include
#include
#include
#include
#pragma config FPLLODIV = DIV_1, FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FWDTEN = OFF, FCKSM = CSECME, FPBDIV = DIV_1
#pragma config OSCIOFNC = ON, POSCMOD = XT, FSOSCEN = ON, FNOSC = PRIPLL
#pragma config CP = OFF, BWP = OFF, PWP = OFF
#define GetSystemClock() (80000000ul)
#define GetPeripheralClock() (GetSystemClock()/(1 << OSCCONbits.PBDIV))
#define GetInstructionClock() (GetSystemClock())
#define buf_new 1024
void SendDataBuffer(const char *buffer, UINT32 size);
UINT32 GetMenuChoice(void);
UINT32 GetDataBuffer(char *buffer, UINT32 max_size);
char gps_string[buf_new];
float lat, lon, lat1, lon1;
int fix, qual, dd, led=0;
char *start_ptr, *end_ptr, *latitude, *longitude, *quality;
void parse(volatile unsigned char *string)
printf("%s\n", gps_string);
// LATITUDE
start_ptr=strchr(gps_string,','); //find start of time field
start_ptr=strchr(start_ptr+1,','); //find start of latitude field
latitude = start_ptr+1; //find first character in latitude field
printf ("Latitude starts at gps_string[%d]\n",latitude-gps_string);
end_ptr=strchr(latitude,','); //find end of latitude field
printf ("Latitude ends at gps_string[%d]\n",end_ptr-gps_string-1);
if (latitude-gps_string>=end_ptr-gps_string) //determine if latitude exists
{printf("Latitude not received\n");}
lat=atof(latitude); //convert to float
printf("Latitude = %f\n",lat);
// LATITUDE
// LONGITUDE
longitude = start_ptr+1;
printf ("Longitude starts at gps_string[%d]\n",longitude-gps_string);
end_ptr=strchr(longitude,',');
printf ("Longitude ends at gps_string[%d]\n",end_ptr-gps_string-1);
if (longitude-gps_string>=end_ptr-gps_string)
{printf("Longitude not received\n");}
lon=atof(longitude);
printf("Longitude = %f\n",lon);
// LONGITUDE
// QUALITY
quality = start_ptr+1;
printf ("Quality starts at gps_string[%d]\n",quality-gps_string);
end_ptr=strchr(quality,',');
printf ("Quality ends at gps_string[%d]\n",end_ptr-gps_string-1);
if (quality-gps_string>=end_ptr-gps_string)
printf("Quality not received\n");
qual=atoi(quality);
printf("Quality = %d\n",qual);
if (qual==1|qual==2){
printf("Fix acquired\n");
else{
printf("Fix not aquired\n");
int main(void)
UINT32 menu_choice;
UARTConfigure(UART2, UART_ENABLE_PINS_TX_RX_ONLY);
//UARTSetFifoMode(UART2, UART_INTERRUPT_ON_TX_NOT_FULL | UART_INTERRUPT_ON_RX_NOT_EMPTY);
UARTSetLineControl(UART2, UART_DATA_SIZE_8_BITS | UART_PARITY_NONE | UART_STOP_BITS_1);
UARTSetDataRate(UART2, GetPeripheralClock(), 4800);
UARTEnable(UART2, UART_ENABLE_FLAGS(UART_PERIPHERAL | UART_RX | UART_TX));
while(1)
if(gps_string[0]=='$' && gps_string[1]=='G' && gps_string[2]=='P' && gps_string[3]=='G' && gps_string[4]=='G')
parse(gps_string);
while(1)
UINT32 rx_size;
rx_size = GetDataBuffer(gps_string, 1);
SendDataBuffer(gps_string, rx_size);
return -1;
// void UARTTxBuffer(char *buffer, UINT32 size)
void SendDataBuffer(char *buffer, UINT32 size)
while(size)
while(!UARTTransmitterIsReady(UART2))
UARTSendDataByte(UART2, *buffer);
buffer++;
size--;
while(!UARTTransmissionHasCompleted(UART2))
// UINT32 GetDataBuffer(char *buffer, UINT32 max_size)
UINT32 num_char;
num_char = 0;
while(num_char < max_size)
UINT8 character;
while(!UARTReceivedDataIsAvailable(UART2))
character = UARTGetDataByte(UART2);
// if(character == '\r')
// break;
*buffer = character;
buffer++;
num_char++;
return num_char;
Ragazzi questo e' tutto il codice scritto per PIC32
Mi dà questi errori
ource\main.c: In function `parse':
source\main.c:32: warning: implicit declaration of function `strchr'
source\main.c: At top level:
source\main.c:128: error: conflicting types for 'SendDataBuffer'
source\main.c:17: error: previous declaration of 'SendDataBuffer' was here
non capisco.... sto impazzendo.....aiuttoooooooooooooooooooo
grazie a tutti....
