USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    Mar 2009
    Colorado
    Default Working!..a couple of more questions.
    Do you have anything on RB0, RC1 or RC2.
    I've got some Status outputs to LED's on those pins, that shows when it's connected and when it sends/receives data.<br>
    Thanks, Darrel...this led me to the problem. The EasyPic6 has dip-slide switches that let you connect LEDs to the A/E, B, C, and D ports for troubleshooting. I had the switch selected for Ports B and C. When I finally realized I needed to shut them off everything started working properly.
    However, one question. I notice while running MisterE's VB6 monitor side-by-side with your DT_HID monitor I see the Rx data showing some variances. I have attached a screen-snapshot of this so you can see.
    Notice in the screen snapshot that when when AN=123, AN0= 1023; when AN=51, AN0=510, and when AN=-4, AN0=0. Since both are receiving the same data as transmitted by the PIC, shouldn't the displayed values be equal in both monitors??? Don't understand this. Can you explain for me??
    My next step is to figure out how to capture what appears in the DT_HID Rx data window into a text file or better yet into a spreadsheet. Any suggestions as to how to do this in the DT_HID code?,
    Great, I thought I lost you.
    The program is sending different data than mister-e's PC program is expecting.
    I guess my example was off thread, and I should make an example that does work with his GUI.
    In Delphi sure ... can't help with Visual Basic though.
    It may even be easier with CDC and Hyperterminal.
    Outputting the data in CSV format from the PIC, and capturing it with the terminal, makes it real easy to import into excel. But it does require user intervention.
    If it's has to be automatic, HID's the way, whether it's DDE exchanges, or saving the file and importing to excel.
    Anyhow, I'll go make a more appropriate demo for Steve's GUI.
    BBL,
    OK, this program should work with Steve's original USBDemo GUI.
    18F2550/4550, 8Mhz, DT_INTS-18, DT_HID260.
    Cheers,
    Mar 2009
    Colorado
    Default Data from PIC works...data to PIC doesn't
    Darrel,
    Everything compiles/assembles/programs in my EasyPic6 configuration with 18F4550 (8 MHz crystal), and it does run with Steve's VB6 GUI, but only for data from the PIC....data to PIC side of the GUI doesn't work. I double checked that I didn't have anytheng on the EasyPic6 connected to the pins you are using. See attached screen snapshot of the VB6 GUI that shows what is working and what isn't.
    I also notice that when I remove the comments on the DEFINE statements for the status LEDs that they do not light during the PLUGGED, TX or RX actions are supposedly taking place that they are suppose to indicate.
    I looked at your code and I couldn't see where the problem is. Any ideas??
    Last edited by jellis00; - 10th November 2009 at 20:24. Reason: Added comments re: status LEDs
    The ones on the left require 8-LEDs on PORTB, and 2 other LEDs on the CCP outputs, RC1/RC2.
    Previously you said you disconnected the LED's to get things working with the EasyPIC.
    The USB D-/D+ are on RC4/RC5, so I don't think you can just enable the whole bank of LED's on PORTC. You'll need to attach LEDs to only the 2 CCP Pins to get the faders working. But you should be ok with LEDs on PORTB.
    HTH,
    Mar 2009
    Colorado
    Talking Working as advertised! Another question.
    Turns out you can enable all the whole bank of LED's on PORTC and it keeps working. You can then see the LEDs on RC1 and RC2 vary in brightness as you change the sliders.
    Except for the LEDs on RB0, RB5, Rb6 & RB7 (which are used in your code) you can now click the check boxes on B1 thru B4 on the VB6 Gui and they work to light the corresponding LEDs.
    I now have Steve's VB6 GUI and the DT_HID monitor running side by side and everything works as advertised except for the exceptions I listed above for the B0 thru B7 check boxes. Your support to me in getting to this has been outstanding, Darrel. Thanks so much!
    Now I only have to figure out how to capture the data coming across the USB interface from the PIC into a spreadsheet. Your suggestion to use CDC and HYPERTERM would be an easier option except that my application requires a USB interface that is also used to connect to a cell phone, and I don't have physical room for both an RS232 and a USB interface within the physical board size contstraint or panel connector space. Looks like I have to figure out how to do the capture in Steve's USB VB6 GUI. I will modify the PIC side to send comman delimited data per your suggestion, but don't know how to approach capturing the comma delimited data from the VB6 USB Gui that is showing into a spreadsheet. Can you refer me to any forum ideas or reference tutorials in this area??
    Thanks again, Darrell. Your contributions & presence on this forum is what makes it worthwhile.
    PORTB.0 is not used anywhere in the program (other than output from the Demo).
    PORTB.5-7 are only used if the USB Status LED lines are uncommented (I left them commented). And they can be assigned to any pin, they don't have to be PORTB.5-7
    CDC is USB, there's no RS232 connector.
    In excel, use the Data | Import External Data | Import Data menu item to just plop your CSV file right into your spreadsheet. Then when the data changes, use Data | Refresh Data to update everything automatically.
    Last Post: - 14th June 2016, 08:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  3. Replies: 9
    Last Post: - 31st July 2008, 09:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
