USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    You can.
    But before you put it to sleep, you'll need to put the USB module in suspend mode UCON.1, which can only be done reliably when unplugged.
    This disables the USB voltage regulator and stops the clock to the SIE, which will give the lowest current consumption.
    The USB routines are not setup to handle a resume.
    So your best bet it probably to connect the +5V from the USB cable to one of the INT pins with a pull-down resistor.
    When the cable gets plugged in, it will generate an interrupt, at which point you would execute an @ RESET to reset the processor and initialize the USB again.
    HTH
    Mar 2009
    Colorado
    Default Made changes per your suggestions...now an assembly error
    HTH
    OK, so I made changes to my code per your suggestions (see partial code below) including an IF Plugged =1 test in the Main loop to pole for USB connection and go to my USB servicing procedure when connected. I didn't do anything to get SLEEP mode yet because I want to make sure the interrupts are working first in this code.
    This code compiles, but creates a single error during assembly that says
    "Error[101]c:\PathToAsmfile.asm 1132:ERROR:(INT_ENABLE priority state not found)". So I can't get it to run yet with this error.
    I'm not sure what this error is telling me...the required statement for @ INT_ENABLE INT2_INT is in the code. Does it also require an INT_ENABLE USB_HANDLER statement for the USB interrupt??
    Include "Modedefs.Bas"
    INCLUDE "DT_INTS-18.bas"    ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP high priority interrupts
    INCLUDE "ALLDIGITAL.pbp"    ' Sets all registers for digital ops.
    DEFINE OSC 48
    ;--- if you un-comment these, you must comment the ones in the .inc file--
    ASM ; 18F2550/4550, 8mhz crystal
       __CONFIG    _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
       __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
       __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
       __CONFIG    _CONFIG3H, _PBADEN_OFF_3H ; PortB resets as digital
       __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    ' Initialize Hardware
        Spare_1         VAR PORTB.7   ' PGD for ICSP & Spare I/O for normal ops
        Spare_2         VAR PORTB.6   ' PGC for ICSP & Spare I/O for normal ops
        'Set registers
          TRISA = 0             ' PORTA all outputs for LCD use
          TRISB =%00011000      ' RB4 & RB3 set as RTC Alarm1 & Alarm2 inputs
          TRISC = 0
          TRISD = 0
          TRISE = 0
    '------------SETUP FOR USING DS1337 Real Time Clock (RTC)---------------
    ' Setup Hardware for uart
        DEFINE HSER_BAUD 115200
        DEFINE HSER_RCSTA 90h
        DEFINE HSER_TXSTA 24h
        DEFINE HSER_CLROERR 1
    ' Aliased Variables for CLock
        Alarm1      VAR PORTB.4     ' Alarm1 input from DS1337 INTA
        Alarm2      VAR PORTB.3     ' Alarm2 input from DS1337 INTB
        SCL         VAR PORTB.1     ' I2C clock pin
        SDA         VAR PORTB.0     ' I2C data pin
        RTC         CON %11010000   ' RTC device write address(byte addressing)
        ' This is a list of allowable clock contrl settings, one which must be
        ' setup in the SetTimeAndDate subroutine as intended.
        'contrl     CON %00000011   ' Starts the oscillator, sets the SQW/OUT
                                    ' to 1 Hz, enables INTA interrupt from A1F
                                    ' or from A2F.  WORKS as intended!!
        'contrl     CON %00000111   ' Starts oscillator, enables INTA interrupt
                                    ' from A1F or INTB from A2F. WORKS OK!
                                    ' Both interrupts staggered 30 secs apart.
    ' RTC Address definitions
        SecReg      CON $00   ' seconds address (00 - 59)
                              ' MSB of SecReg must be set to a 0 to enable RTC
        MinReg      CON $01   ' minutes address (00 - 59)
        HourReg     CON $02   ' hours address (01 - 12) or (00 - 23)
        DayReg      CON $03   ' day address (1 - 7)
        DateReg     CON $04   ' date address (01 - 28/29, 30, 31)
        MonthReg    CON $05   ' month address (01 - 12)
        YearReg     CON $06   ' year address (00 - 99)
    ' Alarm 1 Address definitions
        Alm1sec     CON $07   ' Alarm 1 seconds address (00 - 59)
        Alm1min     CON $08   ' Alarm 1 minutes address (00 - 59)
        Alm1hr      CON $09   ' Alarm 1 hours address (01 - 12) or (00 - 23)
        Alm1Day     CON $0A   ' Alarm 1 day address (1 - 7)
    ' Alarm 2 Address definitions
        Alm2min     CON $0B   ' Alarm 2 minutes address (00 - 59)
        Alm2hr      CON $0C   ' Alarm 2 hours address (01 - 12) or (00 - 23)
        Alm2Day     CON $0D   ' Alarm 2 day address (1 - 7)
    ' Alias of Clock register addresses
       ContReg     CON $0E         ' CONTROL register address
       StatusReg   CON $0F         ' STATUS register address
    ' Clock Variables
        sec         VAR BYTE  ' seconds
        MINs        VAR BYTE  ' minutes
        hr          VAR BYTE  ' hours
        day         VAR BYTE  ' day
        date        VAR BYTE  ' date
        mon         VAR BYTE  ' month
        yr          VAR BYTE  ' year
    ' ALARM1 VARIABLES
        A1sec       VAR BYTE  ' seconds
        A1MINs      VAR BYTE  ' minutes
        A1hr        VAR BYTE  ' hours
        A1day       VAR BYTE  ' day
    ' ALARM2 VARIABLES
        A2MINs      VAR BYTE  ' minutes
        A2hr        VAR BYTE  ' hours
        A2day       VAR BYTE  ' day
    GoSub SetTimeAndDate        ' Setup current time & alarm settings
    '*----------------SETUP FOR USING USB INTERFACE-------------------------
    INCLUDE "DT_HID260.pbp"
    DEFINE USB_VENDORID    6017
    DEFINE USB_PRODUCTID   2000
    DEFINE USB_VERSION     1
    DEFINE USB_VENDORNAME  "Mister E/DT"
    DEFINE USB_PRODUCTNAME "USBDemo"
    DEFINE USB_SERIAL      "001"
    DEFINE USB_INSIZE      8    ;  IN report is PIC to PC (8,16,32,64)
    DEFINE USB_OUTSIZE     8    ; OUT report is PC to PIC
    DEFINE USB_POLLIN      10   ; Polling times in mS, MIN=1 MAX=10
    DEFINE USB_POLLOUT     10
    ; --- Each USB status LED is optional, comment them if not used ---------
    ; ---They can be assigned to any pin, and no further action is required --
    ;DEFINE USB_LEDPOLARITY 1       ; LED ON State [0 or 1]  (default = 1)
    ;DEFINE USB_PLUGGEDLED  PORTB,7 ; LED indicates if USB is connected
    ;DEFINE USB_TXLED       PORTB,6 ;  "      "     data being sent to PC
    ;DEFINE USB_RXLED       PORTB,5 ;  "      "     data being received from PC
    ;--- Variables ----------------------------------------------------------
    Value0      VAR  WORD
    Value1      VAR  WORD
    X           VAR  WORD
    DUTY1       VAR  WORD
    DUTY2       VAR  WORD
    Old_PORTA   VAR  BYTE
    New_PORTA   VAR  BYTE
    ;--- Setup ADC ----------------------------------------------------------
    DEFINE ADC_BITS 8  ; Number of bits in ADCIN result
    ;--- Initialize ---------------------------------------------------------
    CCPR1L = 0
    CCPR2L = 0
    CCP1CON =   %00001100       ' CCP1, PWM mode
    CCP2CON =   %00001100       ' CCP2, PWM mode
    PR2     =   249             ' 0-1000 duty range
    T2CON   =   %00000101       ' TMR2 on, prescaler 1:4
    TRISB = 0
    OUTPUT PORTC.1
    OUTPUT PORTC.2
    ADCON2.7 = 0       ; left justify    (Change this if ADFM in diff register)
    ADCON1 = %1101     ; AN0/AN1 Analog
    '------------------------SETTINGS FOR INTERRUPTS------------------------
    'Set interrupt related registers
        RCON.7 = 1     ' Set Interrupt Priority Enable bit (Bit7=IPEN)
                             ' to enable priority levels on interrupts
        INTCON.7 = 1         ' Set Global Interrupt Enable bit
        INTCON.6 = 1         ' Set PEIE to enable low priority periph interrupts
        INTCON2 = %10001000  ' Enable PORTB Pull-ups (Bit7-high), set INTEG2
                             ' for falling edge (Bit4-low) on RTC's interrupt.
        INTCON3 = %10001000  ' Set INT2IP high priority (Bit7-high),
                             ' enable INT2IE for interrupt(Bit4-high)
        RTC_INT_FLG  VAR INTCON3.1 'Alias for RB4 INTA interrupt from RTC
    'Setup external interrupt macros
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler   USB_Handler
            INT_Handler   INT2_INT,        _Alarm,   PBP,  yes
        INT_CREATE                ; Creates the interrupt processor
    @    INT_ENABLE   INT2_INT     ; enable external (INT) interrupts
    '  -----------------------BEGIN MAIN PROGRAM LOOP-----------------------
        Pause 1000
        IF Plugged = 1 THEN
            HIGH PORTC.6
            GOTO USB  ' USB cable is plugged-in
        ' Else, do other things if not connected
        ' If Alarm interrupt, read current time & ALARM settings from DS1337
        ' Perform range measurements if Midnight
        LOW PORTC.6
    USB:
        'Process data from EEPROM to PC via USB interface
        GoTo Main                       ' Endless Loop
    End     ' Safety measure to insure program stops if reaches here
    '--------------------( Begin Interrupt Handler )------------------------
    Alarm:
           HIGH PORTC.7      ' Test LED if Interupt
           '  Put code here to service the Alarm interrupt
           LOW PORTC.7
        ' Resume Main Program
    @ INT_RETURN
    '------------------{ End of Interrupt Handler }---------------------------
    ' START LIST OF SUBROUTINES
    Put the Interrupt definitions before the HID stuff.
    That's the way it was originally. But it got reversed in your program.
    Also, don't mess with all the INTCON and RCON registers.
    DT_INTS handles all those for you.
    If you change them, it can interfere with the interrupt system.
    Mar 2009
    Colorado
    Default A couple of more questions re: USBDemo
    Darrel, first of all let me commend you on they way you created the USBdemo. It has been a god send to me to save time in getting my application to work with a USB interface. However, I have a couple of more questions:
    1) I notice that this declaration implies you must use BufferIn(X) where X is either 8.16, 32, or 64.
    "DEFINE USB_INSIZE 8 ; IN report is PIC to PC (8,16,32,64)"
    Is that true also with the BufferOut(X) per this statement?
    I ask this question because I need 10 data elements per BufferOut transmission for my application and didn't know whether I could size the BufferOut as 10 or would have to use 16.
    2) In my application I need the PIC to read individual Bytes out of EEPROM and then send them as data to the PC via the USB interface. The data is stored in EEPROM during normal ops as 75 data sets, each data set consisting of 3 bytes. The PIC code reads each data set into a three element array, arrData(i,j,k), where i, j,k range from 0 to 74. My question is how to code the PIC to best fit this data into the BufferOut array to send each arrData(i,j,k) over the USB interface, at the rate of one per second. The data is in the PIC code in the form of:
    arrData(0,0,0)
    arrData(1,1,1
    arrData(2,2,2)
    arrData(74,74,74)
    I want each data set to show up at the PC as the three bytes contained in the array element. I guess my question is in essence how to convert each array element into the three BufferOut(X) bytes for transmission.
    3) I also notice that the PC's RX Window of my application is showing continuous receipt of a e garbagvalue shown as "p|?|6||", even when none of the PORTA pushbuttons are pressed. But when PORTA.4 button is pressed, the string value "USBDemo" is correctly received. However, when any of the other PORTA buttons are pressed it has no impact on the data stream and just shows another "p|?|6||". All other functions of the USBDemo interface work OK. It almost seems like there is a continuous button bounce going on in PORTA, but causing transmit of garbage values rather than the "USBDemo" string. I don't have a debug ability to see what is causing this. Any ideas?? If seeing my code would help you to assess this, let me know and I will somehow get it to you.
    Both USB_INSIZE and USB_OUTSIZE can only be 8,16,32 or 64.
    If you want to send 10-bytes per report, it needs to be 16.
    Question 2, I don't understand.
    If you have them in arrays, just copy them to the USBTXBuffer.
    And what looks like "garbage data" is the analog reading from the pots being sent periodically.
    Mar 2009
    Colorado
    Default Question2??
    That is my problem...I don't know how to structure the code to write each array element of arrData(i,j,k) to the USBTXbuffer. Each of the elements of the USBTXbuffer is a single byte, whereas each element of the array is 3 bytes.
    Are you saying I will still need to parse each array element into 3 bytes and then load each byte into one of the output buffer bytes??
    Arrays in PBP can be byte or word. Not 3 bytes wide. So, what Darrel suggested is still valid.
    I suppose that you don't know how to read 3 bytes everytime into a 8-byte buffer?
    If so, just fill the rest with zero.
    Mar 2009
    Colorado
    Default Question re: DT_INTS
    Darrel, I have discovered that when I am using INT2_INT interrupt source from DS1337 to the 18F4550 that I have to have the INTCON2 statement per below code...otherwise the interrupt doesn't work. When you said that I shouldn't mess with the INTCON register settings because DT_INTS takes care of them, did you mean only the GIE setting?? In fact, can you explain which of the INTCON register settings ARE NOT handled by DT_INTS, if more than just this one for INT2 falling edge??
    '----------------------[ SETUP FOR INTERRUPTS ]-------------------------
            ;INT_Handler   USB_Handler
    ' Per DT, DT_INTS already takes care of setting INTCON and RCON registers
    ' but this doesn't work unles INTCON2 set per below:
        'INTCON.7 = 1         ' Set Global Interrupt Enable bit
        INTCON2 = %00000000  ' Set INT2 for falling edge (Bit4-low)
                             ' on RTC's interrupt.
        'INTCON3 = %10010000  ' Set INT2 high priority (Bit7-high), enable INT2
                             ' (Bit4-high)
    Enable bits (IE), Interrupt Flags (IF) or Priority bits (IP).
    Don't "mess" with them. That includes GIE and PEIE or GIEL.
    Many interrupt sources have registers that affect the specific peripheral.
    For instance ...
    • If you don't set TXSTA and RCSTA then you will never get proper interrupts from the USART.
    • If you don't set T1CON, you will never get interrupts from TMR1_INT.
    • And ...
      If you don't set the INTEDG bits, you may never get the correct interrupt from INT2_INT.
    You have to tell the hardware how to handle the signals.
    DT_INTS will handle the interrupts.
    Dec 2006
    Hi Guys,
    Ive got a bit of a problem with the USB thats got me stumped and hope you can help.
    Im using DT's interupts and have setup INT_INT to read a DS18S20+ temp sensor which works fine and I can display it on the LCD lovely.
    My problem is that trying to use the USB it works with the interupt for the temp probe ok, but as SOON as I use LCDOUT I get the USB device not recognised
    Even splattering USBSERVICE after all the lines in the main loop it still wont recognise it.
    I have tried both ON INTERUPT and DT's TMR0_INT for the USBSERVICE but nothing I do will get it working unless the LCDOUT is removed.
    I can post the code if required but thought I would just write the problem first in case its something obvious im missing.
    Many thanks,
    Mark
    Dec 2006
    Doh, I suppose I should have looked a bit more deeply on the forum! lol.
    I did see this ages ago and it slipped my memory, but found DT's USB_ASM_Service file and tried that and BINGO! sorted it PHEW!
    Must say thanks to DT as it seems that whenever I see someone (even myself!) get stuck with something, a quick delve into the forums usually finds a post by Darrel that sorts it!
    Mark
    Last Post: - 14th June 2016, 08:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  3. Replies: 9
    Last Post: - 31st July 2008, 09:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
