USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    Previous versions of PBP didn't have the UCFG register defined in the include files. And usbdemo was written at that time.
    PBP 2.50 does have the UCFG register, so defining it in the main program causes a "re-definition" error.
    Just comment out the UCFG var byte EXT line and the error should go away.
    hth,
    Oct 2007
    I am using the 18F4550 pic, Picbasic Pro 2.50 and MicroCode Studio Plus 3.0.0.5
    When I compile it gives the following errors.
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 87 : Overwriting previous address contents (0000)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 87 : Overwriting previous address contents (0001)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 93 : Overwriting previous address contents (0000)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 93 : Overwriting previous address contents (0001)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 98 : Overwriting previous address contents (0002)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 98 : Overwriting previous address contents (0003)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 99 : Overwriting previous address contents (0004)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 99 : Overwriting previous address contents (0005)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 100 : Overwriting previous address contents (0006)
    Error[118] c:\progr~1\mecani~1\mcs\usbdemo.asm 100 : Overwriting previous address contents (0007)
    Are these errors anything to be concerned with?
    Also out of interest, I am using a 4Mhz Resonator but in the code it is: DEFINE OSC 48
    What is that about?
    However, I seem to be making progress because when I plug it into the USB of the computer. I get the message found new hardware "USB Demo" but then it gives a message There were problems ........ etc etc.
    The VB Application is not picking it up yet.
    Quote Originally Posted by kiwipiper View Post
    What to do if i get "overwriting previous address content" error message?
    http://www.picbasic.co.uk/forum/showthread.php?p=6775
    What is that about?
    The 18F/USB PIC's have an amazing oscillator/PLL structure.
    With the proper CONFIG settings, You can use any crystal that's a multiple of 4mhz (4,8,12,16,20) and still have a system clock of 48mhz.
    If the timing doesn't work well with your program, you can also have 48mhz going to the USB module, and 4/8/12/16/20/24/32 mhz going to the system clock.
    It all depends on the CONFIG's.
    Oct 2007
    I commented out the four offending lines in the 18F4550.INC file and now don't get any errors. However, still get a error message from windows when I attach the PIC
    Messages are: Found New Hardware. USB Device
    USB Human Interface Device
    A problem occurred during hardware installation. Your new hardware might not work properly.
    I have tried USBDemo.exe and HIDmonitor.exe neither of these seems to see the PIC.
    Any suggestions as to what I should try to do now to find the fault. At this stage I have not connected the push buttons or the trim pot to the breadboard but this shouldn't affect the pic being recognised as a USB device.
    P.S. I have the USB connected to 18F4550 in the following way. D- to pin 23, D+ to pin 24 and the -ve usb connection and the USB case connected to vss. I have not connected the +ve usb connection to anything.
    Oct 2007
    Smile
    Forget my last I have figured it out ....... a very happy man here.
    I had left out the .47uF cap on Vusb. Connected this and all is working.
    Will now have a serious play with it, which I sure will create a bunch more questions.
    Thanks for all your help Darrel.
    Oct 2007
    This One for Darrel Taylor. My question is how did you get on modifying the USBDemo program from VB to Delphi. I am much more comfortable working in Delphi than VB and would be really interested in any examples of Delphi Code for this project. I found a good component at http://www.soft-gems.net/index.php?o...d=14&Itemid=33 and have had some success in using it to connect to my PIC but my limited programming ability slows me down a fair bit, although I am learning a lot. If I had a working example in Delphi I am sure it would help me understand what is going on much better.
    A second question is how do you put a serial number into the program. I have been playing around with the DESCUSBDemo.asm
    file and tried to put a serial number into the code. Here is what I did:
    ; serial number
    String3
    retlw (String4-String3)/2
    retlw DSC_STR
    retlw '4'
    retlw 0x00
    retlw '3'
    retlw 0x00
    retlw '2'
    retlw 0x00
    retlw '0'
    retlw 0x00
    retlw '8'
    retlw 0x00
    retlw '8'
    retlw 0x00
    retlw '8'
    retlw 0x00
    Not working. Any suggestions.
    Both questions can be answered with EasyHID.
    The serial number is entered on one of the setup screens.
    And EasyHID will make a "Starting" program for either VB or Delphi.
    Last Post: - 14th June 2016, 07:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  3. Replies: 9
    Last Post: - 31st July 2008, 08:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
    Last Post: - 6th March 2005, 01:07
