USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    Mar 2009
    Colorado
    Default Question re: DT_INTS
    Also, don't mess with all the INTCON and RCON registers.
    DT_INTS handles all those for you.
    If you change them, it can interfere with the interrupt system.
    Darrel, I have discovered that when I am using INT2_INT interrupt source from DS1337 to the 18F4550 that I have to have the INTCON2 statement per below code...otherwise the interrupt doesn't work. When you said that I shouldn't mess with the INTCON register settings because DT_INTS takes care of them, did you mean only the GIE setting?? In fact, can you explain which of the INTCON register settings ARE NOT handled by DT_INTS, if more than just this one for INT2 falling edge??
    '----------------------[ SETUP FOR INTERRUPTS ]-------------------------
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            ;INT_Handler   USB_Handler
            INT_Handler   INT2_INT,        _Alarm,   PBP,  yes
        INT_CREATE                ; Creates the interrupt processor
    @    INT_ENABLE   INT2_INT     ; enable external (INT) interrupts
    ' Per DT, DT_INTS already takes care of setting INTCON and RCON registers
    ' but this doesn't work unles INTCON2 set per below:
        'INTCON.7 = 1         ' Set Global Interrupt Enable bit
        INTCON2 = %00000000  ' Set INT2 for falling edge (Bit4-low)
                             ' on RTC's interrupt.
        'INTCON3 = %10010000  ' Set INT2 high priority (Bit7-high), enable INT2
                             ' (Bit4-high)
    Enable bits (IE), Interrupt Flags (IF) or Priority bits (IP).
    Don't "mess" with them. That includes GIE and PEIE or GIEL.
    Many interrupt sources have registers that affect the specific peripheral.
    For instance ...
    • If you don't set TXSTA and RCSTA then you will never get proper interrupts from the USART.
    • If you don't set T1CON, you will never get interrupts from TMR1_INT.
    • And ...
      If you don't set the INTEDG bits, you may never get the correct interrupt from INT2_INT.
    You have to tell the hardware how to handle the signals.
    DT_INTS will handle the interrupts.
    Dec 2006
    Hi Guys,
    Ive got a bit of a problem with the USB thats got me stumped and hope you can help.
    Im using DT's interupts and have setup INT_INT to read a DS18S20+ temp sensor which works fine and I can display it on the LCD lovely.
    My problem is that trying to use the USB it works with the interupt for the temp probe ok, but as SOON as I use LCDOUT I get the USB device not recognised
    Even splattering USBSERVICE after all the lines in the main loop it still wont recognise it.
    I have tried both ON INTERUPT and DT's TMR0_INT for the USBSERVICE but nothing I do will get it working unless the LCDOUT is removed.
    I can post the code if required but thought I would just write the problem first in case its something obvious im missing.
    Many thanks,
    Mark
    Dec 2006
    Doh, I suppose I should have looked a bit more deeply on the forum! lol.
    I did see this ages ago and it slipped my memory, but found DT's USB_ASM_Service file and tried that and BINGO! sorted it PHEW!
    Must say thanks to DT as it seems that whenever I see someone (even myself!) get stuck with something, a quick delve into the forums usually finds a post by Darrel that sorts it!
    Mark
    Dec 2010
    Tokyo
    Default USBout sends garbage byte ahead of message
    I am new and this is my first posting, please don't shoot me in case of mistakes.
    Today I started to use PicPasic Pro 2.6 with MPLAB IDE 8.60 and tried out the usb_demo.bas sample immediately.
    MPLAB file list:
    CDC_DEMO.BAS
    CDC_DESC.BAS
    USB_CDC.ASM
    USB_CDC.INC
    USB_MEM.ASM
    USB_DEV.ASM
    USB_DEV.INC
    CDC_DEMO.BAS Code:
    ' USB sample program for PIC18F4550 CDC serial port emulation
    '  Requires PBP 2.60 or later
    '  Compilation of this program requires that specific support files be
    '  available in the source directory.  For detailed information, see
    '  the file PBP\USB18\USB.TXT.
    	Include	"cdc_desc.bas"	' Include the HID descriptors
    Define  OSC     48
    buffer	Var	Byte[16]
    cnt	Var	Byte
    	OSCTUNE.6 = 1		' Enable PLL for 18F87J50 family
    	Pause 10
    	USBInit			' Get USB going
    ' Wait for USB input
    idleloop:
    	USBService		' Must service USB regularly
    	cnt = 16		' Specify input buffer size
    	USBIn 3, buffer, cnt, idleloop
    ' Message received
    	buffer[0] = "H"
    	buffer[1] = "e"
    	buffer[2] = "l"
    	buffer[3] = "l"
    	buffer[4] = "o"
    	buffer[5] = " "
    	buffer[6] = "W"
    	buffer[7] = "o"
    	buffer[8] = "r"
    	buffer[9] = "l"
    	buffer[10] = "d"
    	buffer[11] = 13
    	buffer[12] = 10
    	buffer[13] = 0
    outloop:
    	USBOut 3, buffer, 14, outloop
    	Goto idleloop		' Wait for next buffer
    The test program in the PC is a simple VB6 routine:
    ;---------------- Write to PIC --------------------------
    Private Sub Out3Byte(bus As Byte, adr As Byte, data As Byte)
    Dim Com(2) As Byte
    Com(0) = bus: Com(1) = adr: Com(2) = data
        '3 byte send
        MSComm1.Output = Com
    End Sub
    ;----------------- Receive from PIC ----------------------
    Private Sub MSComm1_OnComm()
    Dim data As String, ende As Boolean
    ende = False: Text1.Text = ""
        Static IsActive As Boolean
        MSComm1.RThreshold = 0
        If IsActive Then
            Label4.Caption = "OnComm Ueberschneidung"
           Exit Sub
        End If
            Do Until ende
                If MSComm1.InBufferCount > 1 Then     'min 1byte recvd
                data = MSComm1.Input
                Text1.Text = Text1.Text + Hex$(AscB(data)) + " "
                Else
                ende = True
                End If
            DoEvents
            Loop
    IsActive = False
    MSComm1.RThreshold = 1
    End Sub
    In general it works fine but, for one little but crucial problem I cant find the reason, so I suspect the problem to be with the PBP compilation.
    The 3 bytes from the PC are always received properly, but the "Hello World" message arrives in the PC correctly only the first time immediately after Com Port Open statement. When continuously sending and receiving, at the beginning of the messages there is always one garbage byte ahead of "Hello World". The value is always the same, but depends one actual memory location in PIC RAM of "buffer Var Byte[16]"
    Can anyone help?
    CDC_DEMO_transmission_log:
    35	VB6.EXE	IOCTL_SERIAL_SET_BAUD_RATE	USBSER000	SUCCESS	Rate: 115200
    36	VB6.EXE	IOCTL_SERIAL_CLR_RTS	USBSER000	SUCCESS
    37	VB6.EXE	IOCTL_SERIAL_SET_DTR	USBSER000	SUCCESS
    38	VB6.EXE	IOCTL_SERIAL_SET_LINE_CONTROL	USBSER000	SUCCESS	StopBits: 1 Parity: NONE WordLength: 8
    39	VB6.EXE	IOCTL_SERIAL_SET_CHAR	USBSER000	SUCCESS	EOF:1a ERR:0 BRK:0 EVT:0 XON:11 XOFF:13
    40	VB6.EXE	IOCTL_SERIAL_SET_HANDFLOW	USBSER000	SUCCESS	Shake:1 Replace:0 XonLimit:8000 XoffLimit:8000
    41	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    42	VB6.EXE	IRP_MJ_WRITE	USBSER000	SUCCESS	Length 3: A1 A9 AF	<3 bytes send
    43	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    44	VB6.EXE	IOCTL_SERIAL_SET_WAIT_MASK	USBSER000	SUCCESS	Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
    45	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    46	VB6.EXE	IOCTL_SERIAL_WAIT_ON_MASK	USBSER000	SUCCESS
    47	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    48	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 48 	   <----- Starts with "H"
    49	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    50	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    51	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 65
    52	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    53	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    54	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    55	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    56	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    57	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    58	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    59	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    60	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6F
    61	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    62	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    63	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 20
    64	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    65	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    66	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 57
    67	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    68	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    69	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6F
    70	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    71	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    72	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 72
    73	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    74	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    75	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    76	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    77	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    78	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 64
    79	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    80	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    81	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 0D
    82	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    83	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    84	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 0A
    85	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    86	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    87	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    88	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    89	VB6.EXE	IOCTL_SERIAL_GET_PROPERTIES	USBSER000	SUCCESS
    90	VB6.EXE	IRP_MJ_WRITE	USBSER000	SUCCESS	Length 3: A1 A9 AF	<3bytes send
    91	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    92	VB6.EXE	IOCTL_SERIAL_SET_WAIT_MASK	USBSER000	SUCCESS	Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
    93	B6.EXE	IOCTL_SERIAL_WAIT_ON_MASK	USBSER000	SUCCESS
    94	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    95	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    96	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 00		<----- starts with "0x00"
    97	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    98	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    99	B6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 48 		<----- "H" is 2nd byte
    100	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    101	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    102	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 65
    103	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    104	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    105	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    106	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    107	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    108	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    109	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    110	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    111	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6F
    112	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    113	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    114	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 20
    115	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    116	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    117	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 57
    118	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    119	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    120	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6F
    121	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    122	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    123	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 72
    124	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    125	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    126	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 6C
    127	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    128	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    129	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 64
    130	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    131	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    132	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 0D
    133	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    134	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    135	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 0A
    136	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    137	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    138	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    139	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    140	VB6.EXE	IOCTL_SERIAL_GET_PROPERTIES	USBSER000	SUCCESS
    141	VB6.EXE	IRP_MJ_WRITE	USBSER000	SUCCESS	Length 3: A1 A9 AF	<3 bytes send
    142	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    143	VB6.EXE	IOCTL_SERIAL_SET_WAIT_MASK	USBSER000	SUCCESS	Mask: RXCHAR TXEMPTY CTS DSR RLSD BRK ERR RING
    144	VB6.EXE	IOCTL_SERIAL_WAIT_ON_MASK	USBSER000	SUCCESS
    145	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    146	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    147	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 00 <garbage again
    148	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    149	VB6.EXE	IOCTL_SERIAL_GET_COMMSTATUS	USBSER000	SUCCESS
    150	VB6.EXE	IRP_MJ_READ	USBSER000	SUCCESS	Length 1: 48
    Dec 2010
    Tokyo
    Default USBOut out byte mixup
    I am still stuck with my proplem, therefore, I modified the cdc_demo.bas to be able to change the outbuffer contents:
    Define  OSC     48
    inbuffer	Var	Byte[15]
    outbuffer	Var	Byte[15]
    icnt	Var	Byte
    ocnt	Var	Byte
    	Pause 10
    idleloop:
    	icnt = 6		' Specify input buffer size
    	USBIn 3, inbuffer, icnt, idleloop
    ' Message received
    	outbuffer[0] = inbuffer[0]
    	outbuffer[1] = inbuffer[1]
    	outbuffer[2] = inbuffer[2]
    	outbuffer[3] = inbuffer[3]
    	outbuffer[4] = 0
    	outbuffer[5] = icnt
    	outbuffer[6] = 0
    	outbuffer[7] = $AA
    	outbuffer[8] = $BB
    	outbuffer[9] = $CC
    	outbuffer[10] = $DD
    	outbuffer[11] = 0
    	outbuffer[12] = inbuffer[0]
    	outbuffer[13] = inbuffer[1]
    	outbuffer[14] = inbuffer[2]
    outloop:
    	ocnt = 14
    	USBOut 3, outbuffer, ocnt, outloop
    I continued testing and found out:
    With ocnt = 14
    The first USBOut after com port open in PC test program is actually
    outbuffer[0]....outbuffer[12] -> in total 13 bytes
    from the second output it is always the same
    outbuffer[13], outbuffer[0], outbuffer[1]...., outbuffer[12] ->in total 14 bytes
    I suspect in the appended .inc and .asm files might be a definition mistake, but since I do not understand the code written there, I really need the help of an USB specialist in this Forum to overcome this problem.
    To all the USB experts in this Forum, please Help.
    Last Post: - 14th June 2016, 08:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  3. Replies: 9
    Last Post: - 31st July 2008, 09:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
