18F2510 help
Results 1 to 8 of 8
Thread: 18F2510 help
    Default 18F2510 help
    Hello Everyone. I recently added code to a program compiled for a 16F76 and it wouldn't fit in the PIC. So I compiled it for a 18F2510 and the timing seems to be off. Certain sections of the code seem to run slower while other sections run a little too fast. Does anyone have any suggestions? I changed adcon1 = 7 to adcon1 = 15 for the 18F PIC. I also had to remove my @device line to compile without errors. I then set the config bits within MPLAB before programming. Thank you.
    Just make sure that all register match from one to another. Sometimes, some specific bits on a device are not located at the same place on another one.
    If you don't mind, post your code here.
    Thanks Steve. One interesting thing is the beginning of the program runs slow - delays that are supposed to last only 1/2 second take 2 seconds to complete. I was able to eliminate this by changing the Watchdog Postscaler from it's default of 1:128 to 1:8. However, later in the program there are delays that are supposed to last up to 6 seconds but finish in about 4-1/2 seconds. Any ideas?? - Thank you.
    I didn't check the datasheet but, are you using the internal OSC (if there's) ?
    try the eternal Led Blink first and post your observations here.
    Hi Steve. The circuit uses a 4MHZ ceramic resonator. Again, the 16F76 worked perfectly until I compiled it for 18F2510. I must be missing something???
    Sep 2003
    Vermont
    Quote Originally Posted by peterdeco1 View Post
    How are you implementing the delays?
    Weird,
    your ADCON setting is good, the comparator are off at POR... so...
    Any way to post your config fuses setting here?
