Audio D/A idea
Results 1 to 2 of 2
Thread: Audio D/A idea
    Radiance's Avatar
    Radiance Guest
    Default Audio D/A idea
    I have a screwy idea about building a low cost digital wireless 2-way radio using the A/D input on a pic, some of the 433 mhz low power xcvers, and a D/A converter on the other side.
    The question is, can the PWM function in PicBasic be used as a D/A converter with enough accuracy and granularity to accurately reproduce the human voice? I know the 10 bit A/D's are sufficient, but the PWM command shows only 255 steps. Does this mean I only get 8 bit resolution from PWM? Also, can sound even be reproduced in this manner? The Sound command does not look like it would be sufficient due to the limited granularity (127) of the frequency range reproduced.
    Take a look at this as a starter...
    http://www.microchip.com/1000/edit/p..._174/index.htm
    The 18F parts at 40MHz have considerable processing power for DSP applications. It's one of those play and experiment kind of things...
    Melanie
  1. Audio Amplifier
    Last Post: - 20th August 2008, 10:45
  2. Idea of master/slave serial comm.
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 6th December 2007, 09:36
  3. Replies: 5
    Last Post: - 18th July 2007, 11:43
  4. PIC Audio
    By toofastdave in forum mel PIC BASIC Pro
    Last Post: - 27th June 2007, 14:49
  5. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 21:42
