Select case...Just wondering....
Results 1 to 6 of 6
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default Select case...Just wondering....
    I haven't tried this yet, but my reading of the manual says I should be able to do something like-----
    select case X 'X is the name of a/d variable
    case 0<X<20
    go do something
    case 21<X<40 'or should this be IS >21 AND IS < 40
    go do something different
    case 41<X<60
    go do something different still
    etc, etc.
    Does anyone reckon this will work?
    Just thinking out loud,
    Peter Moritz.
    Jan 2006
    Istanbul
    What about these?
    First one works for sure.
    SELECT CASE x
         CASE IS < 21   'Between 0 and 20; including 20.
         CASE IS > 20 AND IS < 41 'Between 21 and 40 ; including 21 and 40.
         CASE IS > 40 AND IS < 61  'Between 41 and 60 ; including 41 and 60.
    END SELECT
    For this second one, I expect someone to confirm.
    'Once it hits the first matching condition it should not go to the next one.
    'Or will it?
    SELECT CASE x
         CASE IS < 41 'Between 21 and 40 ; including 21 and 40.
         CASE IS < 61 'Between 41 and 60 ; including 41 and 60.
    END SELECT
    Last edited by sayzer; - 29th December 2006 at 17:17. Reason: Added the second example.
    Feb 2003
    Salt Lake City, Utah USA
    sayzer,
    go with the second - it works the same as the first
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Jan 2006
    Istanbul
    Ok, we get (save) more space then, as long as the values are in the same ascending order.
    Muddy, pick the second.
    New Jersey
    To further the discussion, because I have never used select case before, can you do something like this:
    SELECT CASE x
    CASE IS < 21 led1
    CASE IS < 41 led2
    END SELECT
    I am used to something like this
    If x=1 then
    goto led1
    goto led2
    Also, an OT question. How do you guys get the code to display in blue?
    Chris
    Quote Originally Posted by Christopher4187 View Post
    SELECT CASE x
    CASE IS < 21 led1
    CASE IS < 41 led2
    END SELECT
    If x=1 then
    goto led1
    goto led2
    Chris
    Should work. If it doesn't, reverse the cases around a bit...
    SELECT CASE x
    CASE IS > 20
    GOTO LED1
    CASE IS > 0
    GOTO LED2
    END SELECT
    Sometimes it's all about the order things go in...
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  3. Write Onewire data toa I2C memory / read ASCI
    By Eugeniu in forum mel PIC BASIC Pro
    Last Post: - 16th November 2008, 20:19
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 23:05
