Hello,
If you just compiled a program in Microcode Studio by pressing the button for Compile and Program or pressed F10 it should have brought up the programmer window. This is what happens when I use the ME Labs USB programmer or the EPIC programmer. The only time it doesn't is when I use the PIC Flash from Mikroelektronica. Then I have to open the programmer program and then select the .hex file to load. That may be because I don't have the path for PicFlash setup properly. But as long as I have used MCS it has always opened the programmer window with the .hex file ready to load.
BobK
