Delay Problem,Byte,Word
Results 1 to 21 of 21
    It's certainely strange dude...
    Wich PIC #
    Wich PBP version?
    Pic 16F870 and PBP 2.46.
    Maybe is this a Compiler Bug for the Pause Command.
    mmm, i think i may have spotted few problems...
    When you declare an array like this...
    Array var BYTE[3]
    it will hold 3 different value. And they will be...
    Array[0]
    Array[1]
    Array[2]
    Not MUCH, if you Write to Array[3], the compiler won't complaint... but it will cause you some problem one day or another because you WILL overwrite x variable...
    so just modify your code and it should work better. In VB it work.. but it's a little bit different in PBP.
    Just for testing, try...
    DelayArray  var byte[4]
        delayarray[0]=1
        delayarray[1]=10
        delayarray[2]=100
        delayarray[3]=200
    Delay       var word
    CounterA    var byte
    Start:
        for countera=0 to 3
            high PORTB.0
            delay=delayarray[countera]
            pause delay
            low PORTB.0
            pause delay
            next
        goto start
    at least it's working here
    Mister thank a lot I will try now your code,
    I try this too:
    Delay1 var Word
    Delay2 var Byte
    Delay1 = Datain[3] * Datain[4]
    if Delay1 < 256 then
    Delay2 = Delay1
    Delay1 = 0
    Delay2 = 0
    Loop = (Datain[2] * 10)
    ''''''''''''''''''''''''''''''''''''''''''''Progra m 1''''''''''''''''''''''''''''''''''''''''''''''''' ''
    IF Datain[1] = 0 then
    for N = 0 to Widerholung
    High PortC.0
    High PortC.1
    low PortC.2
    low PortC.3
    Pause Delay1
    Pause Delay2
    low PortC.0
    High PortC.1
    high PortC.2
    low PortC.3
    Pause Delay1
    Pause Delay2
    low PortC.0
    low PortC.1
    high PortC.2
    high PortC.3
    Pause Delay1
    Pause Delay2
    high PortC.0
    low PortC.1
    low PortC.2
    high PortC.3
    Pause Delay1
    Pause Delay2
    Next N
    This Work ! :-)
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  3. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 16:34
  4. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 19:55
  5. Problem with saving to EEPROM...
    Last Post: - 1st July 2005, 00:10
