USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    Nov 2009
    Australia
    Default Problems with ASM
    G'day
    Have 2.60 PBP and did the latest setup etc as per the last few posts.
    I now get the following errors when compiling.
    ERROR: Unable to execute mpasmwin.Error[118] C:\PBP\USBDEMO260\USBDEMO.ASM 413 : Overwriting previous address contents (0000)
    Error[118] C:\PBP\USBDEMO260\USBDEMO.ASM 413 : Overwriting previous address contents (0001)
    etc.
    Any ideas,
    Tks
    Quote Originally Posted by OzGrant View Post
    etc.
    OzGrant,
    See this thread about how to fix the configs ...
    http://www.picbasic.co.uk/forum/show...=6775#post6775
    jellis00,
    Uno momento ...
    Nov 2009
    Australia
    Default Asm ok
    Darrel,
    Tks it of course fixed the error. I should spend more time searching the forum, that trying to solve the problem, and then by default put up a newbee sort of question. Will now wait for my Picstart Plus upgrade kit so I can burn the 18F4550 and have even more fun. Will now search the forum before I ask my next question "does the mcHID.dll work with VB5"
    Tks again.
    Grant
    Mar 2009
    Colorado
    Default Here are the 18F4550 _CONFIG settings
    [QUOTE=Darrel Taylor;80423]OzGrant,
    Attached .txt document is a list of the _CONFIG settings for the 18F4550 from its corresponding P18F4550.INC file in MPLAB folder. It is always a good idea to have this list handy when setting up code for a new program.
    Mar 2009
    Colorado
    Default This time with the list
    [QUOTE=jellis00;80428
    Attached .txt document is a list of the _CONFIG settings for the 18F4550 from its corresponding P18F4550.INC file in MPLAB folder.QUOTE]
    Forgot to attach with previous post.
    Mar 2009
    Colorado
    Default Try this
    Make sure you commented out the _config statements in the 18F4550.inc file and resaved it. If you don't the _config statements in the USBDemo code will give this type of error. I don't have any ideas as to the other error...sorry!
    What is your development environment?....editor (MicroCode Studio, MPALAB or what?)...assembler (MPASM or PM?).....programmer (PicKit2, EasyPic or what?)
    USBDemo was a good starting point for me, Thanks Steve.
    But there are several problems that don't coincide with what you want.
    1) When you disconnect the cable, it will still try to send data, causing the PIC to enter a Locked Loop, waiting to send to an inactive bus.
    2) You really have no indication that anything was received.
    If there's no incoming data, it just goes ahead and sets the dutycycles again, using the old data left over in the buffer.
    3) There's no indication of when it's connected, when something was received or when it's ok to send.
    4) With the 1mS servicing from Timer0, it's a bit sluggish when enumerating, overall data rates suffer and it uses TMR0 when it doesn't need to.
    5) EasyHID no longer works with 2.60, so it's difficult to make changes to the descriptors.
    6) I don't use Visual Basic, so I can't update the PC program.
    My main language is Delphi, and I stopped using mchid.dll a long time ago.
    I would have worked with Steve to build a better demo, but alas, he's not here.
    <hr>
    I'm thinking it's time to unveil DT_HID.
    It's the PIC side of USB, made ... yes, I'll say it ... EASY!
    The PC side is still up to you, but it even works with Steve's original VB prog, so that, or any other VB/Delphi program from EasyHID can be used as a "template".
    I'm not even going to tell you how it works.
    I defy you to not understand what it does.
    Up until you ask a question.
    Warning, the example is setup for 13K50/14K50.
    Comment the configs, and uncomment the other configs (if needed).
    Change ANSELs to ADCON1 (if needed).
    Also note: This is for PBP 2.60 only.
    BasicUSB.pbp is the test program.
    Don't shoot me, I can't even play a piano ...
    Mar 2009
    Colorado
    Question Compiles and programs but USB doesn't connect
    USBDemo Warning, the example is setup for 13K50/14K50.
    I made these changes to the BasicUSB.pbp code for use with 18F4550 as you can see in my listed code below. It compiles OK into a .hex file which I then programmed into the 18F4550 using the PicFlash programmer in my EasyPic6. By all appearances everything was OK until I turned on power to the MCU with Steve's VB6 program running....at that point the USB connection was not recognized and nothing else happened. Can you look at this code and tell me what is wrong. I made shure both the include files were in the PBP folder and since it compiled I interpreted that to mean the INCLUDES were OK. Since I was able to get Steve's code to run in my EasyPic6 I believe that eliminates the VB6 code as the problem, so need to figure out how to debug yours and when it doesn't connect or do anything visible, I don't know how to debug it.
    I studied the code in both the test program and in DT__HID.bas and unfortunately I guess I don't understand what it does since I can't get it to work. I need your HELP.
            '*  Name    : BasicUSB.pbp        *
            '*  Author  : Darrel Taylor       *
            '*  Notice  : Copyright (c) 2009  *
            '*  Date    : 7/23/2009           *
            '*  Version : 1.0                 *
            '*  Notes   :                     *
    ;--- if you un-comment these, you must comment the ones in the .inc file ---
    ASM  ; 18F2550/4550, 8mhz crystal as used in EasyPic6
       __CONFIG    _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
       __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
       __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
       __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    ASM  ; 18F13K50/14K50  Only 12mhz crystal can be used for USB
    ;    __CONFIG    _CONFIG1L, _CPUDIV_NOCLKDIV_1L & _USBDIV_OFF_1L
    ;    __CONFIG    _CONFIG1H, _FOSC_HS_1H & _PLLEN_ON_1H & _PCLKEN_ON_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    DEFINE OSC 48
    clear
    ;--- Setup Interrupts ------------------------------------------------------
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INT_LIST  macro    ; IntSource,          Label,  Type, ResetFlag?
            INT_Handler   USB_Handler
    endasm
    ;--- Setup USB -------------------------------------------------------------
    INCLUDE "DT_HID260.pbp"
    DEFINE USB_VENDORID    6017
    DEFINE USB_PRODUCTID   2000
    DEFINE USB_VERSION     1
    DEFINE USB_VENDORNAME  "Darrel Taylor"
    DEFINE USB_PRODUCTNAME "DT_HID"
    DEFINE USB_SERIAL      "001"
    DEFINE USB_INSIZE      32   ; IN report is PIC to PC (8,16,32,64)
    DEFINE USB_OUTSIZE     16   ; OUT report is PC to PIC
    DEFINE USB_POLLIN      10   ; Polling times in mS, MIN=1 MAX=10
    DEFINE USB_POLLOUT     10
    ; --- Each USB LED is optional, comment them if not used ----
    DEFINE USB_LEDPOLARITY 1       ; LED ON State [0 or 1]  (default = 1)
    DEFINE USB_PLUGGEDLED  PORTB,0 ; LED indicates if USB is connected
    DEFINE USB_TXLED       PORTC,2 ;  "      "     data being sent to PC
    DEFINE USB_RXLED       PORTC,1 ;  "      "     data being received from PC
    OutCount    VAR  WORD : OutCount = 0
    Value       VAR  WORD
    X           VAR  WORD
    ;--- Setup ADC -------------------------------------------------------------
    DEFINE ADC_BITS 10  ; Number of bits in ADCIN result
    ADCON2.7 = 1        ; right justify    (Change this if ADFM in diff register)
    ADCON1 = %00010000  ; AN4/RC0 Analog
    'ANSELH = 0
    ;--- The Main Loop ---------------------------------------------------------
        FOR X = 0 to 1000           ; Check for incomming USB data while pausing
    @     ON_USBRX_GOSUB  _HandleRX
          PAUSE 1
        NEXT X
        ADCIN 4, Value
        OutCount = OutCount + 1
        ARRAYWRITE USBTXBuffer,["AN0=",DEC Value," -",DEC OutCount,"  "]
        IF Plugged THEN GOSUB DoUSBOut     ; only send when USB is connected
    GOTO Main
    ;---- This just sends the received packet back to the PC -------------------
    HandleRX:
        ARRAYWRITE USBTXBuffer,[STR USBRXBuffer\USBBufferSizeRX]
    Apparently, I missed the CONFIG2L.
    I always miss that one, weird ...
       __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
    And try the HIDmonitor program from the .zip
    When I said it works with Steve's original program, well it will, but it's not set up to send/receive the same analog values and switches/LED's. With HIDmonitor you should see when it connects and what data it's sending.
    hth,
    Mar 2009
    Colorado
    Default Made config change..compiles, nothing happening
    [QUOTE=Darrel Taylor;80452]Apparently, I missed the CONFIG2L.
    I made this _CONFIG change in the code. Compiles/assembles OK and appears to program the 18F4550 OK.
    Tried both your HIDmonitor and Steve's VB6 routine after programming and power/resetting the 18F4550 . Although I hear a low "click" and see the USB icon appear in my WINDOWS tray when the USB cable is connected from the PC, I don't see any indication of the connection on the HIDmonitor or on Steve's VB6. And the USB icon disappears out of the tray about 10 secs after the next keyboard key or mouse button is pressed with no audible "click". Nor do I hear another "click" or see any visual indication of disconnect when USB cable is disconnected. Nor is there any indication of any communications on either the HIDmonitor or the VB6 window.
    Do you have any suggestions how I might monitor what is happening in the code while running so I can debug? I don't have a usable ICD.
    Before I posted last time, I copied your program to MCS, added the config2L and changed my crystal to 8mhz.
    It fired right up, and is still connected now.
    It shows up as DT_HID (001) in HIDmonitor.
    Do you have anything on RB0, RC1 or RC2.
    I've got some Status outputs to LED's on those pins, that shows when it's connected and when it sends/receives data.
    You did have the hardware working before right?
    Default Re: USBDemo, something to learn USB a little bit
    Also note: This is for PBP 2.60 only ...
    Someone found a workaround for PBP 3:
    http://www.picbasic.co.uk/forum/show...599#post126599
    Last Post: - 14th June 2016, 08:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  3. Replies: 9
    Last Post: - 31st July 2008, 09:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
