USBDemo, something to learn USB a little bit
Results 1 to 40 of 279
    The ones on the left require 8-LEDs on PORTB, and 2 other LEDs on the CCP outputs, RC1/RC2.
    Previously you said you disconnected the LED's to get things working with the EasyPIC.
    The USB D-/D+ are on RC4/RC5, so I don't think you can just enable the whole bank of LED's on PORTC. You'll need to attach LEDs to only the 2 CCP Pins to get the faders working. But you should be ok with LEDs on PORTB.
    HTH,
    Mar 2009
    Colorado
    Talking Working as advertised! Another question.
    Turns out you can enable all the whole bank of LED's on PORTC and it keeps working. You can then see the LEDs on RC1 and RC2 vary in brightness as you change the sliders.
    Except for the LEDs on RB0, RB5, Rb6 & RB7 (which are used in your code) you can now click the check boxes on B1 thru B4 on the VB6 Gui and they work to light the corresponding LEDs.
    I now have Steve's VB6 GUI and the DT_HID monitor running side by side and everything works as advertised except for the exceptions I listed above for the B0 thru B7 check boxes. Your support to me in getting to this has been outstanding, Darrel. Thanks so much!
    Now I only have to figure out how to capture the data coming across the USB interface from the PIC into a spreadsheet. Your suggestion to use CDC and HYPERTERM would be an easier option except that my application requires a USB interface that is also used to connect to a cell phone, and I don't have physical room for both an RS232 and a USB interface within the physical board size contstraint or panel connector space. Looks like I have to figure out how to do the capture in Steve's USB VB6 GUI. I will modify the PIC side to send comman delimited data per your suggestion, but don't know how to approach capturing the comma delimited data from the VB6 USB Gui that is showing into a spreadsheet. Can you refer me to any forum ideas or reference tutorials in this area??
    Thanks again, Darrell. Your contributions & presence on this forum is what makes it worthwhile.
    PORTB.0 is not used anywhere in the program (other than output from the Demo).
    PORTB.5-7 are only used if the USB Status LED lines are uncommented (I left them commented). And they can be assigned to any pin, they don't have to be PORTB.5-7
    CDC is USB, there's no RS232 connector.
    In excel, use the Data | Import External Data | Import Data menu item to just plop your CSV file right into your spreadsheet. Then when the data changes, use Data | Refresh Data to update everything automatically.
    Mar 2009
    Colorado
    Question One more time
    Sorry to be such a pest, Darrell, but am now trying to adapt your USBdemo_DTID so that it will go into USB connection mode as an interrupt when the USB cable is connected, permitting me in the Interrupt Service Routine to execute some code that is only intended to be executed when the USB cable is connected.
    I thought I could make the simple changes to your code as shown in my attachment below, where I just used a USB_INT with the DT_INTS-18 include file to perform the interrupt to my label "USBhandler".
    This compiles and assembles OK and starts on power up, but when the USB cable is connected I get a WINDOWS error saying "USB Device Not Recognized". Am I missing something here on how to make this work as a USB connection interrupt??
    '*  Name    : USBdemo_DTHID2.pbp                                          *
    '*  Author  : Modification of Steve Monfette/Darrel Taylor                *
    '*  Date    : 11/9/2009                                                   *
    '*  Version : 2.0                                                         *
    '*  Notes   : This is a re-creation of mister-e's USBdemo for DT_HID      *
    '*          : Meant to work with mister-e's GUI but with a USB interrupt  *
    '*          : service routine where some specific code will be executed   *
    '*          : only during USB connection.                                 *
    ;-- if you un-comment these, you must comment the ones in the .inc file --
    ASM  ; 18F2550/4550, 8mhz crystal
       __CONFIG    _CONFIG1L, _PLLDIV_2_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
       __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
       __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
       __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
       __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE OSC 48
    CLEAR
    ;--- Setup Interrupts ------------------------------------------------------
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ' Include if using PBP high priority interrupts
    INT_LIST  macro    ; IntSource,          Label,  Type, ResetFlag?
        INT_Handler        USB_INT,    _USBhandler,   PBP,  yes
    endasm
    @    INT_ENABLE   USB_INT    ; enable external (INT) interrupts
    ;--- Setup USB -------------------------------------------------------------
    INCLUDE "DT_HID260.pbp"
    DEFINE USB_VENDORID    6017
    DEFINE USB_PRODUCTID   2000
    DEFINE USB_VERSION     1
    DEFINE USB_VENDORNAME  "Mister E/DT"
    DEFINE USB_PRODUCTNAME "USBDemo"
    DEFINE USB_SERIAL      "001"
    DEFINE USB_INSIZE      8    ;  IN report is PIC to PC (8,16,32,64)
    DEFINE USB_OUTSIZE     8    ; OUT report is PC to PIC
    DEFINE USB_POLLIN      10   ; Polling times in mS, MIN=1 MAX=10
    DEFINE USB_POLLOUT     10
    ; --- Each USB status LED is optional, comment them if not used ------------
    ; --- They can be assigned to any pin, and no further action is required ---
    DEFINE USB_LEDPOLARITY 1       ; LED ON State [0 or 1]  (default = 1)
    ;DEFINE USB_PLUGGEDLED  PORTB,7 ; LED indicates if USB is connected
    ;DEFINE USB_TXLED       PORTB,6 ;  "      "     data being sent to PC
    ;DEFINE USB_RXLED       PORTB,5 ;  "      "     data being received from PC
    ;--- Variables -------------------------------------------------------------
    Value0      VAR  WORD
    Value1      VAR  WORD
    X           VAR  WORD
    DUTY1       VAR  WORD
    DUTY2       VAR  WORD
    Old_PORTA   VAR  BYTE
    New_PORTA   VAR  BYTE
    ;--- Setup ADC -------------------------------------------------------------
    DEFINE ADC_BITS 8  ; Number of bits in ADCIN result
    ;--- Initialize ------------------------------------------------------------
    CCPR1L = 0
    CCPR2L = 0
    CCP1CON =   %00001100       ' CCP1, PWM mode
    CCP2CON =   %00001100       ' CCP2, PWM mode
    PR2     =   249             ' 0-1000 duty range
    T2CON   =   %00000101       ' TMR2 on, prescaler 1:4
    TRISB = 0
    OUTPUT PORTC.1
    OUTPUT PORTC.2
    ADCON2.7 = 0       ; left justify    (Change this if ADFM in diff register)
    ADCON1 = %1101     ; AN0/AN1 Analog
    ;--- The Main Loop ---------------------------------------------------------
        'Normally in sleep mode waiting for interrupts
        Toggle PORTE.2      ' Test LED flashing during Main loop
    GOTO Main
    '----------------Interrupt Service Routines Start Here--------------------
    USBhandler:
        FOR X = 0 to 1000         ; Check for incomming USB data while waiting
        @       ON_USBRX_GOSUB  _HandleRX
                PAUSE 1
                New_PORTA = PORTA                ; Check PORTA pins
                IF New_PORTA != Old_PORTA THEN
                    Old_PORTA = New_PORTA
                    ARRAYWRITE USBTXBuffer, ["USB Demo"]
                    GOSUB WaitToSend
                    ARRAYWRITE USBTXBuffer, [Value0, Value1, PORTA.2, _
                                             PORTA.3, PORTA.4, PORTA.5,0,0]
                    GOSUB WaitToSend
            NEXT X
            ADCIN 0, Value0            ; Send A/D about once/sec
            ADCIN 1, Value1
            GOSUB SendIfReady
        'Code to be processed only during USB connection.
            TOGGLE PortE.3      ' Test LED that USB interrupt occured
    @ INT_RETURN
    ;--- Send Data if Plugged and ready, otherwise discard --------------------
    SendIfReady:
        IF Plugged AND TX_READY THEN DoUSBOut
    ;--- Wait till Ready to send of until unplugged ---------------------------
    WaitToSend:
        WHILE Plugged and !TX_READY : WEND
        IF TX_READY THEN GOSUB DoUSBOut
    ;---- Receive incoming data PORTB LEDS and CCP PWM dutycycle ---------------
    HandleRX:
        ARRAYREAD  USBRXBuffer,[PORTB, DUTY1.LowByte, DUTY1.HighByte, _
                                        DUTY2.LowByte, DUTY2.HighByte]
        CCP1CON.5=DUTY1.1       ' load CCP1 duty value
        CCP1CON.4=DUTY1.0       '      with Duty1
        CCPR1L=DUTY1>>2         '
        CCP2CON.5=DUTY2.1       ' load CCP2 duty value
        CCP2CON.4=DUTY2.0       '      with Duty2
        CCPR2L=DUTY2>>2         '
    DT_HID already uses the USB interrupt.
    If you override it, then USB can't happen anymore.
    Besides, your routine is not suitable for interrupts anyway.
    There's 1000 loops with pauses and gosubs ... wouldn't work.
    There is already a way to determine if the cable is plugged in or not, and that is handled by DT_HID.
    When the cable is plugged in, and the USB is connected to the PC and has fully enumerated. The Plugged bit will be 1. When not plugged, it's 0.
    So just put your routine in the Main loop, and only run it IF Plugged = 1.
    Don't forget to restore the INT_Handler ...
            INT_Handler   USB_Handler
    endasm
    Also, DO NOT enter sleep mode when using USB.
    Mar 2009
    Colorado
    Unhappy Bad News!
    So what your saying is I can't have the MCU in SLEEP mode and wake it up with an intterrupt when the USB cable is connected? Unfortunately, that is exactly what we wanted to do to save battery power on our application. It is only going to have someone plug a USB cable into it once per month and we wanted to have the MCU sleep except for about 1 minute at midnight each night and also when it then sees a USB cable plug-in once per month. Keeping it awake all the time to accomadate a possible USB connection will not meet our battery life requirements.
    Is there any way to save power consumption by the embedded processing application when a USB cable is not plugged in???
    Get +5Vfrom USB itself maybe?
    You can.
    But before you put it to sleep, you'll need to put the USB module in suspend mode UCON.1, which can only be done reliably when unplugged.
    This disables the USB voltage regulator and stops the clock to the SIE, which will give the lowest current consumption.
    The USB routines are not setup to handle a resume.
    So your best bet it probably to connect the +5V from the USB cable to one of the INT pins with a pull-down resistor.
    When the cable gets plugged in, it will generate an interrupt, at which point you would execute an @ RESET to reset the processor and initialize the USB again.
    HTH
    Last Post: - 14th June 2016, 07:55
  2. How to receive stream of bytes using PIC USART
    By unifoxz in forum mel PIC BASIC Pro
    Last Post: - 20th June 2009, 10:38
  3. Replies: 9
    Last Post: - 31st July 2008, 08:56
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
    Last Post: - 6th March 2005, 01:07
