GPS parser for GPRMB and GPRMC
Results 1 to 6 of 6
    Default GPS parser for GPRMB and GPRMC
    Here is a routine for a PIC16F877 that will extract all the GPRMB data fields and selected GPRMC fields. It works with a Garmin Foretrex as the NMEA source and I use both an on-board LCD and a HP-200LX as a portable RS232 terminal to display results.
    Cheers
    Brian
    Apr 2010
    thank you for sharing your code, i really appreciate that.
    but could you please provide me with the hardware connection between the GPS and the PIC.
    thnx again
    Aug 2003
    Quote Originally Posted by sradayda View Post
    thnx again
    The source makes it pretty obvious.
    A 16F877 running at 20MHz, and LED connected to RA0,
    GPS connected RX to RD7, Tx to RD6, etc.
    188 is the serin2 mode for 4800 baud rate so the GPS device will have to
    be set to 4800 baud, or the basic program changed.
    May 2011
    Default Re: GPS parser for GPRMB and GPRMC
    Dear all,
    I have problems with the parser of GPS string using PIC32.
    Could you help me please?
    Do you have an example please?
    May 2011
    include
    #include
    #include
    #include
    #pragma config FPLLODIV = DIV_1, FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FWDTEN = OFF, FCKSM = CSECME, FPBDIV = DIV_1
    #pragma config OSCIOFNC = ON, POSCMOD = XT, FSOSCEN = ON, FNOSC = PRIPLL
    #pragma config CP = OFF, BWP = OFF, PWP = OFF
    #define GetSystemClock() (80000000ul)
    #define GetPeripheralClock() (GetSystemClock()/(1 << OSCCONbits.PBDIV))
    #define GetInstructionClock() (GetSystemClock())
    #define buf_new 1024
    void SendDataBuffer(const char *buffer, UINT32 size);
    UINT32 GetMenuChoice(void);
    UINT32 GetDataBuffer(char *buffer, UINT32 max_size);
    char gps_string[buf_new];
    float lat, lon, lat1, lon1;
    int fix, qual, dd, led=0;
    char *start_ptr, *end_ptr, *latitude, *longitude, *quality;
    void parse(volatile unsigned char *string)
    printf("%s\n", gps_string);
    // LATITUDE
    start_ptr=strchr(gps_string,','); //find start of time field
    start_ptr=strchr(start_ptr+1,','); //find start of latitude field
    latitude = start_ptr+1; //find first character in latitude field
    printf ("Latitude starts at gps_string[%d]\n",latitude-gps_string);
    end_ptr=strchr(latitude,','); //find end of latitude field
    printf ("Latitude ends at gps_string[%d]\n",end_ptr-gps_string-1);
    if (latitude-gps_string>=end_ptr-gps_string) //determine if latitude exists
    {printf("Latitude not received\n");}
    lat=atof(latitude); //convert to float
    printf("Latitude = %f\n",lat);
    // LATITUDE
    // LONGITUDE
    longitude = start_ptr+1;
    printf ("Longitude starts at gps_string[%d]\n",longitude-gps_string);
    end_ptr=strchr(longitude,',');
    printf ("Longitude ends at gps_string[%d]\n",end_ptr-gps_string-1);
    if (longitude-gps_string>=end_ptr-gps_string)
    {printf("Longitude not received\n");}
    lon=atof(longitude);
    printf("Longitude = %f\n",lon);
    // LONGITUDE
    // QUALITY
    quality = start_ptr+1;
    printf ("Quality starts at gps_string[%d]\n",quality-gps_string);
    end_ptr=strchr(quality,',');
    printf ("Quality ends at gps_string[%d]\n",end_ptr-gps_string-1);
    if (quality-gps_string>=end_ptr-gps_string)
    printf("Quality not received\n");
    qual=atoi(quality);
    printf("Quality = %d\n",qual);
    if (qual==1|qual==2){
    printf("Fix acquired\n");
    else{
    printf("Fix not aquired\n");
    int main(void)
    UINT32 menu_choice;
    UARTConfigure(UART2, UART_ENABLE_PINS_TX_RX_ONLY);
    //UARTSetFifoMode(UART2, UART_INTERRUPT_ON_TX_NOT_FULL | UART_INTERRUPT_ON_RX_NOT_EMPTY);
    UARTSetLineControl(UART2, UART_DATA_SIZE_8_BITS | UART_PARITY_NONE | UART_STOP_BITS_1);
    UARTSetDataRate(UART2, GetPeripheralClock(), 4800);
    UARTEnable(UART2, UART_ENABLE_FLAGS(UART_PERIPHERAL | UART_RX | UART_TX));
    while(1)
    if(gps_string[0]=='$' && gps_string[1]=='G' && gps_string[2]=='P' && gps_string[3]=='G' && gps_string[4]=='G')
    parse(gps_string);
    while(1)
    UINT32 rx_size;
    rx_size = GetDataBuffer(gps_string, 1);
    SendDataBuffer(gps_string, rx_size);
    return -1;
    // void UARTTxBuffer(char *buffer, UINT32 size)
    void SendDataBuffer(char *buffer, UINT32 size)
    while(size)
    while(!UARTTransmitterIsReady(UART2))
    UARTSendDataByte(UART2, *buffer);
    buffer++;
    size--;
    while(!UARTTransmissionHasCompleted(UART2))
    // UINT32 GetDataBuffer(char *buffer, UINT32 max_size)
    UINT32 num_char;
    num_char = 0;
    while(num_char < max_size)
    UINT8 character;
    while(!UARTReceivedDataIsAvailable(UART2))
    character = UARTGetDataByte(UART2);
    // if(character == '\r')
    // break;
    *buffer = character;
    buffer++;
    num_char++;
    return num_char;
    Ragazzi questo e' tutto il codice scritto per PIC32
    Mi dà questi errori
    ource\main.c: In function `parse':
    source\main.c:32: warning: implicit declaration of function `strchr'
    source\main.c: At top level:
    source\main.c:128: error: conflicting types for 'SendDataBuffer'
    source\main.c:17: error: previous declaration of 'SendDataBuffer' was here
    non capisco.... sto impazzendo.....aiuttoooooooooooooooooooo
    grazie a tutti....
    Sep 2003
    INDIA
    Could you please show me how to extract the speed component from $GPRMC, its variable lenght......
    Thank you.
  1. GPS decoding problems
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 25th February 2012, 11:57
  2. GPS Logging
    By eoasap in forum GPS
    Last Post: - 14th February 2006, 18:22
  3. GPS logger?
    By Gonzzo in forum Off Topic
    Last Post: - 13th February 2006, 14:25
