USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    Sep 2009
    FormMain.frm is missing...
    Thanks pedja089, I just added it.
    http://www.scalerobotics.com
    Sep 2009
    Excellent project!
    Not too complicated, but there are interesting examples of communication and usage of DT's include files.
    Perhaps you should add the LCD.
    Here is my example how to sendtext from winamp to lcd:
    http://www.elektronika.ba/506/lcd-winamp-plugin-on-usb/
    I hope that you will manage the translation...
    5 years later and this thread always evolve and got some more user in the "USB freaks" loops. Glad to see that. Congrats to all!
    Now I wish I have time to revamp it and share some part of what i've done for .NET (C# & VB) ...VB6 being a dead duck for ages now... and the .dll not that suitable now (but still workable) and then on the top of it, new PBP version
    Helm PCB (Amr Bekhit) did a good work on my first .NET version though http://helmpcb.com/?p=166
    Feb 2004
    Michigan, USA
    Default Re: USBDemo, something to learn USB a little bit
    Reading through this it looks like there was a sample of code were the 18F2550 was using an external resonator at 20mhz using the HS fuse. Looking at the datasheet, this would only enable low speed USB, right?
    With those chips ... you can get Full Speed with any crystal that's a multiple of 4Mhz (up to 24Mhz).
    And the processor can run at 48Mhz too.
    They have a really nice Oscillator/PLL.
    Adjusting the Configuration bits is a little tricky though.
    Dec 2010
    Tokyo
    Hello
    I use a PIC18F2550 for CDC serial port emulation based on cdc_demo.bas:
    USBInit
    For input and output I use:
    inloop:
    icnt = inbuff
    USBService
    USBIn 3, inbuffer, icnt, inloop
    outloop:
    USBService
    ocnt = outbuff
    USBOut 3, outbuffer, ocnt, outloop
    and it works really fine.
    At start PIC tests 5V from PC-USB-Port to wait with 'USBInit'. Sometimes PC is rebooting w/o switch off, but equipmend with the PIC interface still running. Is it possible to let the PIC routine know that Windows VSP is gone and the 'USBInit' has to be done again?
    Thanks to everybody who can help
    Last Post: - 14th June 2016, 08:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 11:38
  3. Replies: 9
    Last Post: - 31st July 2008, 09:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 01:55
