Using the A/D for Monitoring a Solor Cell and Battery
Results 1 to 7 of 7
Threaded View
  1. #2
    Hi Chuck,
    This should help out. I Hope.
    In the sample voltage divider shown below. If the input is 25Vdc then the output voltage will be about 4.38 Vdc.
    With 10-bit A/D you should get an ADCin of around 898.
    If you first scale that A/D value up to match the voltage divider ratio, you can then calculate the voltage the same way you would if you were reading 0-5 V.
    The ratio of the voltage divider is (R1+R2)/R2.
    To scale up the A/D reading you just multiply the value times the total resistance of the divider (R1+R2) then divide that number by R2.
    898 * 5700 / 1000 = 5118
    This is what the A/D would be if it could actually read 0-25 volts directly.
    Now then, for 1 decimal place, multiply that by 50 and divide by 1023.
    For 2 decimal places, multiply by 500 instead.
    5118 * 50 / 1023 = 250 or 25.0Vdc
    The program below is one way to do it in PBP.
    HTH,
    Darrel
    Res1   Var Word
    Res2   Var Word
    Rt     Var Word
    Volts  Var Word
    AD     Var Word
    Loop:
       ADCin  0, AD
       Res1 = 4700          ' Change these to match your Voltage divider
       Res2 = 1000          ' resistor values for the Solar Cell
       Gosub CalcVoltage
       LCDout $FE,2,"Solar= ",DEC Volts/10,".",DEC1 Volts Dig 0," Vdc"
       ADCin  1, AD
       Res1 = 2200          ' Change these to match your Voltage divider
       Res2 = 1000          ' resistor values for the Battery
       Gosub CalcVoltage
       LCDout $FE,$C0,"Batt = ",DEC Volts/10,".",DEC1 Volts Dig 0," Vdc"
    goto Loop
    CalcVoltage:
        Rt = Res1 + Res2        ' Total resistance of Voltage Divider
        Volts = AD * Rt         ' Scale the AD reading accordingly
        Volts = DIV32 Res2
        Volts = Volts * 50      ' Convert AD to Voltage
        Volts = DIV32 1023
  1. A/d 16f88
    By Steves in forum mel PIC BASIC Pro
    Last Post: - 31st May 2009, 02:19
  2. Of battery discharge curves
    By ardhuru in forum General
    Last Post: - 21st January 2009, 17:24
  3. 12f675 A/d Miseries
    By MARAD75 in forum mel PIC BASIC Pro
    Last Post: - 16th December 2008, 03:16
  4. Low battery signal from an RTC
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 19th March 2008, 18:13
  5. Need advice on A/D
    By james in forum mel PIC BASIC Pro
    Last Post: - 24th August 2007, 20:30
