USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    Jan 2007
    Brazil
    Hello..
    I'm using 18F2550 and USB is working very well... I've been trying to increase the buffer size from 8 to 16 but it do not work.
    On Pic's code, I've only changed this:
    BufferSize      con 16
    ' BufferSize      con 8
    On VB's code, this:
    Private Const BufferInSize = 16
    ' Private Const BufferInSize = 8
    Any idea of what is the problem?
    Thanks!!
    Sylvio,
    The IN/OUT "Report" length is usually set in one of the easyHID dialogs.
    Or it can be changed manually in the Descriptor file.
    If you re-run easyHID for the same project, it will wipe out any changes you've made. So create a new project, set everything the way you want it in easyHID, then just copy the descriptor file to your existing project.
    hth,
    Jan 2007
    Brazil
    Done! Perfect Darrel!
    Thanks a lot!
    Sylvio,
    Aug 2008
    Tucson AZ
    Hello,
    First, Mister e This is an outstanding demo. Was able to get running right out of the box on a PIC18f4550.
    I've been trying to add an additonal 8 LEDs to the demo but keep getting overrun errors. Which I'm sure it's caused on the VB side. I'm almost sure the PIC side is ok as i can turn on the original 8 LED or the ones added to PORTD. Can even turn on 4 on PORTB and 4 on PORTD. I'm just unable to get all 16 working at the same time.
    I think my problem is in this part of the VB side code. I was hoping someone could point me back in the proper direction
    Private Sub Check1_Click(index As Integer)
        '   Convert PORTB check box to decimal value before sending it
        '   to USB bus.  Result is store in BufferOut(1)
        Dim LoopCheck, PORTB As Byte
        PORTB = 0
        For LoopCheck = 0 to 15                                               ' 0 To 7
            PORTB = PORTB + (Check1(LoopCheck).Value * (2 ^ LoopCheck))
            Next
        BufferOut(1) = PORTB
        WriteSomeData
    End Sub
    Any assistance would be greatly appricated
    Quote Originally Posted by Philtkp View Post
    PORTB = 0
    Next
    WriteSomeData
    End Sub
    PortB is a byte value. A byte runs 0-255...
    2 ^ 15 = 32,768 which is greater than 255!
    Aug 2008
    Tucson AZ
    I tried changing the variable, PortB to an Integer and Long with no positive results
    Well of course it won't work.
    PortB is a Visual Basic Byte variable (or whatever you want) which gets stored in a Byte Array and sent over the USB to the PIC as a Byte variable stored in a Byte array, which is then stored in the PIC as a Byte variable.
    PORTB = 0
    Next
    WriteSomeData
    End Sub
    Last Post: - 14th June 2016, 07:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  3. Replies: 9
    Last Post: - 31st July 2008, 08:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
    Last Post: - 6th March 2005, 01:07
