USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    Aug 2008
    Tucson AZ
    PortB is a byte value. A byte runs 0-255...
    2 ^ 15 = 32,768 which is greater than 255!
    I tried changing the variable, PortB to an Integer and Long with no positive results
    Quote Originally Posted by Philtkp View Post
    Well of course it won't work.
    PortB is a Visual Basic Byte variable (or whatever you want) which gets stored in a Byte Array and sent over the USB to the PIC as a Byte variable stored in a Byte array, which is then stored in the PIC as a Byte variable.
    Private Sub Check1_Click(index As Integer)
    ' Convert PORTB check box to decimal value before sending it
    ' to USB bus. Result is store in BufferOut(1)
    Dim LoopCheck, PORTB As Byte
    PORTB = 0
    For LoopCheck = 0 to 15 ' 0 To 7
    PORTB = PORTB + (Check1(LoopCheck).Value * (2 ^ LoopCheck))
    Next
    BufferOut(1) = PORTB
    WriteSomeData
    End Sub
    Aug 2008
    Tucson AZ
    Can this be done using an array of bytes?
    You ARE sending out an array of bytes...8 of them, unless you've messed with the HID-Maker.
    You have to send out more bytes or figure out a way to 'encode' those bytes you've already got to do more...
    Last Post: - 14th June 2016, 07:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  3. Replies: 9
    Last Post: - 31st July 2008, 08:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
    Last Post: - 6th March 2005, 01:07
