protected
    _CP1_ON_5L           EQU  H'FD'    ; Block 1 (002000-003FFFh) code-protected
    _CP1_OFF_5L          EQU  H'FF'    ; Block 1 (002000-003FFFh) not code-protected
    _CP2_ON_5L           EQU  H'FB'    ; Block 2 (004000-005FFFh) code-protected
    _CP2_OFF_5L          EQU  H'FF'    ; Block 2 (004000-005FFFh) not code-protected
    _CP3_ON_5L           EQU  H'F7'    ; Block 3 (006000-007FFFh) code-protected
    _CP3_OFF_5L          EQU  H'FF'    ; Block 3 (006000-007FFFh) not code-protected
    ;----- CONFIG5H Options --------------------------------------------------
    _CPB_ON_5H           EQU  H'BF'    ; Boot block (000000-0007FFh) code-protected
    _CPB_OFF_5H          EQU  H'FF'    ; Boot block (000000-0007FFh) not code-protected
    _CPD_ON_5H           EQU  H'7F'    ; Data EEPROM code-protected
    _CPD_OFF_5H          EQU  H'FF'    ; Data EEPROM not code-protected
    ;----- CONFIG6L Options --------------------------------------------------
    _WRT0_ON_6L          EQU  H'FE'    ; Block 0 (000800-001FFFh) write-protected
    _WRT0_OFF_6L         EQU  H'FF'    ; Block 0 (000800-001FFFh) not write-protected
    _WRT1_ON_6L          EQU  H'FD'    ; Block 1 (002000-003FFFh) write-protected
    _WRT1_OFF_6L         EQU  H'FF'    ; Block 1 (002000-003FFFh) not write-protected
    _WRT2_ON_6L          EQU  H'FB'    ; Block 2 (004000-005FFFh) write-protected
    _WRT2_OFF_6L         EQU  H'FF'    ; Block 2 (004000-005FFFh) not write-protected
    _WRT3_ON_6L          EQU  H'F7'    ; Block 3 (006000-007FFFh) write-protected
    _WRT3_OFF_6L         EQU  H'FF'    ; Block 3 (006000-007FFFh) not write-protected
    ;----- CONFIG6H Options --------------------------------------------------
    _WRTB_ON_6H          EQU  H'BF'    ; Boot block (000000-0007FFh) write-protected
    _WRTB_OFF_6H         EQU  H'FF'    ; Boot block (000000-0007FFh) not write-protected
    _WRTC_ON_6H          EQU  H'DF'    ; Configuration registers (300000-3000FFh) write-protected
    _WRTC_OFF_6H         EQU  H'FF'    ; Configuration registers (300000-3000FFh) not write-protected
    _WRTD_ON_6H          EQU  H'7F'    ; Data EEPROM write-protected
    _WRTD_OFF_6H         EQU  H'FF'    ; Data EEPROM not write-protected
    ;----- CONFIG7L Options --------------------------------------------------
    _EBTR0_ON_7L         EQU  H'FE'    ; Block 0 (000800-001FFFh) protected from table reads executed in other blocks
    _EBTR0_OFF_7L        EQU  H'FF'    ; Block 0 (000800-001FFFh) not protected from table reads executed in other blocks
    _EBTR1_ON_7L         EQU  H'FD'    ; Block 1 (002000-003FFFh) protected from table reads executed in other blocks
    _EBTR1_OFF_7L        EQU  H'FF'    ; Block 1 (002000-003FFFh) not protected from table reads executed in other blocks
    _EBTR2_ON_7L         EQU  H'FB'    ; Block 2 (004000-005FFFh) protected from table reads executed in other blocks
    _EBTR2_OFF_7L        EQU  H'FF'    ; Block 2 (004000-005FFFh) not protected from table reads executed in other blocks
    _EBTR3_ON_7L         EQU  H'F7'    ; Block 3 (006000-007FFFh) protected from table reads executed in other blocks
    _EBTR3_OFF_7L        EQU  H'FF'    ; Block 3 (006000-007FFFh) not protected from table reads executed in other blocks
    ;----- CONFIG7H Options --------------------------------------------------
    _EBTRB_ON_7H         EQU  H'BF'    ; Boot block (000000-0007FFh) protected from table reads executed in other blocks
    _EBTRB_OFF_7H        EQU  H'FF'    ; Boot block (000000-0007FFh) not protected from table reads executed in other blocks
    Walter
    Hi Walter,
    When using the new config directives you need to place them in the 18F26J50.INC file. They will not work when dropped directly in your code file.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. pic program crashing
    By comwarrior in forum General
    Last Post: - 8th July 2009, 17:33
  2. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  3. Making Program Code Space your playground...
  4. size of program vs mem on pic
    By PICMAN in forum General
    Last Post: - 1st March 2005, 18:23
  5. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 16:45
Members who have read this thread : 5
