Delay Problem,Byte,Word
Results 1 to 21 of 21
    Default Delay Problem,Byte,Word
    I have a little problem:
    Delay1 var word
    DataIn var byte [12]
    Delay1 = Datain[3]
    pause Delay1
    Pause just work wenn Delay1 > 255 Why.
    I want for Example to have a Delay sometimes 1 or 10 or 50 Milliseconds and sometime over a Second.
    Its just work when Delay1 > as Byte.
    How can I transform this Datain to Word.
    I try with this:
    Delay1.byte0 = Datain[3]
    Delay1.byte1 = Datain[4]
    Pause delay1
    But this dont' Work.
    I need Please a Help.
    Thank You very mouch !!!
    Ciao.
    As you figured out it won't work because DataIn[3] is a byte sized variable, it can only hold values between 0 and 255. To do what you want something like this may work:
    Delay1 = DataIn[3] * 256 + DataIn[4]
    OR
    Delay1.HighByte = DataIn[3]
    Delay1.LowByte = DataIn[4]
    In both examples DataIn[3] is the most is the upper 8 bits, DataIn[4] is the lower 8 bits of the word sized Delay1.
    /Henrik Olsson.
    Jan 2006
    Istanbul
    Why not DataIn VAR WORD[12] ?
    Do I need more coffee again?
    Or am I missing something here again?
    Why I must to multiple this with 256 I don't understand.
    What I can do to have for example 1 Millisecond or 5 Millisecond with Pause.
    Thanks.
    Ciao.
    What is the range of your values? if all of them are <255, i guess you just need to use..
    Delay1=0
    Delay1.LowByte=DataIn[3]
    Pause Delay1
    in case the range is greater than 255, Sayzer's suggestion have to work... or i miss something myself too
    (I may be missing something here too, but here comes the long winded answer....)
    Since you have an array of 12 bytes each byte can only hold a value between 0 and 255. If you want a delay longer than 255mS you need to, either use an array of words OR use two bytes in the byte-array to 'make' a word.
    The multiply by 256 "shifts" the 8 bits in DataIn[3] to the upper 8 bits in Delay1.
    Say you want a 1000mS delay. Since 1000 wont fit in a byte you'll use two bytes. 1000 in binary is 00000011 11101000 so DataIn[3] = 3 and DataIn[4] = 232.
    Then when you parse it you get Delay1 = DataIn[3] * 256 + DataIn[4] which is the same as 3 * 256 + 232 = 1000.
    Or the easier way:
    /Henrik Olsson.
    Thanks a lot.
    But When Delay1 < 256 dont' work.
    This is my Code:
    INCLUDE "modedefs.bas"
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 12 ' 19200 Bauds
    DEFINE HSER_CLROERR 1
    Adresse var byte
    AdresseIn var byte
    N var byte
    Delay1 var word
    Loop var word
    Kanal var byte [5]
    KanalCount var byte
    SOUND PORTB.1,[124,100]
    MainStart:
    Adresse = $1
    low PORTB.0 '''''''''''''''''''''''''''''''''''''''''''''RS485 Input Data Enable'''''''''''''''''''''''''''''''''''''''''''' ''''''''''''
    hserin 10000,MainStart,[WAIT("!"),STR Datain\13]
    CheckAdr:
    AdresseIn = Datain[0]
    if Adresse = AdresseIn then RcvData
    GoTo MainStart
    RcvData:
    IF Datain[11] = 13 Then CheckEnd
    Goto MainStart
    CheckEnd:
    IF Datain[12] = 10 Then Discard
    Goto MainStart
    Discard:
    Delay1 = 256
    Delay1 = (DataIn[3] * 256) + DataIn[4]
    Loop = (Datain[2] * 10)
    Kanal[0] = Datain[5]
    Kanal[1] = Datain[6]
    Kanal[2] = Datain[7]
    Kanal[3] = Datain[8]
    Kanal[4] = Datain[9]
    Kanal[5] = Datain[10]
    KanalCount = 0
    'SOUND PORTB.1,[124,30]
    ''''''''''''''''''''''''''''''''''''''''''''Progra m 1''''''''''''''''''''''''''''''''''''''''''''''''' ''
    IF Datain[1] = 0 then
    for N = 0 to Loop
    High PortC.0
    High PortC.1
    low PortC.2
    low PortC.3
    Pause Delay1
    low PortC.0
    High PortC.1
    high PortC.2
    low PortC.3
    Pause Delay1
    low PortC.0
    low PortC.1
    high PortC.2
    high PortC.3
    Pause Delay1
    high PortC.0
    low PortC.1
    low PortC.2
    high PortC.3
    Pause Delay1
    Next N
    GoTo MainStart
    My Code Work just fine wehn the Delay Value > Byte is.
    But I need for Example : Pause Delay1 = 1
    I Wrote a visual Basic Software where I can send this Delays values,but this work just wehn this Word Variable > 255.
    Thanks.
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  3. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 16:34
  4. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 19:55
  5. Problem with saving to EEPROM...
    Last Post: - 1st July 2005, 00:10
