Select case...Just wondering....
Results 1 to 6 of 6
    Jan 2006
    Istanbul
    Ok, we get (save) more space then, as long as the values are in the same ascending order.
    Muddy, pick the second.
    New Jersey
    To further the discussion, because I have never used select case before, can you do something like this:
    SELECT CASE x
    CASE IS < 21 led1
    CASE IS < 41 led2
    END SELECT
    I am used to something like this
    If x=1 then
    goto led1
    goto led2
    Also, an OT question. How do you guys get the code to display in blue?
    Chris
    Quote Originally Posted by Christopher4187 View Post
    SELECT CASE x
    CASE IS < 21 led1
    CASE IS < 41 led2
    END SELECT
    If x=1 then
    goto led1
    goto led2
    Chris
    Should work. If it doesn't, reverse the cases around a bit...
    SELECT CASE x
    CASE IS > 20
    GOTO LED1
    CASE IS > 0
    GOTO LED2
    END SELECT
    Sometimes it's all about the order things go in...
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 08:10
  3. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 19:19
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 15:04
  5. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 22:05
