Define Loader_used 1
Results 1 to 3 of 3
    brighton
    Default Define Loader_used 1
    Hi i don't know if this is a stupid question
    but for the bootloader to work the following define needs to be included
    on top of the program
    DEFINE LOADER_USED 1
    where can i find this in the pbp folder so that i can see what its actually doing
    Isaac
    Mar 2006
    China
    Default Depending of PIC serie
    PBPPIC18.LIB if you are using the 18-series, if you use anything else PBPPIC??.LIB is a good guess (where ?? is the serie). These files are found in the PBP directory.
    Hope it can be what you asked for
    /me
    brighton
    Smile
    Thank you very much
    That was exactly what i was looking for
    Isaac
  1. Thermo 7 segments - little problem
    Last Post: - 27th July 2013, 07:31
  2. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  3. 32 bit square root
    Last Post: - 6th May 2009, 03:37
  4. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 12:19
  5. HSERIN doesn´t work
    Last Post: - 29th July 2007, 14:23
