USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    Mar 2006
    INDIA
    Can i use this demo with DasyLab Or Labview ? I using both software from long time for DAQ.
    Quote Originally Posted by precision View Post
    Sorry, i don't use them
    Johan, it's really a trough hole PLCC44 socket
    Digikey:
    A-CCS44-Z-R
    OR
    940-44-044-24-000000
    OR
    8444-11B1-RK-TP
    Jun 2007
    Yes, it is indeed just a plain PLCC socket,
    I was mistaking it as something else , I thought it was a " mini" plcc44,that fits inside DIP 40 socket, but after I look more closer, it is bigger than the DIP
    I never use PLCC44 socket before, will it fit to QFN 8x8 type PIC 18F4431 ?
    Nope, it's really 2 different animal. Even if possible, good luck with home made soldering for QFN packages
    the easiest home made soldering would be DIP or TQFP packages.
    But yes you can buy some QFN adapter.. make sure you're wallet is ready for that talking about those no solder type... kind of ZIFF for QFN... see those
    http://www.ironwoodelectronics.com/c...-P-Z-01Dwg.pdf
    http://qfp-adapter.com/Site/QFN-MLF-...cket-TOPs.htm#
    Last Post: - 14th June 2016, 08:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  3. Replies: 9
    Last Post: - 31st July 2008, 09:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
